Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-09-2008, 09:28 AM   #1
Maintenance Monster
I keep burning out stock headlight bulbs
I'm using stock halogen 9004s, stock wattage.
The low beam filament to be partly or totally burns out every 6 months or so. I've always driven with my lights on, but for the first several years I owned/drove the car the bulbs were lasting much longer. Both the left and right side are burning out.
I've already:
- made *CERTAIN* the bulb does not get touched or dirtied
- checked that the headlight housings are not moist
- I don't see anything toasty around harnesses or plugs
I've heard about, but don't know much about
- checking the electrical circuits
- use anti-seize or dielectric grease
- replace the harnesses
I'd appreciate any advice on what to do next. It's not that bulbs cost a lot, but I've been pulled over 3! times in the past few years for a fix-it ticket and those are a PITA.
dgeesaman is offline   Reply With Quote
Old 11-09-2008, 12:12 PM   #2
Send a message via AIM to AndrewR2442
Are any other bulbs giving you problems as well?
Your alternator's voltage regulator could be wacked. You'd need to buy a multi-meter and check the voltage...ground/black and power/red. My battery is at 13.0 when i check the battery w/the car running.
AndrewR2442 is offline   Reply With Quote
Old 11-09-2008, 12:20 PM   #3
ThurzNite's Avatar
Send a message via ICQ to ThurzNite Send a message via AIM to ThurzNite Send a message via MSN to ThurzNite Send a message via Yahoo to ThurzNite
I think most headlight bulb failures are caused by 2 things: heat, and vibration. Vibration's obvious, and you can't do much about it. So let's tackle the heat issue. Energy comes in and gets converted into heat with light as a byproduct (or the other way around). What's the condition of the filament? If that's the part getting burnt out, try using higher quality bulbs (ebay bulbs are notorious for being cheaply made; and stay away from 'hyperwhite' bulbs, the blue bulb coating could be affecting the heat dissipation).
If the filament's ok, then how's the base of the bulb? I always use dielectric grease, even when I was running 100/130watt bulbs on stock harness, never had a problem, bright as heck with the proper beam pattern too. I stopped using those bulbs when I was doing a mountain run acceding 8000 ft in minimal time, and popped a bulb probably due to altitude pressure change and vibration. After that, I made my own upgraded wire harness using 12guage speakerwire, high temp sockets from ebay, and a 30amp relay.
http://cgi.ebay.com/ebaymotors/3-Pro...Q5fAccessories
Since then, I've converted to 9007, but don't do it. The output is brighter, but there's so much 'overspray' light that's wasted and affects other drivers. It's not blinding, but annoying to others.
Dr J
__________________
Dr J
ICQ/AIM/MSN/YIM/Google/Skype: ThurzNite
Email: ThurzNite@Yahoo.Com
MCC member #27
Show your support! Custom MAXIMA.ORG lanyards! Link
ThurzNite is offline   Reply With Quote
Old 11-09-2008, 01:47 PM   #4
Maintenance Monster
Thanks for the ideas. The only bulbs going out are the low beams on the headlights. You can see the filament is getting kinda scratchy looking if I catch it before it burns out completely.
I've been using the white Sylvanias ($20/2 at Advance Auto). I just today picked up some dielectric grease and I'll try that.
I don't believe my alternator is overcharging but I'll check it.
Old 11-09-2008, 02:17 PM   #5
Send a message via AIM to chillin014
I get the same thing, but its not really consistent. I have gone through more than an usual amount of bulbs in the past few years though. That is why I started buying the cheap bulbs (same as you get)...
chillin014 is offline   Reply With Quote
Old 11-09-2008, 08:28 PM   #6
Send a message via AIM to 95max327
have you checked your pig tails?? same thing happend to my old maxima something with a heat issue i changed out the pig tails and it worked fine. and they only cost like 7 bucks for both at advance auto
__________________
1995 black on black SE 124,000
mods: Short throw shifter, stillen intake,
konig 18's wrapped in dunlop sport p901's
95max327 is offline   Reply With Quote
Old 11-10-2008, 06:28 AM   #7
I actually have converted to 9007 so the harnesses arent but like 3 years old at most.
Old 11-19-2008, 04:32 PM   #8
water seal on right?
gregmaxin is offline   Reply With Quote
Old 11-19-2008, 08:07 PM   #9
ThurzNite's Avatar
Quote:
Water up there? Isn't there a squeegy piece that prevents water from getting into that area?
__________________
Dr J
MCC member #27
Old 11-19-2008, 08:09 PM   #10
I had that problem with a 97
4thGMax is offline   Reply With Quote
Old 11-20-2008, 04:02 AM   #11
Maintenance Monster
Yeah the water seal at the plug is good.
I polished the lenses (getting cloudy again) and added terminal grease to the connectors. The lights are definitely brighter, time will tell if it made a difference.
Dave
Old 11-20-2008, 08:56 AM   #12
maybe there is a shortage in the socket and only after it vibrates and shorts out the bulb blows ive had that happen to me on my 91 ser
10psigti is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
