Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 10-22-2008, 02:35 PM   #1
t_ahan's Avatar
Rear Timing Chain Cover Leaking
Well my rear timing chain cover started leaking to the point were it drips even when the engine is turned off. I really dont want to pull the engine out cuz then i have deal with the obx 2 piece headers with the rear manifold one pipe with the y pipe, and plus i would have to do the radiator support cuz when i put the cross member back last time i saw the bolts twist in the radiator support becuz that nasty rust,so i know as soon as i take them out they wont go back in......ok well i have been told with my milage 198k+ that stop leak would just give me poor oiling and eventually cause an internal problem, so they told me to try brake fluid or half a qt of ATF...i dont want pull the motor till i get a 5sp trans to do the conversion and jus do it all but that wont be till next spring or summer.i put an autometer oil pressure gauge jus to be on the safe side n see when it drops low. WIL THE ATF OR BRAKE FLUID BE ANY BETTER THAN THE STOP LEAK????
__________________
MR.T
t_ahan is offline   Reply With Quote
Old 10-24-2008, 06:30 AM   #2
You will have to remove the timing chain cover, clean everything and use a good silicon to seal the cover and re-torque all those bolts, but you may get away by just re-tightening all the bolts. My 2 cents.
AA
__________________
2K1 AE-SE - Sterling Mist
2k8 Nissan Rogue
doublea is online now   Reply With Quote
Old 10-24-2008, 07:47 AM   #3
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
This has nothing to do with advanced performance, moved to the 4th gen forum. Also, no, adding ATF or brake fluid to your oil will do nothing to fix your leak, if anything, it would make it worse.
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is online now   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
