Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Closed Thread
Thread Tools Display Modes
Old 10-20-2008, 10:27 AM   #1
80MPH at 3400 RPMs?
Hey does this sound right? I have a 5 speed. I just cleaned the throttle body, new air filter, and a new PCV valve. I didnt clean the IACV or change the fuel filter could that be why the RPM's are so high?
__________________
5MT- 9007 Rewire - Yellow Fogs - Full Exhaust- 2k Wheels
Mctwist77 is offline
Old 10-20-2008, 10:31 AM   #2
Maintenance Monster
Physically impossible for that to cause a change in your tachometer reading. The speed / RPM is mechanically governed by things like wheel size, transmission ratio, etc. The ECU is programmed with the speed vs. RPM and will not change.
80mph/3400 sounds about right.
What size tires are you running, and on what rims?
dgeesaman is online now
Old 10-20-2008, 10:32 AM   #3
I have on the 2001 stock 17inch rims.
__________________
Old 10-20-2008, 10:37 AM   #4
Maybe I am just used to my mustang which cruised at 2000 RPM's on the highway
__________________
Old 10-20-2008, 10:45 AM   #5
Yep, that sounds about right. I really wish we had a taller 5th gear. The car definitely has enough torque to cruise at 80 or 90 at 2500 rpm just fine.
modenaf1 is offline
Old 10-20-2008, 11:17 AM   #6
Yep its normal, wheels will not affect the engine speed reading from the tachometer. It might not be 100% accurate, I know that mine reads about 100rpms higher than it actually is revving, due to having a VAFC-II.
It does suck that our 5th gear isn't taller but oh well, I still get 27 mpg if I drive easy on the pedal and all highway.
__________________
1999 Super Black SE 5MT '00VI|VAFC-II|Fed Spec Conversion|Cattman Y|Budget B|HKS Rear Section|Stillen Hi-Flow Intake
OBX STS|18" Mille Miglia Evo 5s|Stillen FSTB|Progress RSB|Intrax Springs|KYB AGX Struts|AE Pedals+350Z Dead Pedal
Escort Passport 8500 Hardwired|Red/Clear Tails|Clear Bumper Lights|35%/25% Tint|Nismo Shift Knob|I30 Leather E-Brake+Autodim Mirror
Exedy Stage II Clutch|I30 VLSD Transmission
99BlackMaxMS is online now
Old 10-20-2008, 11:26 AM   #7
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Sounds good. I know that 5th tops out at about 143 lol.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is offline
Old 10-20-2008, 11:39 AM   #8
sounds bout right, swap in a 6 spd if you don't like it
__________________
Car Ramrod
Don't tase me bro!
SHIFT_3.ooohhh
fat_kid is offline
Old 10-20-2008, 11:45 AM   #9
I agree, sounds about right.
__________________
1996 I30 auto champagne gold
2007 350z redline
1994 Mazda 626 v6 champagne gold (for sale)
1990 240sx fastback red (sold)
1994 Chevy Lumina Euro white (sold)
exchange240sx is offline
Old 10-20-2008, 11:53 AM   #10
Quote:
I might just have to do that one of these days. And a VQ35 to go along with it. And forced induction to go along with the VQ35. And...god damnit this hobby is an addiction I tell you!!!
modenaf1 is offline
Old 10-20-2008, 12:15 PM   #11
Is there a reason Nissan didn't make 5th taller? It spins pretty dang fast, it gets annoying when you're out in the middle of nowhere and are cruising at 85-90 like everybody else.... My mom's 00 I30 is a good bit slower, which seems a bit counter intuitive, does it not?
While we're on the topic, how do you guys feel about the ratios of the 5 speed? That is, is first too short compared to how long second is, etc..
__________________
1996 5spd Max. G wheels.
ck4x4 is offline
Old 10-20-2008, 12:31 PM   #12
Thanks guys for all your information it is greatly appreciated.
__________________
Old 10-20-2008, 02:56 PM   #13
Maintenance Monster
It's a maxima, not a ferrari. I think the ratios are just fine.
I suppose a taller 5th might help fuel economy, but if you need to push hard on the gas in 5th to accelerate you can pretty quickly eat up the fuel savings that you saved while cruising.
