Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-10-2008, 08:16 AM   #1
dammit
97SEdriver's Avatar
will a dead battery possibly cause a car to stall at low rpm's
Today my car wouldn't start, I jumped it, it fired up and I left.
2 or 3 times on the way to work, it sort of flickered and died for a moment when I was easing out the clutch to start going in traffic.
Once I got going, it was fine, drove 18 miles, so I'd be surprised if it was the alternator.
When I got to work, I turned it off and then tried to restart it, battery was still dead and it wouldn't start.
I'm guessing the battery is toast, but it's been running fine lately, I didn't drive it over the weekend and it got cold, nothing else happened.
97SEdriver is offline   Reply With Quote
Old 11-10-2008, 08:49 AM   #2
Send a message via AIM to njmaxseltd
If the battery is that dead, then yes. Keep the rev's up so the alty can put out enough current to keep the car powered up.
Get the battery replaced asap.
__________________
njmaxseltd is offline   Reply With Quote
Old 11-11-2008, 03:08 PM   #3
dammit
97SEdriver's Avatar
UPDATE
the problem was the battery terminal itself had corroded a bit, then weakened, then broke. So, it was barely connected, and as such really wasn't getting any juice from the alternator.
Over the summer, I had to replace the bolt that keeps the terminal tight on the battery, I had to bend the terminal apart to accomplish this. I am guessing that bending, and the fact the car has 180k+ just weakened it to where it broke.
the terminal fell apart when I took it off the battery last night to get the battery tested.
It's probably been somewhat disconnected for a while, but sitting for two days was too much.
So, in conclusion, I bought a universal battery terminal, bought some heavy duty wire cutters, and hooked everthing back up.
It's started 3 times already and will most likely be fine, despite the auto parts store saying I had to replace the battery.....whatever....
Old 11-11-2008, 03:14 PM   #4
Send a message via AIM to MaxGordon7
no need to replace, you found the problem.
__________________
MaxGordon7 is offline   Reply With Quote
Old 11-11-2008, 03:20 PM   #5
MaXXiN
MaXiM@KiD's Avatar
Send a message via AIM to MaXiM@KiD
Like Max said you seem to have found the problem..sounded like the alternator in the OP but you found the culprit sounds like you should be a ok
__________________
MaXiM@KiD is offline   Reply With Quote
Old 11-12-2008, 09:38 PM   #6
dammit
97SEdriver's Avatar
I am going to keep updating this thread just to prove those guys at the auto parts store are....full of sh1t.....new battery...pshh..
let's see how long I can drive on my "shot" battery
Old 11-12-2008, 10:11 PM   #7
Send a message via AIM to f550maranello2
the alternator "should" be able to power the car w/o any problems.. basically what is happening is that the battery is probably putting a load on the alternator and that isnt good... i just finished my dads car the alternator went bad... i replaced it and turn the car on and immediately the new alternator gets hotter than the africa.. what do i find? the battery it self took out the alternator.
the battery ALWAYS showed 14.3 volts untill you started to run the car, all of a sudden it dropped to 10...
so in conclusion bad battery killed the starter... so change ur battery...
__________________
f550maranello2 is offline   Reply With Quote
Old 11-13-2008, 10:57 AM   #8
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
i agree. at least test the battery. and fwiw a new batt with 850CCAs is like 40 bucks. throw the old one on the work bench and use it for random tests and such that's i what i always end up doing.
Torgus is offline   Reply With Quote
Old 11-13-2008, 11:08 AM   #9
sonicrunch's Avatar
you are one dumb sob
sonicrunch is offline   Reply With Quote
Old 11-13-2008, 11:21 AM   #10
Send a message via MSN to Thanatos
I would like to know what type batt you are using that puts out 14.3 volts. Any auto parts store top of the line battery will range between 12.80-13.50 volts strait off the shelf. Your alt. will put out 14+ volts if in good working order or new. Anything above 14.6 from the alt. isnt good for the car unless you are in baja or have a high wattage system.
Thanatos is offline   Reply With Quote
Old 11-18-2008, 10:42 AM   #11
dammit
97SEdriver's Avatar
Quote:
no wai....
I'm wicked smaht....
and mai cah is still stahtin' and runnin'
Old 11-18-2008, 06:03 PM   #12
Super Member
TunerMaxima3000's Avatar
Quote:
Failed batterys can read higher surface charges than normal. Thats why when checking a battery you should always eliminate the surface charge.
The point I'm making is, bad batteries don't always read low voltage, sometimes they can read excessivly high voltage.
Obiously the battery he had was no good.
__________________
______________
<<'87 Z31 VG30ET (Hibernating) <> '97 A32 VQ30DE>>
TunerMaxima3000 is offline   Reply With Quote
Old 11-18-2008, 06:25 PM   #13
sorry my bad.. i meant 12... basically what was happening was that when i turned the car on with a new alternator it would drop to like 10... then i put another battery in with the car on it it showed 14 right away..
if you tested the battery with a dmm it showed 12...
__________________
Old 12-24-2008, 01:07 AM   #14
I thought a light on the dash showing the battery was a guarantee alternator problem. Do you mean to say, there were no battery light on to begin with?
FishyMan is online now   Reply With Quote
Old 12-30-2008, 03:43 PM   #15
Hobhob26's Avatar
Send a message via AIM to Hobhob26
i had the same problem with the battery terminal...and my battery was bad at the same time. it ended up fawking up my alternator within a month
Hobhob26 is offline   Reply With Quote
Old 12-31-2008, 12:39 PM   #16
dammit
97SEdriver's Avatar
Quote:
who are you asking?
I had no battery light
Old 12-31-2008, 12:40 PM   #17
dammit
97SEdriver's Avatar
Quote:
Originally Posted by 97SEdriver View Post
no wai....
my battery died finally, it died, then I got it tested, it just said recharge and test...it was ok for a few more days...then it got cold and it died again.
I just got a new battery, it's not been starting great, but I think my fuel filter needs to be changed and it's been snowing
Old 12-31-2008, 12:46 PM   #18
1 of few unmodded 4G Maxs
Wills98MaxSE's Avatar
if BOTH the brake and battery lights are on at the same time, then its a guaranteed alternator problem
__________________
- Will
1998 Maxima SE, Arctic White Pearl - relegated to spare car duty
2007 Jeep Commander Sport, Black - currently leased w/ < 1yr to go
Wills98MaxSE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
