Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-17-2008, 08:10 PM   #1
OK what the heck is going on?
Not sure what to search for since it's hard to describe, but here goes....Saturday I was driving my '99 Maxima w/156K miles on it, I was pulling away from a stoplight at normal, slow and steady speed, the car started to hesitate and seemed like the engine vibrated as if it was going to stall....This only happened for about 3 or 4 seconds or so, the Check Engine light flashed for a second, then shut itself off and the car was running fine the rest of the day, maybe 15-20 miles after the initial problem.
Drove about 15 miles on Sunday, no problems or recreation of the symptoms. Drove again today, another 15 or 20 miles, again at a stoplight, engine vibrated/hesitated again, noticed the RPM's drop to about 200 or so, then went back to normal 500-600 idle RPM's...again, this hesitation/vibration problem only lasted 2 or 3 seconds. No engine light this time though. Just went out and drove another 8 or so miles and no issues.
The car is running fine otherwise, getting decent mpg's and I always use 93 octane gas. Any ideas?
Crusher47 is offline   Reply With Quote
Old 11-17-2008, 08:17 PM   #2
Forgot to add, no weird noises or smells, car starts and runs fine otherwise. Car is completely stock. Thanks!!
Old 11-17-2008, 08:20 PM   #3
Fuel filter?
When's the last time you replaced the fuel filter? Look for obvious stuff like that which would affect the engine to that degree.
larso1 is offline   Reply With Quote
Old 11-17-2008, 08:21 PM   #4
Send a message via AIM to chillin014
Please dont title your thread so ridiculously vague.
search
hesitation during acceleration
Severe hesitation... thought it was gas, but now...
Power surge and hesitation on accelleration? New symptom..
chillin014 is online now   Reply With Quote
Old 11-17-2008, 08:41 PM   #5
I'm the 3rd. owner, not sure when the fuel filter was replaced, but will replace it. Thanks for the tips everyone and sorry about the thread title, noob mistake
Old 11-17-2008, 08:43 PM   #6
Send a message via AIM to shadyonedeath
Ground your MAF.
Did it stall at night?
shadyonedeath is offline   Reply With Quote
Old 11-17-2008, 09:03 PM   #7
Is It a 3rd gen,If so check for the MAF or the EFI wires and If have not yet done the fuel filter do it now. Check the air filter while your at It.
vqmaxman is offline   Reply With Quote
Old 11-17-2008, 09:36 PM   #8
sounds like MAF. i jsut had to replace mine. It wasnt a maxima but sounds like the same exact symptoms.
__________________
[Lou]
ThreePointO is online now   Reply With Quote
Old 11-17-2008, 10:09 PM   #9
Your car is most likely misfiring...the 99's are notorious for having coilpacks fail. Check the stickies on how to test each one individually, and replace accordingly.
__________________
1999 Super Black SE 5MT '00VI|VAFC-II|Fed Spec Conversion|Cattman Y|Budget B|HKS Rear Section|Stillen Hi-Flow Intake
OBX STS|18" Mille Miglia Evo 5s|Stillen FSTB|Progress RSB|Intrax Springs|KYB AGX Struts|AE Pedals+350Z Dead Pedal
Escort Passport 8500 Hardwired|Red/Clear Tails|Clear Bumper Lights|35%/25% Tint|Nismo Shift Knob|I30 Leather E-Brake+Autodim Mirror
Exedy Stage II Clutch|I30 VLSD Transmission
99BlackMaxMS is online now   Reply With Quote
Old 11-17-2008, 10:11 PM   #10
Thanks again guys...sorry, more noob omissions....I already replaced all 6 coil packs, spark plugs and knock sensor less than 6 months ago. Also the air filter was replaced about 2 months ago..... I will get the fuel filter replaced and clean the MAF and see what happens.
Old 11-17-2008, 10:38 PM   #11
The car that is having problems Is a 3rd gen right?
Old 11-17-2008, 11:00 PM   #12
Send a message via AIM to nyc96max
Quote:
dude he stated 99 in 1st post
__________________
WTB : Vortech supercharger kit
nyc96max is offline   Reply With Quote
Old 11-18-2008, 12:00 PM   #13
Replaced the fuel filter...the gas coming thru it was black and dirty....took the car for a quick 1 or 2 mile spin and it seems to be running much better. I'm going to clean the MAF too just in case over the weekend. I'll post again if the problem returns. Thanks for all your help, this board rocks!
Old 11-18-2008, 03:13 PM   #14
January 20th, 2009
ROCKART's Avatar
Send a message via AIM to ROCKART
flashing CEL is most def a failing coilpack
u said u replaced them 6 months ago, but where did you get them from?
ROCKART is offline   Reply With Quote
Old 11-18-2008, 08:48 PM   #15
+1 for a coil pack failing.
I've experienced a similar problem with my sister's max which is a 99. The car itself does not act up when you are driving, but when ever it idles or at a stoplight, the engine shacks and the cel flashes.
When ever the cel flashes, there is something wrong with your engine, most likely an electrical problem.
darklegend06 is offline   Reply With Quote
Old 11-18-2008, 10:53 PM   #16
The CEL only flashed for a second and never came back on again. Car is running fine now, you guys still think it could be a bad coil? I got 3 of them from Autozone and the other 3 from the dealership.
Old 11-19-2008, 06:40 PM   #17
You guys are good!! Car started running like crap again and the CEL flashed for a few seconds. Went to Autozone to read the code, Cylinder 6 misfire! The light is on solid now. Will do a search to find which one exactly is cylinder 6 and will buy another coil. I'll let y'all know if it is an Autozone or Nissan OEM coil.
Thanks again fellas!
Old 11-20-2008, 09:58 AM   #18
Pulled the coil and plug this morning. Plug still looks good. Coil is an Autozone/Duralast product. Replaced it with a Hanshin labeled Nissan OEM coil I had laying around from last time. Only drove 8 miles to work, but the car is running better. We'll see what happens when I drive it to lunch in a few minutes.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
