Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-28-2008, 07:04 AM   #1
doesn't twitter
rxm6's Avatar
shudder on accel at low speeds
just had axles replaced, never did this before axles.
doesn't shudder when not accelerating, just when accelerating between certain lower speeds. At high speeds i don't feel any shudder. Alignment needed? something else?
rxm6 is offline   Reply With Quote
Old 11-28-2008, 06:58 PM   #2
Not much to go on. Is the shudder seeming to be the engine misfiring, or just a vibration in the front end. ? Are you MT or Auto ? Could be motor mounts. Were the old axles noisy or just bad boots ? Really need more info to more than list guesses.
Fasteddie01 is offline   Reply With Quote
Old 11-28-2008, 07:47 PM   #3
Probably motor mounts but yeah were gonna need more info
__________________
WTB 97-99 Stillen Front Lip
maxboy325 is offline   Reply With Quote
Old 11-29-2008, 04:53 PM   #4
mine does the same thing after axle replacement. im auto. my axels popped around corners, and were tore other than that they were fine. its just a vibration. ive had 3 mechanics look at it and none of them knows what it is
__________________
tigersharkdude is offline   Reply With Quote
Old 11-29-2008, 04:56 PM   #5
doesn't twitter
rxm6's Avatar
axles' boots were bad.
not engine either, this began to happen immediately after axles were replaced. by shudder, i mean, the steering wheel vibrates excessively between 10 and 35 mph on acceleration. there is no vibration while coasting either. If i'm coasting at 20mph and then i accelerate, the wheel will shudder. If i'm coasting at 45 and i accelerate, there will be no shudder. For reasons unknown to me, it only occurs at lower speeds. When i'm on the freeway, i have no vibrations which is why i was confused by it because if it was alignment i would think that i would feel it most at freeway speeds.
Old 11-29-2008, 05:47 PM   #6
the same hear, only from a stop up till about 20mph. mines not that bad, just annoying at first. now im used to it though. I know mines not an alignment issue because I have had 2 done since the axle swap.
__________________
Old 11-30-2008, 02:53 PM   #7
Send a message via AIM to QNO_A32
its the axles, your probably gonna have to replace them or maybe just one at a time you know
__________________
SHIFT_ pinned
QNO_A32 is offline   Reply With Quote
Old 11-30-2008, 05:17 PM   #8
I have had my axels replaced, twice!! well it started doing it after the first replacement, so I had them replaced again 2 days later and it still does it.
__________________
Old 11-30-2008, 07:31 PM   #9
My brother's Q45 did this at low speeds. It was the axles.
__________________
1990 Infiniti Q45 - Sold
1996 Lexus LS 400 - Sold
1996 Nissan Maxima SE 5MT - Proud owner
EEMaxima is offline   Reply With Quote
Old 11-30-2008, 07:35 PM   #10
but i have had 2 different sets, SO ITS NOT LIKE I GOT A BAD AXEL
__________________
Old 12-01-2008, 06:47 AM   #11
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
Quote:
why not?
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 12-01-2008, 08:00 AM   #12
Are the bearings OK ? That may cause vibration, which may smooth out at higher speeds ? Maybe warped rotor ?
Old 12-01-2008, 08:24 AM   #13
tighten the axle nut properly? are your lug nuts tight?
__________________
The FIRST AWD Maxima'97 Black/Black SE 5 Speed: DEK swap, K&N, Budget Y, Budget Test Pipe, Budget B, Dynomax Muffler, Exedy Clutch, Shortened shifter, Mustang GT shift knob, Smoked Red/Clears, AE'd Headlights, Yellow Fogs, Ebay FSTB, Ionic front Lip, Intrax Springs, 17in G35 Coupes.....EManage Ultimate!
MaximaSpd85 is offline   Reply With Quote
Old 12-01-2008, 11:06 AM   #14
Bad axle(s) - specifically the inner joint sticks. Even more likely if the car is lowered.
7jackmack is offline   Reply With Quote
Old 12-01-2008, 04:03 PM   #15
doesn't twitter
rxm6's Avatar
car is lowered.
both axles were replaced and bearings inspected at that time. also, pads and rotors were replaced at the same time. car does pull to the right a wee bit, but not enough to cause that shudder only at certain speeds. i will get an alignment done, but i'm waiting on new tires which are about due in a month's time. just wanted to see if there was a clear answer on this or if other member's experienced this.
Old 12-02-2008, 05:44 AM   #16
t_ahan's Avatar
same here
i have a shuttering problem to but its torque converter chatter it sounds like the same.Also ive been told that BG synthetic trans fluid can help torque converter chatter but i have never flushed it since i only have 10k miles on the fluid in there now.
__________________
MR.T
t_ahan is offline   Reply With Quote
Old 12-02-2008, 06:24 AM   #17
my car also pulls slightly to the right but ive had an alignment(not by goodyear,etc) but by a shop that specializes in high performance and lowered vehicles
__________________
Old 12-02-2008, 07:19 AM   #18
Maxima.org, my g/f's nightmare
JtzMax's Avatar
Send a message via Yahoo to JtzMax
bad axle .... like everyone here has mentioned. I also agree that it is the inner joint on whichever axle it is (or both). Did you get your axles from Raxles? See .... if you would have, there would be none of this vibration / shuttering crap at all. Buy 'remaned' Autozone parts and see ... this is what you get. Raxles FTMFW!!!!!
