Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-19-2008, 09:23 AM   #1
Idler Pulley or AC Pulley Bearing
Well, my car has suddenly developed the constant whine from the engine bay. I have more or less isolated the problem, and I am pretty sure it is the ac bearing or idler pulley. The only reason I think it might be the idler pulley because the noise will only go away for alittle bit, weither I turn the ac on or off. After a few minutes, I can turn the ac back on and the noise will go away again for a few minutes. Does this sound familiar to anyone?
KrayolaSE-L is offline   Reply With Quote
Old 11-19-2008, 10:13 AM   #2
Send a message via AIM to wirelessdude04 Send a message via Yahoo to wirelessdude04
ac compresser probably
__________________
Under Major Overhaul
Team All Out Nissan: President
Visit us @ teamalloutnissan.com
wirelessdude04 is offline   Reply With Quote
Old 11-19-2008, 11:57 AM   #3
Yes, it sounds familiar and no I personally cannot tell you which it is based on what you've explained.
A bad AC pulley bearing may make noise whether the AC is on or off (been there done that). Noise from a bad tensioner pulley may make noise intermittently.
1. Loosen the tensioner.
2. Spin the tensioner pulley by hand... Noisey or rough? If yes, you’re done. If no move on to #3.
3. Spin the AC pulley by hand... Noisey or rough? If yes, you’re done. If no move on to #4.
4. Go get the appropriate belt to bypass the AC compressor and run it... Noisey? If yes, it’s the tensioner. If no, it’s the AC pulley.
__________________
Turbobink is online now   Reply With Quote
Old 11-19-2008, 12:17 PM   #4
Send a message via AIM to njmaxseltd
Do the screwdrive to the ear test. Put one end on each device and the other (handle) in your ear. The device that transmitts the most noise is the culprit.
Easy test, takes 2 minutes and a long screwdrive or rod.
__________________
njmaxseltd is offline   Reply With Quote
Old 11-19-2008, 12:29 PM   #5
Im going to try all of those when I get home. And I forgot to mention, not sure if it matters or not, I have a UDP. But like I said, this noise just started and and I've had the udp for almost 6 months now. The power steering belt is a smaller size but the main acc belt is factory. But Im going to try all of those to see if I can isolate the problem.
Old 12-29-2008, 07:36 AM   #6
I have a similar problem but the noise is muffled only wen I turn the front defogger on.
When I turn the blower off or direct the blower to the vents ,the wining/ rattling noise come back
CEASE225 is offline   Reply With Quote
Old 12-29-2008, 01:29 PM   #7
dammit
97SEdriver's Avatar
I would guess you have something actually in your vents like a leaf or something. the vents and defogger probably hit the leaf different ways, making one way louder than the other.
97SEdriver is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
