Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-17-2008, 07:47 AM   #1
FYI Guys... It's The VC Gasket Not The RMS...
This is just some advice... it's not a diagnosis... all I'm saying here is if you think you've got a bad RMS you actually might not.
I had my RMS replaced last May.
I knew my VC gaskets were getting to the point where they needed to be replaced but I was putting off pulling the upper. However, lately the typical RMS leak appeared... typical meaning at the typical location.
Needless to say, I was a bit pissed having paid ~$800 about 6 months ago for the RMS and now seeing it go bad, but the leak was getting so bad I could watch it drip when the car was running.
... back the shop.
Turned out that the RMS is fine... it was my rear VC gasket and it was friggin pouring oil. I was under the car and watched it. It was a bit alarming the amount of oil that was escaping.
Apparently, with the rear VC gasket leak, oil can and does find it's way b/t the block and the tranny exiting right at the same spot as it would if the RMS had failed. Even with the removal of the inspection plate at the flywheel, it still looks like it's the RMS but it ain't. My shop actually had to insert a scope to make sure what was leaking and what wasn't.
Just an FYI for those who are thinking they need a new RMS.
__________________
Turbobink is offline   Reply With Quote
Old 11-17-2008, 10:13 AM   #2
Good thread. How hard is it to determine it a VC gasket issue? Meaning where does one start looking for the leak.. the last time I went under the car searching for the leak, it resulted in a stiff neck for me and my neck was sore for a week.
Love_00_Max is offline   Reply With Quote
Old 11-17-2008, 10:33 AM   #3
oem ftw!
CRiME's Avatar
Quote:
Well, what I did to confirm that the rear VC gasket was the source of my leak was reach behind the UIM and feel the VC (particularly the mating point where the gasket sits, and the left corner of the cover). When I pulled my hand back out, it was covered in fresh oil! Probably not the greatest method, but it worked for me
The best thing about that leak was that it resulted in the 00VI. Gave me a good reason to pull the UIM and trash it
__________________
Originally Posted by dashan
EnervinE,
You might be right. I should not speak at all. But I could fcuk your axshole, so be prepared.
Originally Posted by shaft369
hey man whoever posted this if these guys hurt your feelings, just go out and buy a altima and never come back here...lol...peace
Originally Posted by myschyf
the tornado? I heard it didnt work........
well hee-yuck jethro, brand spanked new?? gawl-dang, i needs me some of that there zymol, tarnation!!!!!
Originally Posted by CanadianKnicksFan
huh.....where you guys getting this info from? That link takes me to something that says "You've been Rick Rolled"
Worst question ever asked on maxima.org:
1 Year Old Thread Bumped by bluebriscoe
So do you disconnect the battery then the air bag or vise versa?
CRiME is offline   Reply With Quote
Old 11-17-2008, 11:36 AM   #4
Let's build something!
oldngivout's Avatar
Here's picture of the rear of the engine. RH corner of the valve cover is usually where it starts. You can see the trail of oil if you look up at the rear of the engine from underneath the car.
oldngivout is offline   Reply With Quote
Old 11-17-2008, 03:46 PM   #5
Maintenance Monster
I've got the tell-tale signs of a RMS leak, so I'll check this out.
Did you also notice excess oil consumption? On mine I don't get drops on the pavement at all. With an RMS leak I would expect to see that.
Dave
dgeesaman is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
