Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 10-22-2008, 04:51 PM   #1
Possible clutch fluid leak?
Okay, I've been noticing a few things. One, no matter how mucky it is outside, my driver's front wheel well always seems to have splatters up underneath, and I don't notice any under the passenger side. Also, at the right angle from the outside I can see little blue-ish spots on the bottom inside of the windshield, near the defrost vents.
My clutch fluid is at an okay level, but seems a few millimeters lower than I remember it (not low enough to explain how much splatter I see in the wheel well). Also, the fluid buildup in the well seems to stem from a small panel leading directly underneath of the clutch master cylinder. However, the cylinder and the lines leading from it are bone dry.
I also noticed starting after I had my alternator replaced (around the same time I noticed the splatters), a funky sweetish-musty kind of smell coming from the engine from time to time. At the time I thought maybe it could be the new rubber of the belt they replaced, and I have not noticed it for a while now, but I don't know if it could possibly be the smell of clutch fluid or whatever could have been coming in from my vents.
Does anyone have any ideas if these symptoms could be related, what could be causing them, or what could be causing them individually? Also lemme know what else to check for, this odd combination of symptoms puzzles me..
__________________
SHIFT_F7
99BettySE is offline   Reply With Quote
Old 10-22-2008, 05:37 PM   #2
I have a leaking drivers side axle. But it of course is tranny fluid not clutch fluid...
__________________
1988 Ford Mustang Notchback
427 Stroker, Art Craft C4, Nitrous, Caged..
10.95@124 On motor
10.01@131 on Nitrous. So so close to 9's
Silver 99 Maxima SE
Black leather 5 speed
100% stock...
Gtpowered4.6l is offline   Reply With Quote
Old 10-22-2008, 06:41 PM   #3
I haven't confirmed that it's clutch fluid, it just seemed possible it was coming from a clutch line. But does the axle leave similar splash marks under the fender? I've never seen any puddles or anything where the car is parked.
__________________
SHIFT_F7
Old 10-22-2008, 06:55 PM   #4
my vote is for transmission fluid, leaking from the driver side diff seal. If you look under your car i bet you will see a bead of fluid sitting on the bottom edge of the tranny near the drivers side wheel.
This is most likely caused by a bad seal or bad diff bearing assuming that is the problem.
if you had a clutch leak bad enough that you were noticing drips i would think you would have a mushy pedal pretty quickly
__________________
00' SE 5 Speed/ Cattman Muffler/ Warpspeed Y/ 17º advance/ 5% tint all around/ 6000K HID's all around/ Hawk HPS's all around/ FSTB/ Alpine HU/ Alpine Type R speakers
Feldman is offline   Reply With Quote
Old 10-23-2008, 06:02 AM   #5
Not that it's light out and I've had time to look up underneath, I found it. CV boot torn wide open. I haven't had any clicking or driveability issues, do you think it's too late to just do the boot and not have to replace the whole axle? I don't have the money or time to replace an axle right now, and I'm wondering if that will at least be a quick fix for a short while so it doesn't completely go on me until I can replace the axle.
Granted, I doubt this would get in my defrost vents, so there might still be that mystery...
__________________
SHIFT_F7
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
