Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-02-2008, 03:23 PM   #1
clamp to big for battery terminal
i noticed it a while ago and keep putting off fixing it because its really nbd but now it's starting to bother me, the clamp for the positive terminal on my battery is to big, it's tightened all the way and it still can just slide on and off.
Has anyone else had this problem? how did you fix it
__________________
97 SE 5spd
SHIFT_VQ
T Keck is offline   Reply With Quote
Old 12-02-2008, 04:10 PM   #2
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
the positive side is too big?
normally it is the negative side that is too big. some batteries use a smaller negative post than the positive side does.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 12-02-2008, 04:21 PM   #3
One of mine is like that too, I believe it's the positive but it's dark out and I'm in my pajamas and I don't wanna go look. It has a sabot-type thing, a little flat piece of metal wedged in between the clamp and the post. It does the job I guess.
__________________
SHIFT_F7
99BettySE is offline   Reply With Quote
Old 12-02-2008, 04:30 PM   #4
yep, at first I thought it was because of all the things i have running onto the clamp (horn, HIDs, Subs) but i realized they way i have them on there that they are actually making it tighter, i guess I'll try a shim
__________________
97 SE 5spd
SHIFT_VQ
Old 12-02-2008, 07:50 PM   #5
buy a car from him?
Quote:
depending on how much too big it is, you may be able to put some aluminum foil between the terminal and the post to pick up the slack.
__________________
96 Green A/T gone
Old 12-02-2008, 08:54 PM   #6
Check the clamp very close, I bet it is cracked. I found mine cracked and making poor contact a few years ago. I bought a replacement terminal from the parts store and fixed it. I did not buy the generic clamp where you have to hack up your battery cable. I found a clamp like the orignal one and cut the hoop off the old cable. I was able to trim the new clamp so it could be bolted to the remains of the orignal cable. It looks factory and retained the secondary connections and plastic protective cover.
__________________
click here for more pictures
z32drifter is offline   Reply With Quote
Old 12-02-2008, 11:01 PM   #7
i have the same prob. I need to change the postive terminal. I bought the universal clamps. Can I cut everythign close to the old clamp and just put all the wires together and clamp it down on the new one. The reason I asked is, bc I seen 2 black wires that were seperate on the postive terminal
maxx0831 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
