Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-09-2008, 06:38 PM   #1
Give Gas, she stalls....help
It seems now that I have my CAI installed when I give it gas it stalls or wants to stall...it doesn't make sense. I know My Maf sensor is no good and I unplugged it, but why is the car stalling when I give it gas? Like reving it over 4000 rpm's. This is frustrating. I thougth it was the kinks in the hoses but I fixed that and now it still stalls....any help would be greatly appreciated. Thanks in advance
__________________
Bassbreaker
Bassbreaker is offline   Reply With Quote
Old 11-09-2008, 06:43 PM   #2
Send a message via AIM to 95max327
are you sure its not the maf? maybe not enough air and too much fuel? what other performance parts do you have? any fuel upgrades
95max327 is offline   Reply With Quote
Old 11-09-2008, 06:45 PM   #3
Quote:
i'm quite sure it isn't the maf cause I have it unplugged, and the only performance parts I have it the intake. I know there wouldn't be much power when the maf is unplugged, but when i give it gas it shouldn't stall...
__________________
Bassbreaker
Old 11-09-2008, 06:47 PM   #4
Quote:
also, when it do rev up a bit, there seems to be a backfireing sound of air coming back through the intake like a puffing sound...this is driving me...
__________________
Bassbreaker
Old 11-09-2008, 06:55 PM   #5
I don't know if this will help in any conclusions but yesterday when i tried it with the maf plugged in i gave it gas and i heard a "pop" sound. An injector wouldn't make a pop if it blew would it?
__________________
Bassbreaker
Old 11-09-2008, 08:12 PM   #6
hmm.. sounds like an air/fuel problem.. i had a s/c thunderbird and without my maf it would backfire out of the exhaust when i would rev it high in neutral and let off.. no maf would make the idle ****ty sometimes as well. i dont think an injector would make a popping sound. when did this problem start occuring? before you unpluged the maf, a little while after, long time after? does it misfire? at high R's in gear does it seem to bogg out or skip?
Old 11-09-2008, 08:15 PM   #7
backfiring is making me think it has something to do with too much fuel.. im assuming check engine light is on because the maf.. but have you scanned the car to see what other codes it may have thrown?
Old 11-09-2008, 08:29 PM   #8
how about picking up a new maf since you already need one and see if that solves the problem
__________________
00' SE 5 Speed/ Cattman Muffler/ Warpspeed Y/ 17º advance/ 5% tint all around/ 6000K HID's all around/ Hawk HPS's all around/ FSTB/ Alpine HU/ Alpine Type R speakers
Feldman is online now   Reply With Quote
Old 11-09-2008, 09:35 PM   #9
i advise the same thing^^^
__________________
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Jan-2009
Snypa is offline   Reply With Quote
Old 11-09-2008, 10:57 PM   #10
I had the same exact problem and once i bought a new MAF sensor that problem went away.
K.Hall is offline   Reply With Quote
Old 11-10-2008, 04:56 AM   #11
Quote:
Ok..I have another Maf off of a GXE I own and I can try that, but, it only started happening after the maf went really. I hooked up the CAI, busted the MAF, left it unplugged and it idled smoothly and she'll idle smoothly right now, but when i give it gas it'll sputter a bit and then stall. And when it do rev up for me, it doesn't rev higher than say 4000 or so and then it sounds like air is coming (puffing sound) back through the intake or somewhere in that area...
__________________
Bassbreaker
Old 11-10-2008, 05:04 AM   #12
also, I forgot to mention...there is no CEL, doesn't misfire really..it'll either rev up and make the puffing sound, or stall as soon as I put the gas down. Even if the maf IS bad, it should still be able to run shouldn't it? Maybe the CAI is giving to much AIR?
__________________
Bassbreaker
Old 11-10-2008, 05:26 AM   #13
Send a message via Yahoo to Madmax66
I just F'd my MAF and it acts VERY similarly however, it does not stall. I only get to about 2500 RPM before she sputters like mad. I AM getting 0304 code for KS which I had just replaced a few months ago....hoping a new MAF will cure.
Hopefully, the other MAF helps!
