Just installed a Y-Pipe
Old 10-29-2008, 02:17 AM
mywhitewolf's Avatar
hi there, I've just installed a Y-Pipe (an e-bay pipe) + headers and my exhaust sounds like a V8 at idle? is this normal or is there a good chance i haven't tightened something down properly?
mywhitewolf is offline
Old 10-29-2008, 03:49 AM
allensteiner21's Avatar
better that than "bees in a can" sound did you use ebay gaskets? those might leak so it's better to buy new oem ones.
allensteiner21 is offline
Old 10-29-2008, 04:23 AM
nyc96max's Avatar
sounds like it should , be prepare to smell gas burning if you did the cat also. sounds very nice and you will feel a BIG difference.
nyc96max is offline
Old 10-29-2008, 04:46 AM
Turbobink's Avatar
... and my exhaust sounds like a V8 at idle?
and this is a bad thing as opposed to the narrow "V" and tightly timed chainsaw sound that these things can typically exhibit?
Turbobink is offline
Old 10-29-2008, 04:49 AM
a.k.a. STuNtMAN
JonBlz's Avatar
its going to sound like more beefy now cause i know once you do headers and y-pipe you eliminate the cats so you needan O2 simulator and then perhaps a little tune cause you are going to be running RICH
JonBlz is offline
Old 10-29-2008, 07:19 AM
No more Maximas...
pmohr's Avatar
'Sounds like a V8' means absolutely nothing. Is it loping, as if it had a cam? Is it just plain loud? What exactly is different about it?
pmohr is offline
Old 10-29-2008, 09:51 AM
~ 15 hp isn't exactly what I'd call a BIG difference.
The Wizard is offline
Old 10-29-2008, 07:58 PM
i've no idea this "cam" sound is because i've never heard a 4 stroke engine without cams before
but yes, its similar sound to a car with an aftermarket cam, except with a more consistant idle...
Anyway, i think the problem was an exhaust leak. i redid the gasket on the cat converter. and put some exhaust putty on the EGR tube. which seams to help a lot. the problem was that the exhaust was too loud, way to loud for normal driving. but now its only a little louder than stock but the tone is transformed. must say, i like the noise.
Old 10-29-2008, 08:10 PM
nishansMaxima's Avatar
any sound clips?
nishansMaxima is offline
Old 10-29-2008, 11:54 PM
AH!, apparently i broke one of my ignition coils during the install. so I've replaced it and the car is 100% now ,feels a lot stronger, so i'm alot happier however when i step on i can still feel the exhaust pipe smacking against something in the "transmission tunnel". has anyone else had this problem with the SS autochrome ebay headers / Y - Pipe combo?
Old 10-30-2008, 12:09 AM
hornepirate's Avatar
you broke an ignition coil installing a y pipe?
hornepirate is offline
Old 10-30-2008, 12:25 AM
i think it was when i was trying to install the rear headers...
Old 10-30-2008, 02:32 AM
...when i step on i can still feel the exhaust pipe smacking against something in the "transmission tunnel". has anyone else had this problem with the SS autochrome ebay headers / Y - Pipe combo?
yeah, i guy i know had the same problem. maybe my fix that worked for him will help you too - go to a muffler shop and have them weld in an extra hanger. that'll stiffen it up enough to stop the banging.
Old 10-30-2008, 08:47 AM
GStrength's Avatar
he tried installing the pipe from the engine bay. I dont know how he did it, but some how he shimmied the pipe in between the rear of the engine and the firewall, tearing most of his hoses and wires including breaking his coil pack. It got stuck, and he had to take off the hood to sledge hammer it in to place.
GStrength is offline
Old 10-30-2008, 08:56 AM
chillin014's Avatar
lmfao
chillin014 is offline
Old 10-30-2008, 05:12 PM
i hope your not being serious....lmao
then again...i tend to expect things like this from the org...
just in the past week....
the guys whose airbag went off taking his dash apart...
the guy whose PR style CAI was angeled to sit like an injen...
and the guy who spray painted his dash :-p
Old 10-30-2008, 05:16 PM
Isn't that how everyone else did it?
Old 10-30-2008, 05:26 PM
i did my from under my car....the way most people tend to put y pipes in...kinda hard to reach everything from above....
Old 10-30-2008, 05:27 PM
No more Maximas...
pmohr's Avatar
i did my from under my car....the most people tend to put y pipes in...kinda hard to reach everything from above....
pmohr is offline
Old 10-30-2008, 06:40 PM
ajcool2's Avatar
ajcool2 is offline
Old 10-30-2008, 10:09 PM
modenaf1's Avatar
Holy ****. Links?
LMFAO!!!
modenaf1 is offline
Old 10-30-2008, 10:14 PM
No more Maximas...
pmohr's Avatar
Originally Posted by modenaf1
Holy ****. Links?
LMFAO!!!
http://forums.maxima.org/4th-generat...bout-dash.html
http://forums.maxima.org/4th-generat...-question.html to http://forums.maxima.org/4th-generat...my-intake.html
http://forums.maxima.org/6682858-post23.html
Note these were all the same person. Link 4 is from the thread in link 1.
pmohr is offline
Old 10-30-2008, 10:16 PM
hot_wax_tree's Avatar
yeah not to you turbo boy but to us NA's it is pretty nice.
Hey man make sure your O2's are in, cause with the stock resonator and muffler in you shouldnt get to much of an increase from what i've heard.
hot_wax_tree is offline
Old 10-31-2008, 06:35 AM
chillin014's Avatar
dude no ****!!! LOLLLL My mind is blown.
now we got another guy who admits he has a bad knock sensor but is replacing everything except the knock sensor to solve his problem.
Old 10-31-2008, 07:22 AM
i swear...some of these people's last car must have been a honda...
Old 10-31-2008, 11:38 AM
The Golden One
IlyaK's Avatar
Oh my....
IlyaK is offline
Old 10-31-2008, 01:25 PM
elemax's Avatar
no way someone did this...
elemax is offline
Old 10-31-2008, 01:35 PM
chillin014's Avatar
whats that? you put your Y pipe on backwards?
Old 10-31-2008, 02:11 PM
ChubbieBoi's Avatar
WOW
ChubbieBoi is offline
MaxLife17
06-27-2019 01:37 PM
2kmaximel
09-16-2015 03:19 PM
Violator
09-09-2015 10:14 AM
Quick Reply: Just installed a Y-Pipe
