Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 10-23-2008, 01:04 PM   #1
RPM fluxuation at startup
hey i just got a 95 maxima, when i got it the engine light was on, everything seemed perfect, next day i checked out the engine light codes on the ecu(codes 0304, 0901, 0302). needs a Front Right Htd 02 sensor heater, knock sensor and maybe some egr cleaning. started it it up and the rpm went down past 300 then up to around 1500 and so forth then eventually started to level out at around 600 or so. anyone have any ideas why? mileage is 200 000 km btw
alexdbest is offline   Reply With Quote
Old 10-23-2008, 08:17 PM   #2
anyone?
Old 10-23-2008, 08:30 PM   #3
I would start with the codes make those few repairs then go from there
I have seen EGR valves do that in some imports
__________________
Steve31 is offline   Reply With Quote
Old 10-23-2008, 08:39 PM   #4
i have the same dang problem. check into the egr system. thats the problem with mine. the dealer wanted like 450 bucks to clean it out for me. as you might of already noticed, the egr on this maxima is a pain in the rear. price and lazyness has left mine still uncleaned......my money is on your egr.
fishforlife2007 is offline   Reply With Quote
Old 10-23-2008, 08:51 PM   #5
thing is when i first got it it started up fine, now it has an idle problem, only thing ive done to the car since getting it is getting the codes from the ecu and reset the engine light.
Old 10-23-2008, 09:58 PM   #6
Quote:
the dealer wants to use your lack of knowledge to his advantage - read up on the egr, i have a plugged up one + a code and the car runs without any probs.
OP - clear the codes and see if it happens again and if they come back. there's a $hit load of threads on idle problems which might help you troubleshoot yours ie iacv, tb, tps etc. do some searching.
allensteiner21 is offline   Reply With Quote
Old 10-24-2008, 01:41 AM   #7
Send a message via MSN to davidforehand Send a message via Yahoo to davidforehand
spend a day taking your throttle body, idle air control valve, and egr tube out and hose them down with throttle body cleaner or carb cleaner and wipe down. You may have to adjust idle with throttle position sensor unattached afterwards. This is what fixed my idle fluctuating and got rid of the 0302 code. Also remeber it will still idle high when engine is cold and will eventually come back down to 600 rpm when warmed up.
davidforehand is offline   Reply With Quote
Old 10-24-2008, 01:46 PM   #8
Also check that vacuum hoses are connected properly, and not cracked. A vacuum leak can cause poor idle. However, you wrote that it became steady after a while.
When the engine is cold EGR isn't used, especially not at idle, so if you meant a cold start above I doubt the EGR problem is causing the idle to swing.
davidforehand posted good advice.
iDuty is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
