ABS sensor is stuck. Help?
My passenger side ABS sensor is stuck in the steering knuckle. How do I get this thing out? I have removed the bolt holding it in and this thing wont budge. My drivers side came right out.
Also it appears there is a little slit to but a flathead screwdriver on it to tap it loose. Tried that, and just whaled on it with a hammer and nothing.
I then tried tapping it out from the wheel hub side after removing my CV axle, nothing happened. The screw driver sunk into the plastic a bit. So who knows...I may have destroyed the sensor already but I am not sure.
Anyone else have any tips? I think this damn thing is just rusted right in.
If worse comes to worse and I have to smash it out with a sledge, how expensive are these and how do I go about replacing it? It looks like one continuous wire without a connector.....
Thanks guys
Thanks guys
Oh my god this is so flipping irritating. I managed to pound a screwdriver inbetween the metal plate and the steering knuckle. I tried prying it, but I broke the tips off of 3 screwdrivers already.
I said **** it and put a socket extender on the ABS sensor and started smashing it, the damn thing still wont budge!! OMFG. I am gonna try smashing it out with a sledge hammer now and if that doesn't do it I don't know what the **** I will do. I will probably have the drill the ****ing sensor.
Well, finally got it out. My drivers side was no problem at all. The passengers side took 12 HEAVY hits with a 10lb sledge hammer. That thing was in there good.
PS I removed it because I had to get the steering knuckle off to do my bearings.
Good luck and hopefully they are still both working.
Too late now I guess..... The drivers side should work fine. The passengers side, I haven't tested it yet, but I would be surprised if it still works because I pretty much flattened the sensor element.
Oh well, I guess my car no longer has ABS.....
Yup, no ABS for me anymore either. They want $246 for one here in Can.
My car is a 1996 built in June/ 1995. ABS SENSORS ON EBAY ARE SAYING THEY ARE ONLY GOOD FOR JULY/1996 Aand up built cars? Are there 2 different sensors between 95 & 96 builds?
A32s made in July of '96 are MY1997.
PM Maxima_Joe, see if he has any.
Wow, I love how some of my threads from ages ago get resurrected.
Anyway, I still haven't gotten a replacement yet. One thing I was wondering, will a front sensor from a 5th gen work? It seems front ABS sensors out of 5th gens are easily salvageable when people part out 5th's but most 4th gen sensors are seized into place.
It would be great if a 5th gen sensor works cause I see a lot more of them.
Anyone has a writeup on how to clean or test or replace the ABS sensor?
Where are the all the ABS sensor locate?
Seems like very hard to remove and repair. I have the ABS light ON and i want to fix it.
thanks
thanks
Once you figure out which wheel is having issues, check the fuses first to see if that could be your problem, then check the sensor on that wheel. Chances are more than not its the wheel sensor, which can be a royal PITA to get out.
Hope this helps.
Matt
my03maxima
04-29-2020 12:48 AM
RealityCheck
10-02-2015 06:34 PM
