Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 11-11-2008, 09:33 PM   #41
I was able to remove a Power Valve Actuator without taking of UIM, I didn't have time to replace the KS yet, but it seems that it's doable. My question is do I need to torque the PVA fasteners to a specific pressure and should I put anti-seize or another thing that makes the bolt stay tight no matter what, since it's sitting directly on the engine and undergoes constant vibration (and I think the way to remove the bolt after wards is to heat it up with the torch).
#2 on my pic
At least navigate me to the proper FSM section.
Yankel.v is offline   Reply With Quote
Old 11-13-2008, 09:40 AM   #42
Anyone has any ideas about my question?
Old 11-17-2008, 05:13 PM   #43
I can't answer your question, but curious to know if you changed the KS yet? Just checked my 99 codes and have the same problem.
rotary magic is offline   Reply With Quote
Old 11-18-2008, 08:46 AM   #44
Quote:
Man, it gave me amazing results. First of all who we are without our wives I still couldn't fit my hand in there, by my wife could.
Yesterday I finished this project, started up the car, in a couple of seconds check engine light went out by itself I didn't even have to reset my ECU. The same day I got my inspection without any problems.
Performance
The car is devil, now when the it is tuned up with right proportions for combustion for the gas I put in (93) I just have to top the gas pedal and right away I am getting squashed into the sit, no more hassle under 3000 RPM!!!
BTW my check engine light was for O2 sensors, but I think it's reading where wrong because without KS the car adjusts itself for the lowest octane gas, and I was putting higher that's why the oxygen sensors read it incorrect, because the KS itself doesn't trigger CE light, but I am telling you if you can do it it totally worth it
If you need any help I can guide you through. Some pictures would be helpful. BTW I hope your car is not calispec, right, because it is real pain in the neck.
Good luck, man.
Old 12-18-2008, 03:56 PM   #45
do you have to remove the exhuast manifold and valve cover?
pock3t is offline   Reply With Quote
Old 12-18-2008, 04:00 PM   #46
Send a message via Yahoo to Madmax66
Quote:
No. That's what garages THINK they have to do and why it's so expensive. Check the stickies...great pix and directions. But, if you look at prev posts here..pretty straight forward. You just need a small hand to pull the nut off..put back.
Madmax66 is offline   Reply With Quote
Old 12-18-2008, 07:09 PM   #47
Quote:
ohh.. b/c i jus got mine done today and they said they have to remove those and since they're removing those might as well change the gaskets.. lol.. the people that replaced it for me are family friend so only charged me 200$ so i guess its ok?
__________________
aw11 - sold
a32 - winter car/daily
sw20 - will buy in spring time
Old 12-19-2008, 02:28 AM   #48
good luck im having same trouble right now
__________________
aw11 - sold
Old 12-19-2008, 07:29 AM   #49
Where is the best place to get the KS?
loxety is offline   Reply With Quote
Old 12-19-2008, 08:27 AM   #50
Quote:
Ebay~ $60
I don't see what the trouble is. I have a GLE and it looks to be no problamo to get at. I need to change mine too but i'm waiting on it to arrive.
__________________
Bassbreaker
Bassbreaker is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
