Passenger side tie rod?
Old 10-23-2008, 08:16 PM
DTrem08's Avatar
Hi I'm still relatively new to the Maxima world. Theres a smaller boot on what I believe is the tie rod (not the boot on the axle, the one smaller and closer to the passenger area) that tore on my 99 max. I'm wondering what I'm looking at for a replacement. Also, I heard a clacking noise that is why I got out and found the boot ripped. It's not consistant but does kind of worry me.
Questions:
1- What are my options for fixing the boot/tie rod?
2- Is the clacking sound related to that joint not having grease or what are some other possibilities.
DTrem08 is offline
Old 10-23-2008, 09:29 PM
tHe iLleSt RiCe's Avatar
depending on how old that boot has been ripped, the grease might all be gone and the tie rod might have excessive play providing you with sloppy suspension. An outer tie rod is not that expensive at the auto parts store.
tHe iLleSt RiCe is offline
Old 10-24-2008, 04:45 AM
DTrem08's Avatar
so i could but the outter tie rod and a new boot, put the old tie rod on and then put the new boot on?
i wasnt sure if it was all one peice or not
DTrem08 is offline
Old 10-24-2008, 04:49 AM
No more Maximas...
pmohr's Avatar
The outer tie rod has an integrated ball joint, which is likely the boot you're talking about.
pmohr is offline
Old 10-24-2008, 05:10 AM
KRRZ350's Avatar
I have a weird feeling he's talking about the inner one, just 'cause he compared it to the axle boot and said it's closer to the compartment.
Does the boot you speak of have bellows? Looks like a round accordian?
KRRZ350 is offline
Old 10-24-2008, 07:22 AM
DTrem08's Avatar
Yes, it does KRRZ350
DTrem08 is offline
Old 10-24-2008, 07:39 AM
webjohn's Avatar
does the "clacking" sound happen when your turning, if so its probably the real axle.
and the one your talking about is the rack and pinion boot. to change that boot i believe that all you have to remove is the outer tie rod. and then loosen the clamps on the boot and slide it out(the boot is on the rack and pinion not on the outer tie rod). someone please correct me if im wrong.
webjohn is offline
lkiller123
09-21-2015 03:00 AM
londonflu
09-19-2015 02:33 PM
Bonka
09-14-2015 11:18 PM
Colossus
09-09-2015 05:46 AM
FanaticMadMax
09-04-2015 02:45 PM
Quick Reply: Passenger side tie rod?
