Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-18-2008, 10:57 AM   #41
The Original CF Maxima
Flava_24/7's Avatar
Quote:
Originally Posted by RuSSiAnMax415 View Post
it was stuck on the crank shaft! The rest of it was solidly stuck. and i put visegrips and tried pushing it off with a screw driver....nothin worked...so i ended up tappping into it..
Tapping into the nut or pulley?
__________________
Flava_24/7 is offline   Reply With Quote
Old 11-18-2008, 11:01 AM   #42
The same thing happen to my brother pulley, he had the ebay OBX one.
mmg23max is offline   Reply With Quote
Old 11-18-2008, 11:07 AM   #43
Send a message via ICQ to DaEnigma Send a message via AIM to DaEnigma Send a message via MSN to DaEnigma Send a message via Yahoo to DaEnigma
I have had my UR UDP on since ~4000k on the car (I purchased it new). Not a single problem what so ever...
__________________
forums.maxima.org Member #118
Mods? Look in my profile.
Oh and like you've heard before...
"Enjoy The Ride"
DaEnigma is offline   Reply With Quote
Old 11-18-2008, 11:15 AM   #44
Send a message via AIM to The Russian Send a message via Yahoo to The Russian
Quote:
Originally Posted by Flava_24/7 View Post
But the remaining piece of the UDP will come off once the nut is removed....
so let me explain what happened....i didnt even see the cracks... i just heard the pulley vibrating...so i loostened the tensioner, looseneed belts, and took the bolt out of the udp. The pulley just fell off. Pic in post #1. Then watever was left of the pulley...center part.....was stuck on the crankshaft with no bolt there at all....so i put visegrips onto watever was left and tried prying it off...it didn't work...did some research, and asked some guys what my best bet is......They said saw into it and use a gear puller or tap it...so i tappped it...and then pulled it out...and it finally came out...then just put everything back together, and car ran better then when it did w the udp installed.
__________________
1999 SE 5SPD~WITH SOME BOLT ON's HERE AND THERE....
1999 GXE AUTO~LOWERED, EXHAUST...
The Russian is offline   Reply With Quote
Old 11-18-2008, 11:29 AM   #45
I'm needing a caw
Jeff92se's Avatar
Did you ever specify which pos brand you put on?
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is online now   Reply With Quote
Old 11-18-2008, 11:36 AM   #46
Quote:
This guy blew up his motor in his 4th gen, and gave it to another friend. The other friend fully parted the car out and asked me if i wanted the udp. I thought it would increase power and make a difference. Guess not. Oh well...From what I understand the brand was probably something cheap like obx or something. Regardless, It doesnt add any power or make a difference. So why get it? Ebay or UR ?
__________________
Old 11-18-2008, 11:42 AM   #47
I'm needing a caw
Jeff92se's Avatar
Well the UR one wouldn't have broken as long as one installed it correctly.
BTW. I installed one on my VE. I noticed the increased ability to rev faster. So IMHO, it worked for me.
__________________
Sold Jan 14, 2006'
Mod list:
Old 11-18-2008, 12:10 PM   #48
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
you can't really argue the gains, however minimal, of a properly designed udp since it does not actually make power, it just reduces drag and rotational mass freeing up power to the wheels.
the reason your car ran better without it is a) the pulley you used was poorly designed/manufactured (most likely) or b) psychological.
it has long been known that udp's were not a very worthwhile upgrade to our cars and are generally reserved for those wanting to squeeze every last pony out of the car. i believe it is mostly to do with there not being much weight to shed vs. the oem pulley, but i could be wrong. just going from memory.
__________________
Your source for premium Maxima/I30 parts!
My CarDomain
Houston Maximas
BLACKonBLACK98 is online now   Reply With Quote
Old 11-18-2008, 03:01 PM   #49
Send a message via Yahoo to Madmax66
100K+ on my UR UDP and smooth sailing!
Madmax66 is offline   Reply With Quote
Old 11-19-2008, 03:30 PM   #50
00vi'dvq30devq354.5genftw
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
The only reason I'd replace mine is for weight reduction. I never realized how heavy that damn pulley was until my 3.5 swap.
ajcool2 is offline   Reply With Quote
Old 11-19-2008, 03:54 PM   #51
u got a 3.5 swap??????? on the "dark pheonix??" and auto ? wowww sweet run im just about ready to be doing my swap too! got any info or pix i could read up on? altho "mastercater" can recognize each bolt and how the swap works...i want to check it out and read up some more...!
edit: just saw ur sig and it said rwhp lol......what does ur max run w the 3.5?
__________________
Old 11-20-2008, 04:33 AM   #52
wow... that sucks, never had issues with my Unorthodox pulley
SleepyMax1 is offline   Reply With Quote
Old 11-20-2008, 08:00 AM   #53
ajcool2's Avatar
Haha I'm doing it for my girls max. I got the car dirt cheap and it needed a motor so she wanted to put a 3.5 in it. I have a full progress thread in the all motor section. I'm moving slow a hell with it though since its cold now and I dont want to forget anything. I'm at the point of dropping it back in once I get the new headers on. Beleive me I never thought I would ever do something like this but the car and motor was so cheap I couldnt pass it up.
VQ35 Swap Progress Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
