My 95 GLE changes hard from 1st to second. I was just wondering if anyone had pics of where it was located so I can see if it's unplugged. It's really annoying and i'm afraid it's going to damage something. I'm quite sure there wasn't a DR Mod done previously either. Please Help!!
if im correct the drop resistor only limits the maximum rpm that the car can go to. i didnt think it would make shifting hard.
No.
Quote:
Unless you're experiencing extremely harsh shifts on every shift, the drop resistor is most likely fine. After you get some miles on them, the autos tend to give hard shifts from first to second, especially when cold. Change out the fluid if it's due, see if that helps.
As to the location, it is the only rectangular shaped item on the LH shock tower, mounted on the front of the tower with a single wiring connector going into it. No picture, I drive a 5spd.
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
ok, i have to get the cv axel seal replaced 1st, then i'll do a flush and replace the fluid.
