Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 10-22-2008, 02:55 PM   #1
Slave/Master Cylinder Issue
so the other morning I try to move my car and the clutch pedal kept ketting stuck as I let go and was unable to put car in gear when car was started only wen it was off I was able to put in gear...So i was able to start car in first and took to mechanic....
He says the slave cylinder needs to be replaced as well as the brake master cylinder...do they correspond at all to the clutch pedal being stuck? He said the brake master cylinder needs to replaced something to do with hydrolic system or something...any comments? thanks a lot
KDog125 is offline   Reply With Quote
Old 10-22-2008, 03:11 PM   #2
Are you sure he didnt mean the "clutch" master cyl.?
the brake master has nothing to do with your clutch.
alset2 is offline   Reply With Quote
Old 10-22-2008, 04:45 PM   #3
The Dirty Pearl
pmohr's Avatar
Send a message via AIM to pmohr
Have you tried bleeding it first? I imagine your clutch fluid reservoir is dry?
Also, look around for leaks. More than likely it's around the lower clutch line.
pmohr is online now   Reply With Quote
Old 10-23-2008, 02:02 AM   #4
same thing happen to mine, kept sticking , changed the slave and clutch master cylinder. works perfect now
__________________
NY2NJMAX is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
