Battery
Old 11-30-2008, 01:59 PM
maxima-junky's Avatar
Battery
My friends 97 gxe runs and drives fine but if it's left sitting over the weekend the battery is dead upon attempt start up monday morning. Iv'e checked every thing I can think of and there wasn't anything on in the car when I reinstalled charged up batt. Anyone have this exp is so what did it wind up being?
maxima-junky is offline
Old 11-30-2008, 02:04 PM
tbergma1's Avatar
I had a friends bmw do the same thing. It turned out to be the glove box light staying on even though it was closed.
tbergma1 is offline
Old 11-30-2008, 02:10 PM
maxfever1987's Avatar
search, theres so much on here about batteries, look at the most recent ones goodluck
maxfever1987 is offline
Old 11-30-2008, 02:20 PM
B_Eaze's Avatar
No corrosion? Whats voltage while cars running? If those are fine, batt is def being drained by something that will most likely be a PIA to find.
B_Eaze is offline
Old 11-30-2008, 02:33 PM
its should be 13.5-14.4 some 1 correct me i im wrong
Old 11-30-2008, 10:58 PM
FallenOne's Avatar
While the Vehicle is Ideling, the voltage needs to be at least 13.5, you should be able to turn the blower, and a few other elctronice items on and the voltage still stay about normal.. i had an issue quite recently where my alt went bad, and at Idle with my blower or Any electrical drain whatsoever, my battery would begin to drain, and with its constant drain...
well A new Alternator and battery later.. here i am. :
FallenOne is offline
Old 12-01-2008, 05:22 AM
njmaxseltd's Avatar
How old is the battery? Have it load tested to see if it's starting to fail.
Also measure the parasitic(sp?) drain on the electrical system. If it's high, start looking for the cause by isolating circuits by pulling fuses one at a time.
njmaxseltd is offline
Old 12-02-2008, 07:08 PM
fixerupper10's Avatar
i would definatly see if maybe something random is left on or hey if it gets driven around sometime during the weekend your alternator could be going out thats going to suck if its that
fixerupper10 is offline
06-06-2017 02:01 PM
gigabyte
01-06-2017 06:05 PM
bigfrank
10-01-2015 12:51 PM
markevans999
09-10-2015 04:29 PM
Quick Reply: Battery
