Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-14-2008, 11:40 PM   #41
Send a message via AIM to AndrewR2442
+1 ^ that would help me out so much! : The 3 relay wiring is very confusing.
I thought i had this figured out w/just 2 relays and a diode. Nope...
Are 9004 bulb maximas ground shared and positive switched? Or the other way around
AndrewR2442 is offline   Reply With Quote
Old 11-15-2008, 12:44 AM   #42
According to the database thread, it's common ground and switched power.
__________________
1996 Maxima GXE "My boy blue"
Alpines Type-Rs |Harmon Kardon DP-US1|FSTB|Leather/Heated Seats|ADDCO RSB|Sony Xplod 12" sub|Spoiler|5th Gen 17's | Rainbow SLCs & Audison SRx2 | Custom Red Clears| Viper 771
Need to be installed:
B&M Tranny cooler |
To be:
Illuminas + Progress | Y-pipe | Tint | R34 TSX HL
Coolsaber57 is offline   Reply With Quote
Old 11-15-2008, 08:19 PM   #43
Quote:
Originally Posted by Coolsaber57 View Post
Can you draw a 3 relay scenario out? I can't seem to figure it out.
bump?
__________________
B&M Tranny cooler |
To be:
Old 11-16-2008, 03:44 PM   #44
IF you follow this exactly, it will work perfectly. Our cars are deffinately positive switched b/c someone tried wiring our cars w/a negative switched harness and it didn't work.
If you really want to understand it... then read this following quote while looking at the diagram.
"when the lows are on, both R1 and R2 are closed and power the ballasts. When we switch to high beam, there is a short moment when BOTH low and high beam wire will get powered (this is when we flash). In fact it is only when we completely switch to high beam that the power to lows is lost but when we switch to high beam we always first go through this little moment where both low and high wire are powered. Therefore providing R2 was closed before by the low beam wire, the little moment where both low and high are on allows to keep R2 closed and allows the high beam wire to keep it closed after the low is powered off"
Old 11-16-2008, 04:32 PM   #45
Ok guys, I THINK i figured it out:
Short Version: Replace a diode with a relay and connect the battery to the low trigger wire.
Long Version:
-Parking light switch must be turned on for the lows to come on. This is done to prevent your lows coming on when you just want to flash someone during the daytime (i.e. warning people to slow down because there is a police car around the next bend)
-When the highs come on, it hits a relay, which takes power from the battery and gives it to the low beams' trigger wire. That power is passed through the parking switch relay to the low beam relay, which closes to power the HID ballasts via the battery.
-If you "flash" someone, the power will still hit the "high beam" relay and pass it to the low beam trigger wire, but because the parking light relay is open, the circuit will not be complete, and therefore the lows will not go on.
Can someone please check my work and see if I'm missing something?
__________________
B&M Tranny cooler |
To be:
Old 11-17-2008, 04:07 PM   #46
Bump, what do you guys think?
Think it'll work? Will it "blink"?
__________________
B&M Tranny cooler |
To be:
Old 11-17-2008, 08:24 PM   #47
Send a message via AIM to speed racer
You should use the side light as a trigger to turn the low beams on. Use a relay and connect the power to the battery terminal. You will be able to flash your high beams with out the low beams going off.
speed racer is offline   Reply With Quote
Old 11-26-2008, 11:06 AM   #48
I'm trying to use a capacitor to keep my low's from flickering... what size do i need?
I read i needed 2200uF or 4700uF for a fourth of a second to a half of a second.
BUT THE CAPS ARE HUGE. They're thick as big as a roll of nickels.
Does anyone know if this is overkill? Should i use the 2.2uF caps that are 1/4" thick?
Old 11-26-2008, 11:39 AM   #49
This is what I came up with. I like the R34 headlights, but of course he beam pattern sucks. So I decided to do quad HID reflectors:
- R34 chrome headlights
- TSX projectors for low beans
- FX bi-xenon projectors for quad low beams + high beams
- Clear lenses for the FX projectors (cut line/color mod)
- 4 E46 replica shrouds (for 2.5" lenses)
- 2 slim balasts D2S HID kits (4300K for best visibility)
- 2 9004 to HID wiring harnesses
I bought 2 sets of headlights (TSX and FX) off ebay. The FX clear lenses, E46 replica shrouds and wiring harnesses came from Retrofit Source. They cut me a really good deal. The HID kits were from the group deal from Liuspeed.
Here are pics of the completed headlights:
http://hidillusionz.blogspot.com/200...setup-hid.html
To get the projectors to fit, we put the TSX projectors on the inside and the FX bi-xenon projectors on the outside. They are getting installed this weekend. I do have to cut about 1" into the frame next to the radiator to get clearance for the inner projectors to fit.
__________________
97' Maxima GXE
00' Miata(former CS autocrosser, sold)
86' Mustang SVO(newer GS autocrosser, sold)
04' G35 6-MT Coupe (aka POS re-branded Nissan, sold)
79' Porsche 911 S/C
02' Porsche 911 Carrera
Loren00Miata is offline   Reply With Quote
Old 11-26-2008, 11:52 AM   #50
those R34's are bad ***!!! How much are they gonna run me?
__________________
THE MAX
tigersharkdude is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
