The other one, came in a beat up old box, the guy told me it was exactly the same just that they throw it around the shelves a lot.
This one is not an SKF bearing, it is:
NSK 428WD08jb Japan.
As you can see, obviously this one is a bit different. The actual ball bearings inside are not exposed like the SKF Korean bearing. This one is loaded with tons of grease inside. When I pull it apart, it doesn't seem as tight as the SKF, I can easilly pull the inner race right off and put it back in. Although, neither bearing appears to have play in it while it is together. This bearing looks like it was taken out of the box and greased up, but it doesn't appear that it was really used. At least I don't think so.
When I spin this one, it stops immediately unlike the other one but still seems pretty smooth.
My questions are:
1.) Are both of these part numbers for the Maxima? How can I find specific information about those numbers on the bearings other than "FW119" being printed on the box?
2.)Should I take that NSK bearing back and wait another week until they can get in another SKF? Or should I take them both back and wait until they can get in two brand new NSK's?
3.)Bearing grease...the SKF came with some grease in it, but it doesn't look like much. Should I purchase some grease and heavilly grease it up like the NSK bearing I have is?
4.) Any consequinces for the ball bearings being exposed in the SKF vs. sealed in the NSK?
Thanks a bunch guys, I am trying to get this job done this weekend, so any quick help would be MUCH appreciated!
