Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 10-23-2008, 10:39 PM   #1
Battery Help
Ok so the story goes like this. I was replacing my knock sensor the other day because it was faulty and i need to pass emissions so i can get my car registered here in the great state of Nevada. any i got it all in just fine car started up great, and then i turned it off to finish cleaning up my tools. I get back into the car and it won't start at all not even enough electricty to open the electric locks. So i jump started it i started up no problem i make it home and turn it off same thing happens. So my questions is it the battery or maybe the alternator or something else. The battery is only about a year old so i dont think it should be going bad already should it?
maxima_fan_boy is offline   Reply With Quote
Old 10-24-2008, 01:41 AM   #2
get a voltage test on it
and it is close to 4 am so im a wee bit tired so correct me if im wrong...but if your alt was bad youd be hearing some funny noises from your engine bay... and your car would most likely choke in the middle of the road...
go to advanced auto, autozone, napa, w/e you guys have out there and have them test your battery....ive had ones that lasted 6 months and some that last 7 years
__________________
95 GLE 84K miles
Mods: NGK plugs, z32Fuel filter, Franken mid pipe w/ specter cone, 2.5 Magnaflow muffler with 2.5 crush bent B pipe, Warpspeed Y pipe, Koyo Alum. radiator, Hayden 404, DR switch, Mobil 1 syntec.
FOR SALE
http://forums.maxima.org/4th-generat...arts-sale.html
hornepirate is offline   Reply With Quote
Old 10-24-2008, 09:53 AM   #3
Yeah, test the voltage. If the engine is off it will be 12V, if it is on - then 15V
tosheto is offline   Reply With Quote
Old 10-24-2008, 11:55 AM   #4
make sure u have no corrosion on ur terminlas but as i do when im bored just take a wire brush and give the 2 terminals a good clean dirty terminals= no battery getting charged and excessive work for the alternator
maxfever1987 is online now   Reply With Quote
Old 10-24-2008, 01:39 PM   #5
Battery voltage with engine off should be about 12.6 volts.
But as others wrote above, check the contacts. It's unlikely your battery went from strong to dead in a few minutes without producing some serious heat.
iDuty is offline   Reply With Quote
Old 10-24-2008, 09:09 PM   #6
alright ill get it checked out tomorrow.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
