gas leak/smell problem
I have this thing and it is annoying. When I bought the car (a year ago) there was gas smell in the cabin every time I used the heater (it was the winter time). I finally found where the gas leak was and replaced the hose. It was one of the short hoses that connects a couple of the pipes. A few months later I started having the gas smell again and I found that it was leaking from the same place again. I tightened the clamp and it was fixed. About a week ago the smell came back. Why does this keep coming back?
Another question I have is about a noise that wasn't there before. It sounds like a loud fuel pump. Its kinda like a very 'thin' whistle sound. Could it be from the vacuum lines that connect to the carbon canister? All of this started when I swapped my ECU to a 95 one (the car is a 96).
Thanks for your comments and help!
Don't think the problem is related to the ECU being replaced..
But your fuel pump shouldn't have to do with the leak/smell.
On the other hand, sounds like your fuel pump may be shot/dying. I had to replace one TWICE on a Maxima before.
No, its while its running and it's constantly there at any speed and RPM.
The same hose was leaking so I loosened it and moved the clamp a bit and tightened it again. The smell is gone for now. Why does it do that though?
I tried to listen carefully where the sound is coming from and its some where from the back for sure. It's the pump or some of the evap/vacuum lines that take the vapor back to the canister and tank. Is there a way to check if the pump is going bad?
I am still having the stupid leak guys! I need help!
I moved the clamp last week and tightened it again and this week its leaking again. What should I do? The hose is a year old.
And the sound is starting to annoy when the music is not on in the car.
change the hose and get clamps u can adjust with ur hand instead of a tool..i
Make sure you have fuel injection rated hoses. Parts store guys may have given you cheap coolant/power steering hoses that can't handle FI pressure or break down when they come in contact with fuel. Also consider getting some good FI hose clamps like the ones here: http://www.autobarn.net/iddifuincl.html
I thought about getting a smaller diameter hose too.
what should I look for when buying a good fuel line hose?
thanks guys!
I'd use fuel injection hose that meets SAE 30R9 standards, similar to this one: http://www.midwayautosupply.com/pm-3...mp-pi-502.aspx
I used these thermoid hoses on my old Z when I replaced all the FI hoses and never had a leak.
03-12-2020 12:06 AM
