Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 10-19-2008, 09:10 AM   #1
192.168.1.1
gtr_rider's Avatar
VQpower.com - NWP VQ30DE Spacer Kit Review
During those HOT summers, don't you wish there was a solution to the decline in response and performance once that dreaded heat soak process has taken effect? Heat Soak occurs when heat is applied and not dissipated at an equal rate causing the material to flood with overwhelming tempature limits. That being said Aaron Kimball of NWP Engineering has thought of an easy solution to keep those intake temperatures at optimal levels. The use of Phenolic Laminate Material insulates the intake and throttle body components, reducing the rate of heat transfer from the heads to the intake manifolds, for cooler air which in turn restores optimal performance. Phenolic Laminates are usually compression molded and they have good strength and toughness, good arc resistance and other electrical properties, good resistance to solvents and high temperatures which makes this Spacer Kit a bargain. Today's product we are going to focus on is the VQ30DE Phenolic Thermal Intake Manifold Spacer Kit which is said to have an average Intake Manifold Temperature decrease of 43degrees.
./news.php?readmore=220
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline   Reply With Quote
Old 10-19-2008, 09:22 AM   #2
NOT Banned
JSMax's Avatar
Send a message via MSN to JSMax
that's a really great writeup thanks gtr rider.
__________________
JSMax is offline   Reply With Quote
Old 10-19-2008, 09:49 AM   #3
Send a message via AIM to nyc96max
gtr rider nice wirte up btw you have a HOT sig. Im feeling those projector headlamps
__________________
WTB : Vortech supercharger kit
nyc96max is offline   Reply With Quote
Old 10-19-2008, 10:11 AM   #4
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
Sweet write up. Nice work.
ChrisMan287 is online now   Reply With Quote
Old 10-19-2008, 01:05 PM   #5
Send a message via AIM to ChubbieBoi
Great Write Up..!!
__________________
|Stillen Lip Kit|Stillen Hi-Flow Intake|Budget Y-pipe|Cattman Prototype Coilover|
|CF Hood|AE Headlight|HID 6000k|Red/clear tail light|Black Bumper light|Fstb|
Current projects:| Tan interior swap out into Black leather w/ white LED (85% done) | CF hunting|
MANY PARTS FOR SALE
ChubbieBoi is offline   Reply With Quote
Old 10-19-2008, 01:15 PM   #6
Well Done Luke!
__________________
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Jan-2009
Snypa is online now   Reply With Quote
Old 10-19-2008, 02:34 PM   #7
Good job, Just one question... if i use these on my usim, when the intake manifold to the 00vi can i use these spacers for it?
VQrebuild96 is offline   Reply With Quote
Old 10-19-2008, 02:57 PM   #8
Merc signs my checks
liqidvenom's Avatar
Send a message via AIM to liqidvenom
as always great work.
__________________
which team are you with?
liqidvenom is offline   Reply With Quote
Old 10-19-2008, 03:06 PM   #9
192.168.1.1
gtr_rider's Avatar
Quote:
We are currently working on adapting a spacer setup to run on a 00VI, currently the lower will match up exactly, however, the upper needs to be modified to fit. NWP is sourcing longer thread bolts to allow the spacer to be mounted on the upper manifold.
__________________
VQpower.com
Need work done:
Old 10-27-2008, 12:59 PM   #10
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Thanks Luke for doing this review!
Aaron92SE is offline   Reply With Quote
Old 10-27-2008, 02:15 PM   #11
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
dyno?
nm found it:
Torgus is offline   Reply With Quote
Old 10-27-2008, 03:37 PM   #12
Send a message via AIM to l3ftonm3
Maybe one day someone with a Mevi will dyno before and after with these. Im curious to see the differences.
l3ftonm3 is offline   Reply With Quote
Old 10-27-2008, 06:25 PM   #13
Send a message via AIM to Maximamand Send a message via Yahoo to Maximamand
have something sililar on my Turbo Jetta..works great and keeps the intake charge temps down..worth it if you have the time for sure....
Maximamand is offline   Reply With Quote
Old 10-28-2008, 09:46 PM   #14
Send a message via AIM to A32MadMax
Im getting this set up on my MEVI. But its an auto, so i dont think its worth it getting it dyno'd...
A32MadMax is offline   Reply With Quote
Old 11-19-2008, 01:51 PM   #15
Hey GTR_rider, how long did it take you to do the install? It doesnt look that bad to do....
__________________
Maximus Decimus Meridius....
Stagnet04 is offline   Reply With Quote
Old 11-19-2008, 03:02 PM   #16
NWP Engineering.com
Aaron92SE's Avatar
Quote:
The installation instructions state 4-5 hours. But since gtr_rider has done several of these installations before, it probably took him less than that.
Old 11-19-2008, 05:12 PM   #17
Send a message via AIM to f550maranello2
my only question is that if the motor needs to dissipate all that heat and then ur eliminating a lot of metal that helps draw it away.....
what happens to the additional temperatures that the engine block is now encountering
__________________
f550maranello2 is offline   Reply With Quote
Old 11-19-2008, 05:23 PM   #18
Build.
Send a message via AIM to nismology
^ That's what the cooling system is for.
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 11-19-2008, 05:23 PM   #19
dissipating heat? theres a conflict of terms when referencing a intake manifold. My only question is there a thermal resistant spacer for the egr guide tube that bolts to the IM?
__________________
"97 in progress"
97Maximus is offline   Reply With Quote
Old 11-20-2008, 04:27 AM   #20
sweet
SleepyMax1 is offline   Reply With Quote
Old 11-20-2008, 08:58 AM   #21
NWP Engineering.com
Aaron92SE's Avatar
As nismology mentioned, heat is brought out of the engine by means of the radiator and cooling system. The cast aluminum intake manifolds do not help to draw heat away from the heads. That's what the cooling system does.
With these Thermal Intake Spacers, you will be preventing heat from transferring from the heads to the intake manifolds. This does not increase the temperatures of the heads at all. We tested this as well. The cooling system regulates head and block temperatures. With the spacers, you will reduce the actual intake manifold temps and in turn, reduce heat soak.
Quote:
There is not an EGR thermal spacer. With all our testing, an insignificant amount of heat is transferred by means of the EGR tube. The little amount of heat we are talking did not constitute producing this piece which would have raised the price of the kit. We strictly concentrated on which spacers would provide the most gain in HP.
On the VQ30DE Maxima, we noticed an average temperature decrease of 43 degrees in the lower intake manifold and 40 degrees in the upper intake manifold.
And also, I'd like to point out that the temperature of the heads were exactly the same before and after the installation of spacers. It was 195 degrees before and it remained 195 degrees afterwards.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
