Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-16-2008, 10:13 PM   #1
Send a message via AIM to rockfordmaxII
Reverse Lamp switch in trans, help!
Ok, through rebuilding process, this little switch has been misplaced, i had it on the shaft but lost it throughout reinstallation and what not. Soo, i need to figure out where, if anywhere, i can pick it up. It is the Movable plate assembly, basically just a little switch that rocks back and forth on a ball bearing.
If anyone can help me out id greatly appreciate it.
__________________
Blue 95, 5-speed, tokico blues, 20% all around, HID's, Enkei J10's, Rust-free rad support, Hotshot Headers, Mitsubishi resonator, Custom header back with cat-delete, Cold Fusion 50-shot with heater, Custom intake for nitrous, topped off with a couple gauges on the pillar. Poly filled motor mounts, Rebuilt 5-speed, xtd stage 3 clutch.
13.453 at 106.6 on a 75 shot (mad wheel spin)
13.6 on a 50 shot
rockfordmaxII is offline   Reply With Quote
Old 11-16-2008, 10:20 PM   #2
Let's build something!
oldngivout's Avatar
Perhaps someone has a used one they could send you. It comes as a set along with the electrical portion when purchased at the dealer. But the little part you're needing is usually OK and doesn't need replacing, so maybe you can get lucky. If not, just buy the whole thing, you will probably need it soon anyhow.
oldngivout is offline   Reply With Quote
Old 11-17-2008, 08:27 AM   #3
i dont see why i would need the whole thing sometime soon when it worked just fine before...im selling the car and need to fix this so that its one less thing that is wrong with the car. i think i will get in touch with the dealer and see if they can help me out at all, otherwise ill post something in the wanted forum
__________________
13.6 on a 50 shot
Old 11-17-2008, 09:13 AM   #4
The part is actually a vital part. If the ECU does not sense voltage across that circuit, it will throw you a part/neutral code. So basically a cel light will be on.
darklegend06 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
