electrical problem (hazard, rdefrost, and climate buttons)
So my hazard and rear defrost havent worked in about two years. I tried switching them with ones from the wrecker (about 5 times) no luck. The led in the rear defrost does work which is weird. The climate control sometimes flickers, or dims. Yesterday the light behind the fan control **** went out, but only that, once I tapped it a few times it came back on. I took everything apart and the wires and connections look fine. Anyone else have this happen to them? Or can help?
This sounds like it's probably three seperate problems and probably have three seperate causes. Need to fix one at a time, which is most important? So the defroster does not work or just the LED for it? Try to give more info on each problem it will help. They don't appear to be unfixable problems.
mikeg75
11-30-2015 05:12 PM