Madmax66 is offline   Reply With Quote
Old 11-10-2008, 05:37 AM   #14
thanks, i'll try it when i get home, but I don't know what to do if that isn't the problem...
__________________
Bassbreaker
Old 11-10-2008, 06:09 AM   #15
Send a message via AIM to njmaxseltd
Cliff notes for this thread:
Guy installs an intake, the maf goes bad, car runs poorly, verified the maf is bad, car still runs like crap, asked the org what to do knowing the maf is bad, car still runs like crap.
Seriously.... CHANGE THE MASS AIR FLOW SENSOR!
You were better off with the stock intake anyway, it gives the best throttle response.
njmaxseltd is online now   Reply With Quote
Old 11-10-2008, 06:18 AM   #16
i said I would change it when i got home.....i've also read posts about just cleaning it...maybe that would be the case...also, is a stock CAI gives the best throttle response...then why would people install a CAI
__________________
Bassbreaker
Old 11-10-2008, 07:30 AM   #17
Definatly the MAF. But try cleaning it first. I wasted money replacing it with an aftermarket one. I cleaned the original one, put it back in, and it ran perfectly.
gold96 is offline   Reply With Quote
Old 11-10-2008, 07:35 AM   #18
Quote:
will do, thnaks, btw, would I be able to get that maf cleaner at NAPA? I assume it only costs like 6 or 7 bucks?
Do you only just spray the plugs(male and female)?
I assume you do not spray at the resistor?
__________________
Bassbreaker
Old 11-10-2008, 07:57 AM   #19
most autoparts store.^^
__________________
Jan-2009
Old 11-10-2008, 08:51 AM   #20
also, is a stock intake gives the best throttle response...then why would people install a CAI
Looks and sound.
Old 11-10-2008, 10:41 AM   #21
i dont think the stock intake is the best though... there seems to be alot of restrictions. wouldnt a stillen or nismo be the best intake?
but to stay on topic.. try a diffrent maf, either way you need one right? if its not that then see what it does from there, im sure the maf will deffinatly do something.
__________________
1995 black on black SE 124,000
mods: Short throw shifter, stillen intake,
konig 18's wrapped in dunlop sport p901's
Old 11-10-2008, 11:11 AM   #22
yeah, you're right. In the least i'm hoping it will stay going when I plug the new maf in...i'll clean both of them too and see if that makes a difference
__________________
Bassbreaker
Old 11-10-2008, 05:02 PM   #23
On all cars I have worked on that I have accidentally left the MAF unplugged, they all usually sputter and/or stall when I give it gas. It makes sense, the engine can't detect that more air is going in, thus it can't appropriately control the mixture. The more gas you give it, the more you screw up the mixture thus the more likely you will stall it. I assume modern cars like the Maxima have some sort of an a/f map so it can generally know what to do based on the TPS, but it may not be accurate enough.
modenaf1 is offline   Reply With Quote
Old 11-10-2008, 08:35 PM   #24
Quote:
ahh..i see...well i'm going to clean and put on the new maf tomorrow morning...i'll let you know how it goes.
Just out of curiosity ( off topic ) does anyone know about how long it would take to drop a 5 speed out of a car...i have th step by step instructioons...but a time frame would be nice so I can do it before sundown
__________________
Bassbreaker
Old 11-10-2008, 08:51 PM   #25
u might also check for vaccum leaks..
fishforlife2007 is offline   Reply With Quote
Old 11-10-2008, 09:41 PM   #26
Send a message via AIM to maxkid123
its the maf..get a new one.
maxkid123 is offline   Reply With Quote
Old 11-10-2008, 11:21 PM   #27
KRRZ350's Avatar
Send a message via AIM to KRRZ350
check to make sure you didn't switch the maf and boost sensor connectors around, there the only connectors that are the same on the whole damn car and u probably removed both during the intake install.
KRRZ350 is offline   Reply With Quote
Old 11-11-2008, 12:33 PM   #28
Quote:
i only unplugged 2 plugs when i installed the intake...the IAT and the MAF, and they are not alike...i'll try and post pics
__________________
Bassbreaker
Old 11-11-2008, 12:35 PM   #29
