Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-15-2008, 11:31 AM   #1
Send a message via AIM to shadyonedeath
Anyone else have uneven head lights?
My driver headlight does NOT sit flush with the grill/hood because it has to be adjusted to the left so much just to hit the beam patteren directly ahead. I'd say its 1 inch sticking on where it meets the grill.
Sucks really. It was like this with before and after the 9007 mod.
At first i thought the front end might have been in an accident but there is no sigh of any damage except from a what looks to be repainted radiator support bar. Car looks clean, i've been in and out of it and hell, if it WAS in a accident, the body shop did a hell of a job making it clueless.
shadyonedeath is online now   Reply With Quote
Old 11-15-2008, 11:35 AM   #2
Send a message via Yahoo to 2muchbass
i do but its because of numerous minor accidents
2muchbass is offline   Reply With Quote
Old 11-15-2008, 12:01 PM   #3
Old 11-15-2008, 12:40 PM   #4
4th Gen Parts King
Maxima_Joe's Avatar
There's a clip that secures the adjustment rod to the the headlight. It looks like it isn't clipped to the headlight anymore.
__________________
If you need a 4th gen part contact me:
I do not ship large parts such as
engines, transmissions, seats, hoods, fenders, bumpers, doors or trunk lids due to the hassle.
Maxima_Joe is offline   Reply With Quote
Old 11-15-2008, 12:40 PM   #5
Thats the main reason I gave up on the 9004 to 9007 conversion. I have a 98 SE with plastic lens maybe other years have a different housing. Just convert back to the 9004's Go high wattage if you need more light than the silverstars can put out.
Mods NOT worth doing (9004 to 9007 conversion)
Nopike is online now   Reply With Quote
Old 11-15-2008, 12:51 PM   #6
I just noticed that you said that the problem was there before the 9007 mod. When I installed the 9007's I had to make extreme adjustment to get them aimed with the 9004s properly aimed my housings sit flush like they should.
Old 11-15-2008, 01:30 PM   #7
Quote:
Not here. My 9004s were adjusted the same way. The previous owner had it like this with 9004's and it was still adjusted severely. I just tweaked it a little to get them aligned "Perfect".
9004/9007 swap had nothing to do with it.
Quote:
Ill check that out.
Old 11-15-2008, 03:34 PM   #8
i think it simply needs aiming. Try turning one of those nobs that will have it turn inwards to the grille untile it flushes like the passenger side.
__________________
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Jan-2009
Snypa is offline   Reply With Quote
Old 11-15-2008, 04:12 PM   #9
Thats one of the things i look for when buying a car. If i saw that, i would of walked away from it.
__________________
Matt Blehm's 12.6" 2 piece slotted rotors|Hawk HPS pads|Goodridge SS lines|Stillen intake|UR crank pulley
Cattman headers|y-pipe|catback|Exhaust cutout|Stillen aluminum flywheel
ES LCA's|ES subframe,engine mounts|ES rear trailing arms|VLSD|Matt Blehm grounding kit|Progress coilovers
Stillen RSB FSTB RSTB|Rear beam bent to 0° toe|Stillen oil cooler|cross brace subframe connectors
18" HP wheels|DIY oil catch can
tbergma1 is offline   Reply With Quote
Old 11-15-2008, 04:27 PM   #10
Quote:
How it is right now, its aimed perfectly. If its flush with the grill, it will point towards the passenger beam.
Old 11-15-2008, 08:24 PM   #11
trand71's Avatar
Send a message via Yahoo to trand71
My girlfriend has a misaligned headlight, but i think that's mainly due to the doctor. But i really don't mind realigning them at night.
__________________
UDP, K&N CAI, Frankenstein Budget Y pipe, Grounding kit, Voltage regulator,30,000k HID, PIAA Yellow conversion foglights.
trand71 is offline   Reply With Quote
Old 11-16-2008, 03:04 PM   #12
Send a message via AIM to AndrewR2442
Why don't you try and find a happy medium b/t the two beams.... ie. aim your driver beam more to the right and your passenger more to the right. Then it won't be nearly as noticeable.
My car has been in a few minor front end impacts so my headlights have a few washers in-between the mounts and the headlights to get them close to factory. Maybe you should just add some washers on your passenger side?
AndrewR2442 is online now   Reply With Quote
Old 11-16-2008, 04:35 PM   #13
I'm nutty for Nissans
JSutter's Avatar
Send a message via AIM to JSutter
Its just the way it is. There will always be some misalignment. Many other cars from have adjusters IN the lights, they move the reflector and bulb within the housing. We unfortunately got stuck with some old ass design.
__________________
-Jon
Daily driver: 98 Maxima SE ... Best E/T: 14.9, Best trap: 95
06 Drag car: 91 Sentra SE-R ... Best E/T: 13.1, Best trap: 110, 2.2 60' R.I.P.
09? Drag car: 94 Sentra E ... In the making
JSutter is offline   Reply With Quote
Old 11-16-2008, 07:05 PM   #14
good idea. thanks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