Dave
Old 10-20-2008, 04:50 PM   #14
Newbie-Just Blazed
Send a message via AIM to QNO_A32
yeah 5th is short, my car feels strung out crusing at 80-85 like. but 5th gear definatly pulls real nice. and yes it will do what it says on the speedo.
__________________
SHIFT_ A REBUILT TRANNY
QNO_A32 is offline
Old 10-21-2008, 06:30 AM   #15
I will eat your children
ozzombie13's Avatar
with a lightweight flywheel my car now cruses just about 3050 rpm @ 80. I believe nissan designed the fifth gear so that you wouldnt have to downshift at highway speeds to pass, as the torque curve on the vq really kicks up around 3000 rpm
__________________
1990 GXE -- Ebiach/KYB-GR2 set up, ebay fstb, blehmco grounding kit, ebay maf adapter and filter
system - 2 memphis 10 studio subs, sony xplode head unit and 250 watt xplode amp, pioneere 6x9's with jensen 100 watt amp and hacked bose in the front as tweeters.
1998 GXE -- 5 speed - ebay fstb, ebay intake, clarion head, sony 4-way 6 1/2s all around, ss warpspeed y, high flow cat, ss Megan cat back, red/smoked tails, all clear front lights, B&M sts, Brembo X-drilled rotors all around, many more mods to come.
ozzombie13 is offline
Old 10-21-2008, 07:07 AM   #16
Thunder go b00m.
CapedCadaver's Avatar
Quote:
uh... wha? you mean on your stock flywheel your 80mph RPM in 5th was different? or am I misreading what you said?
i know i'm in the wrong forum, but the 3g 5spd is basically the same way. pulls good in 5th but screams along at an even higher RPM than the 4th gen 5spd... i'm turning 3000 at like 75mph. so what i'm planning to do is replace my 5th gear (in/out) with the correlating parts out of a 2nd gen transmission, to give me a longer 5th gear (.745 instead of .790). if any of you are handy rebuilding manual trannies, this may be a direction some of you will want to look into, providing that the VG tranny parts will match up to the shaft splines on a VQ tranny.
__________________
PieceOut.FallToPeaces
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Fidanza | Exedy | WSP | NWP | a33b front & z31 rear BBK | ES bushings | SE suspension swap | 2k2SE rims | Toyo Proxes4
Quote:
Originally Posted by Benstoked
fu*k a fight, I will just hit him with burhan's car, and tie him up with string cheeze, that way he can chew his way out and he wont starve
New to the forum? CLICK HERE!!!! <-- I see what some mod did there.....
CapedCadaver is online now
Old 10-21-2008, 07:54 AM   #17
Quote:
Could grab one out of a 1st/2nd gen altima if it's the right ratio.
__________________
Mod List? Nope - Sylvania Xtravision headlights | Bosch Microedge wiper blades | Lightning Audio Speakers | Falken Ziex 912 tires
freshv6power is offline
Old 10-21-2008, 07:56 AM   #18
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Can you grab a pic of that 2g gear and pm it to me, I will let everyone know what's up. His post doesn't make sense, 80/3400 is about right.
KRRZ350 is online now
Old 10-21-2008, 08:04 AM   #19
Quote:
Thats weird. Ive gone 145 and i still have like 600rpms more to go before i redline.
__________________
maxima.713 is offline
Old 10-21-2008, 08:26 AM   #20
Quote:
Get gps and you will see how fast you are really going. It may surprise you.
__________________
Led retro's Pm me
kzoosho is offline
Old 10-21-2008, 09:07 AM   #21
Thunder go b00m.
Quote:
unfortunately i don't have one handy... i know matt93SE had a 2g trans laying around recently... but no idea if he's still got it. otherwise i asked Big E-dog if he had any spares or anything... it's a long term project being that i have never cracked a tranny open before..... we shall see.
but currently i lose 33% rpm from 3 to 4, and a scant 20% from 4 to 5....... using a 2nd gen 5th would drop me by 29% into 5th which is much more comfortable.
Old 10-21-2008, 09:27 AM   #22
4th generation 5th gear ratio
Please post what most economical solution to 5th gear ratio reduction!