__________________
CAI, Test Pipe Cat, JDM N1 Cat back, FSTB, Aluminium dash kit, STS, Razo shift knob, Clear markers, CC mod, .ORG Stickers (bright blue), Blue LED switches / map lights, A6 Bi-Xenon retrofit, rebuilt 5spd - My write up --> http://forums.maxima.org/showthread....121&highlight=
Need a wiring harness for your Xenon / Bi-xenon retro? PM ME
JtzMax is offline   Reply With Quote
Old 12-02-2008, 10:30 AM   #19
look at your hub! it is very much so possible to warp your hub which would also cause a vibration and shudder. if that is the case expect to replace your wheel bearings again soon! warped hub would be caused by someone trying to remove the main axle nut without air tools and having to pry against the lugs to counteract axle nut rotation... just a thought! also... my more realistic guess is that if your mt... you probably warped your flywheel. with a warped flywheel your car will shudder like crazy at low speeds/gears where you have enough torque for the clutch to slip on a warped flywheel. i am currently experiencing the warped flywheel problem and your description of your problem sounds very similar. i would almost bet money that its your flywheel and not a motor mount. my motor mounts made a loud thud sound when they went out and it would happen under acceleration and decceleration. with the flywheel it would make sense that you only notice it at low speeds/gears because you prob don't have the horsepower or torque to slip the clutch in anything past 2nd or 3rd gear.
DenverMax99 is offline   Reply With Quote
Old 12-02-2008, 10:38 AM   #20
Send a message via AIM to ImmaSquashYou
Quote:
seriously...i had 3 bad axles from napa. returned them one from another. went with raxles...and i almost hit myself for trying to save like $60
__________________
3 Threads, same question. Good Job Mantis!!
http://forums.maxima.org/infiniti-i3...ights-fit.html
Quote:
Originally Posted by JNCoRacer View Post
Good god, again?
Might I refer you here...http://forums.maxima.org/4th-generat...nto-i30-2.html
Quote:
Originally Posted by mantis40 View Post
OMG THANKS! Looks like some good info there
Quote:
Originally Posted by a33i30 View Post
^You started that thread
ImmaSquashYou is offline   Reply With Quote
Old 12-02-2008, 09:46 PM   #21
JtzMax's Avatar
Quote:
First off ... welcome to the .Org mate.
Now with that out of the way, WTF are you gabbing on about? You don't seem to understand what you are talking about here. A clutch / flywheel issue is not even the topic here - so as much as you want to go on about that, it's pointless. As far as you thinking it's a hub - since when can you warp the hub so much it would cause vibration? I could see a bad wheel bearing (but that is not what the OP was asking / talking about) making noise, but not causing vibration. Not to mention that a bad wheel bearing makes a growling sound to top it all off. Perhaps you should just read more and not post just yet.
__________________
Old 12-03-2008, 12:17 PM   #22
ya its the axel like everyone said before when you have them taken off look at the berings and see if they look any different to you before you put them on.
fixerupper10 is offline   Reply With Quote
Old 12-03-2008, 12:17 PM   #23
Dont be rude! everything i've stated was out of experience in the last 3 weeks! when your wheel bearing gets bad enough your entire hub can move around up to probably 3/4" and you think that wouldn't cause a vibration? the ball bearings will overheat get mis-shapped and then start to overlap each other until there is nothing left but shards of metal inside the outer race. and no i do not think that his problem is wheel bearing related because slow speeds wouldn't make any difference. trust me on this i replaced my passenger side last saturday and my drivers side 2 weeks ago. and both had gotten bad enough to warp the hub and ruin the entire steering knuckle.(NOTE TO ALL: NEVER CONTINUE TO DRIVE ON A BAD WHEEL BEARING!)
rxm6- i've got extra axles for both right and left side. they are left over from my vlsd tranny swap. they were in perfect condition when i took them out and were purchased from the dealership 2 years ago.(6 months of which the car sat in storage) if your interested in buying them and saving some cash just shoot me a pm i'm sure we can find a price that works for us both...
jtzmax- your comment was rude! i thought we were all on here to try to help each other. all you did was repost what 10 other people had already stated... congratulations! at least i brought up a new idea and can back it with personal experience. as for you trying to call me a noob... i've been a member for over a year with this account... 2 years with my old account and i'm on here reading almost everyday. if your wondering why i don't post very often it's because i don't want to be like you and flood .org with re-stating information that is already on this site! i'm one of the few who has been respectful enough to do my research instead of reposting the same old question or replying to someone asking a question thats in the newbie forum. so i'm sorry if my idea upset you enough for you to need to call me out but maybe it's you that should calm down a little bit. if the .org is the only social life you have and you must pick your battles on here then i feel sorry for you... i'm only on here to use this priceless information from experienced vq enthusiasts. so from now on try to keep it proffesional! why am i even wasting my time writting this to you... i just stooped to your level... goodbye!
funny thing is... i used parts of your tranny write-up to put in my vlsd tranny last month. haha... small world
Old 12-03-2008, 04:20 PM   #24
doesn't twitter
rxm6's Avatar
axles are from raxles and they were professionally installed along with everything else by a very qualified nissan-only mechanic I have used for years on all of my cars
I have an at and t_ahan's torque converter chatter theory sounds interesting. I've never had my at fluid flushed or replaced for that matter and i should really check that out, which i will do tonight.
thx for comments, although, i dont understand how new axles would cause this problem? bad manufacturing?
Old 12-05-2008, 09:04 AM   #25
JtzMax's Avatar
Denver ...
Glad my write up helped you out. That is why I am here. As for your post above .... you go on thinking what ever the F you wanna man. Your opinion means jack sh!t to me dude. If you think that first comment was rude, too bad I guess. I'm not on here to "shotgun" parts into a car. Your idea of the hub going bad is a bit extreme IMO. If you can't tell a bad hub (and you obviousley didn't know it untill it had gotten WAY bad) by the sound of it, you're not a mechanic. As I said before, a bad hub makes a groaning sound - most people will notice and look into the noise before it gets too bad ... but in your case, you let it go from the sounds of it.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
