Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Closed Thread
Thread Tools Display Modes
Old 10-25-2008, 02:39 AM   #41
I will eat your children
ozzombie13's Avatar
Quote:
Originally Posted by CapedCadaver View Post
yea... that's why i was wondering where he got that idea..... i just swapped in a light flywheel and the only difference is the performance... so unless he put on a differently-geared tranny (if any such differently-geared 5spd will even fit a VQ maxima) then he must just be mistaken or have a bad tach or something.
i got this idea because thats what my car now does. i was confused myself, but it did change
ozzombie13 is offline
Old 10-25-2008, 07:30 AM   #42
Send a message via Yahoo to j2b4osan
wow, knowing that mustang people are driving max's makes me wanna sell mine.
__________________
Long Island NY black 96 5spd se tein, kyb.
(88 sr5 corolla)
j2b4osan is offline
Old 10-25-2008, 09:36 AM   #43
Thunder go b00m.
CapedCadaver's Avatar
Quote:
well then your tachometer is reading wrong... cuz 3000rpm through a .750 (or whatever your 5th is) gear through a 3.50 (or whatever yours is) final drive on 25.5" (again...) tires will ALWAYS be the same speed whether your flywheel is lead or aluminum.
__________________
PieceOut.FallToPeaces
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Fidanza | Exedy | WSP | NWP | a33b front & z31 rear BBK | ES bushings | SE suspension swap | 2k2SE rims | Toyo Proxes4
Quote:
Originally Posted by Benstoked
fu*k a fight, I will just hit him with burhan's car, and tie him up with string cheeze, that way he can chew his way out and he wont starve
New to the forum? CLICK HERE!!!! <-- I see what some mod did there.....
CapedCadaver is online now
Old 10-25-2008, 11:26 AM   #44
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
LOL this thread is ridiculous. The ONLY thing that can change your indicated speed vs RPM ratio is a change in gear ratio or final drive - or a speedometer or tachometer being messed up and giving you false indications. It is physically impossible to change the ratio between indicated speed and RPM in any other fashion. Physically impossible. Flywheels can't do it. IACVs can't do it. Fairy Godmothers can't do it.
5th gear in the 4th gen at redline is 163mph indicated. Again - there is no discussion to be had. It's simple mathematics. If you're using stock tire size, your tachometer is accurate (meaning you're turning 6550rpm when your tach says you're turning 6550rpm) that is how fast you'll be going at redline in 5th gear in a 4th gen which has the stock .795 5th gear ratio and 3.82 final drive ratio. It's math guys. It can't be argued with. It can't be reasoned with. It can't be changed. It's like the Terminator. That's it.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