I wonder if replacing entire tranny with "lower RPM" box out of another Gen/Altima is the least expensive or getting gear to match current tranny... either way, labor costs will make this a *#&**$$$. I agree, that our VQ does NOT need such a high RPM "cruise gear" as it easily passes traffic in 5th gear below 3K!! If you need to "blast around someone" pull it back one gear! My auto has perfect OD gearing and cruises at below 3K (30MPG) at 75/80... I NEVER have to downshift out of OD to easily pass.
packerZ is offline
Old 10-21-2008, 10:47 AM   #23
Maintenance Monster
Quote:
It's not a simple answer. It would require some calculations using the engine fuel usage vs. load vs. rpm characteristics to determine what the optimum would be.
It is probably more economical to have a taller fifth, since the fuel economy testing of 1993-94 were based on a "highway" speed topping out at 60mph. (http://www.fueleconomy.gov/feg/fe_test_schedules.shtml)
Most of us drive on highways much faster than that. The optimum overdrive ratio will change if designed primarily for 75mph.
All that said, changing 5th will require that the synchros be compatible and the splines line up. I have several spare 5ths and shafts laying around from a 4th gen, but I don't have any altima or 2nd gen maxima parts. It's entirely possible that the parts are a drop in just like the 3rd gear from an altima is. If someone had the proposed gear parts handy we could figure out if they will fit.
The trouble with this exercise is that if you're paying a shop to change it you'll never recover that cost in fuel savings. Even if I'm doing a rebuild for someone and the labor is a non-issue, I still need to have the spare gear parts hanging around or bastardize a core. So that further adds to the cost and difficulty.
Dave
Old 10-21-2008, 12:55 PM   #24
I guess the reality of my question is: gears/tranny swapping "not even practical" until tranny is ready to be re-built! At that time the specs of each transmissions' gear offerings to gain "optimum" gear selections could be factored. However, really all I want to get is a 5th gear replacement on my 4th gen 5speed that was much lower RPM (a real O.D. drop).
Yet, I realize that even if someone had such a 5th gear-conversion tranny made-up or replacement/crossover tranny w/desired 5th gear ratio just laying around, I'd have to wait for tranny R&R-time labor $$ to make sense...
and not really wishing it to be soon! Even though I want that gearing!!!
packerZ is offline
Old 10-21-2008, 01:24 PM   #25
6-speed
If you are going through all this trouble to make a better 5-speed, why not swap a 6-speed. Not practical for Capedcadaver, vg, not vq, but for everyone else... I know it is work to go from rod to cable, but designing a transmission is also pretty tough
augiedog964 is online now
Old 10-21-2008, 02:06 PM   #26
Thunder go b00m.
Quote:
well, eventually (as in, next decade) I am thinking about a VQ (00-01 probably) swap with a 6spd... once those cars are more common in the JY. They are just too new right now to find them.... I give it another 5 years maybe. But you're right, the 6th gear on those is like .603 compared to my 5th gear which is .790... that's one hell of a cruising gear i'd say. Maybe not as second-nature to flick the shifter up for a downshift as it is to pull it rear-center into 4th... but i'm sure we'd all get used to it.
But even so it may be possible for me to do that on my current engine, with a bellhousing adapter, if I ever learn how to weld and fab metal things. i thought there was a sticky for the 6spd conversion somewhere, right?
__________________
Old 10-21-2008, 02:46 PM   #27
at 80 mph my rpm is at 3000 steady, i have an outo tho.
s0mbra is offline
Old 10-21-2008, 02:51 PM   #28
Thunder go b00m.
Quote:
yea.. my old VG A/T would run 85mph @ 3000 on a tach that read high so more like 2900... but the manual has shorter gearing to make up for the fact that you don't have a TC allowing a few hundred RPMs of slip when out of lockup mode.
__________________
Old 10-21-2008, 04:29 PM   #29
khantalha+'s Avatar
Send a message via MSN to khantalha+ Send a message via Yahoo to khantalha+
same here, i think it tops out at 153-155 mph with a factory rev limiter
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Day/Grocery Getter) = sold
myspace.com/shady_aftermath_
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
