Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-19-2008, 09:36 PM   #1
Weird Sound from Tire
I recently got my frony brakes done and now have a soft sqeeling noise from my front tire. It picks up when I accelerate and then slows down and eventually stops when I brake. Anyone know what this might be?
viper250 is offline   Reply With Quote
Old 11-20-2008, 04:01 AM   #2
Maintenance Monster
Sounds like the brake pad is dragging on the rotor.
Did the mechanic relube the sliders when you got your brakes done?
dgeesaman is online now   Reply With Quote
Old 11-20-2008, 07:36 AM   #3
doubt it^^
__________________
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Jan-2009
Snypa is offline   Reply With Quote
Old 11-20-2008, 07:52 AM   #4
NOT Banned
JSMax's Avatar
Send a message via MSN to JSMax
is it constant? The noise that is.
__________________
JSMax is offline   Reply With Quote
Old 11-20-2008, 02:36 PM   #5
I asked a similar question recently and I was told this:
Caliper brackets. Make sure they are tight, make sure the shims are good, make sure both guide pins float freely. Probably need to tear it down & clean/inspect/regrease properly. So many people do brakes and don't know what where and how to clean & grease the caliper brackers. May need to replace due to worn guide pins, could also have a poor fitting break pad (evidenced by clicking, spin the wheel backwords in the air and you should be able to watch the pad move in the holder (holder=caliper bracket)
zeddy is offline   Reply With Quote
Old 11-24-2008, 01:28 PM   #6
No its not constant, I just took it to the dealer and they said the noise had something to do with the wheel bearing/dust pin. Then quoted me about $350 to fix it, so im definately not getting it done there
Old 11-24-2008, 01:48 PM   #7
its probably your bearing. mine made noise when it was goin out. buy some bearings yourself. then fix it. total cost. $60-$80
gregmaxin is online now   Reply With Quote
Old 11-24-2008, 05:29 PM   #8
How wasy is it to install new bearings? and would that be the only thing i would need to buy?
Old 11-24-2008, 05:33 PM   #9
Send a message via AIM to hasuna91 Send a message via Yahoo to hasuna91
answer this mans questin hahah i have the same problem, my bearings are going out
hasuna91 is offline   Reply With Quote
Old 11-24-2008, 07:42 PM   #10
Maintenance Monster
If you want to change the bearing yourself, don't expect to press out the bearing with any normal tools. You'll need a pretty hefty press. I pulled the knuckle and paid a shop $40 to change the bearing for me.
Dave
Old 11-24-2008, 11:02 PM   #11
Super Member
TunerMaxima3000's Avatar
If you had this issue immediately after your brake job, and no symptoms before, why the heLL is everyone suspecting a wheel bearing?
It's your dust sheild, it got bent during the brake job.
If you can access it, just bend/tweak it from inside until it stops making noise.
It's possible that your shims are causing the problem as well, if they aren't replaced they usually won't hold on after a change of pads, unless they're properly 'glued' on.
If I were you, I'd just take it back to the mechanic if straightening the dust sheild doesn't work.
__________________
______________
<<'87 Z31 VG30ET (Hibernating) <> '97 A32 VQ30DE>>
TunerMaxima3000 is offline   Reply With Quote
Old 11-25-2008, 06:08 PM   #12
but it almost sounds like something rubber, and it is not constant. If the dust shield was bent when the brakes were redone, wouldn't that be a constant noise?
Old 11-25-2008, 06:19 PM   #13
Greeny's Avatar
Bad wheel bearings do not squeal or squeak, they grind/roar, similar to the sound of a large rock being dragged across a concrete sidewalk.
Unless you have your sound explanation wrong, you probably have a brake pad dragging the rotor,could be from seized caliper slide pins, a seized caliper, crappy pads, worn/broken or missing brake pad shims/holders.
If you are not able to do the work yourself, then do not take your car back to the same place that done the brake job originally.
__________________
Quote:
Originally Posted by Jason Robards
For democracy, any man would give his only begotten son.
Greeny is offline   Reply With Quote
Old 11-25-2008, 06:23 PM   #14
Send a message via AIM to petro2342
Not really. Depends how bent it got. When I changed my brakes they were making noise, but went away after a few minutes. Pull the wheel and check that every things intact.
Did you or a shop did this?
__________________
1997 Maxima SE 5spd l Short Shifter l Tokico HP245 Kit l K&N Air Filter l Daily Driver
1990 240sx SE 5spd l RB20DET l Project Car
petro2342 is offline   Reply With Quote
Old 11-25-2008, 08:30 PM   #15
blah, blah, blah...
internetautomar's Avatar
Send a message via AIM to internetautomar
didn't we just cover this over in the third gen section
__________________
Maxima parts catalog
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
Quote:
Originally Posted by Benstoked
he is worth his weight in platinum plugs
internetautomar is online now   Reply With Quote
Old 11-25-2008, 09:10 PM   #16
Well, the sound explanation is the best I could think of, lol, but it is definately not a grind/roar. And I think I would be capable of doing it myself (Ive done plenty of other stuff to my max), but the dealer put these brakes on. They did it for free though because the first time they screwed up and I was getting grooves in my rotors. Then they redid the brakes for free and not more than 500 miles later this happens.
Old 11-25-2008, 09:23 PM   #17
Greeny's Avatar
Quote:
Stop taking your car there. find a reliable shop, or do it your self and look at the issues i stated in my original post.
Old 11-25-2008, 09:24 PM   #18
Greeny's Avatar
Quote:
covered this issue about 11ndy billion times down there..
__________________
Old 11-26-2008, 01:34 AM   #19
If it happened after brake job it is probably the dust shield. It is not going to scrape constantly because it flexes with the heat.
Grab a long screw driver and "poke" it outward as much as possible. It doesn't hurt to try as it cost zero dollars.
Donald199 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
