Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 10-16-2008, 04:44 PM   #1
What should I do!
So my wife is giving me a grand to mess around with the car. It's got 164K on it and i need to make it ride better. My plans are replacing the mounts, springs, and some bushings. I'm also planning on doing the 02 sensors and knock sensor. Anything else I should get for it? I'm wondering if I should even do the 02 and Knock sensors. Theres no check engine light...
__________________
WHAT KEEP IT STOCK! Well that takes the fun out of it.
99 Nissan Maxima SE - K&N Filter - Stillen Exhaust - KYB GR2 Struts - 300ZX Fuel Filter
BeZerK2112 is offline   Reply With Quote
Old 10-16-2008, 04:52 PM   #2
def. get the springs and struts. go to advanced and get them to check for codes. if nothing shows up, dont worry. I dont know if you are going performance or style so I dont know. I personally would order a lip kit
__________________
THE MAX
tigersharkdude is offline   Reply With Quote
Old 10-16-2008, 05:02 PM   #3
Send a message via AIM to ImmaSquashYou
ok, what needs to be fixed....what doesn't needs to be fixed...is this thousand you have strictly for whatever you want, or is it part of maintenance. If its maientance money, i would get new rotors and brake pads right away and stash them until u need to change them. I would also buy oil and air and oil filter. If your springs are fine, why get new springs and such? Save money for used rims with tires since tires will eventually need to be replaced. Or just get new tires on ur stock rims. $1k goes fast as i have spent $600 on maintenance in the past month alone. Dont start replacing things that is not broken. There's no need to replace the knock sensor if it works fine. No need to replace 02 sensor if its working properly. Just because u put in a new sensor doesn't give you better mileage. Unless you hear popping noises and really rough ride, changing the springs won't give you a better ride.
If you want it to look good, i suggest tints, rims, y-pipe for performance, and a few hundred worth of ncessities for maintaining the car.
__________________
ImmaSquashYou is online now   Reply With Quote
Old 10-16-2008, 05:03 PM   #4
If you want the car to handle better get springs, adjustable struts, front strut tower bar, and a rear sway bar. You will feel like you are driving a completely different car.
__________________
1999 Super Black SE 5MT '00VI|VAFC-II|Fed Spec Conversion|Cattman Y|Budget B|HKS Rear Section|Stillen Hi-Flow Intake
OBX STS|18" Mille Miglia Evo 5s|Stillen FSTB|Progress RSB|Intrax Springs|KYB AGX Struts|AE Pedals+350Z Dead Pedal
Escort Passport 8500 Hardwired|Red/Clear Tails|Clear Bumper Lights|35%/25% Tint|Nismo Shift Knob|I30 Leather E-Brake+Autodim Mirror
Exedy Stage II Clutch|I30 VLSD Transmission
99BlackMaxMS is online now   Reply With Quote
Old 10-16-2008, 05:06 PM   #5
Carbon Fiber addict
How's your gas mileage? If it's good, don't bother replacing the O2's. Besides, you don't have any codes. "If it ain't broke, don't fix it". No need to replace the KS either IMO.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate.....381 HP/323 TQ
The Wizard is offline   Reply With Quote
Old 10-16-2008, 05:20 PM   #6
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
maintenance first of course.
then the mounts and springs.
maybe some oem nissan take off (or anything else of equal quality you can afford) wheels if you have enough left over.
__________________
Your source for premium Maxima/I30 parts!
My CarDomain
Houston Maximas
BLACKonBLACK98 is online now   Reply With Quote
Old 10-16-2008, 05:54 PM   #7
blah, blah, blah...
internetautomar's Avatar
Send a message via AIM to internetautomar
take the 1k and save it for when something breaks. at 164k you aren't far off from needing new rubbers on anything rubber on the car.
__________________
Maxima parts catalog
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
Quote:
Originally Posted by Benstoked
he is worth his weight in platinum plugs
internetautomar is offline   Reply With Quote
Old 10-16-2008, 06:01 PM   #8
The gas mileage seems to be worse lately. Thats whats making me lean towards replacing the knock sensor. I just don't have a check engine light, but at 164k some of them need to be replaced... right?
I had noises in the front end so i got new struts. Had them just over 10k. It took care of some of the noises but not all. So I did the control arms, ball joints, and bushings. Still have a few left. All I can think of now is the mounts and strut bearings. I've decided to put new springs on it since I'm replacing the mounts. These have taken a beating so I'm going with the EiBach pro kit to go with my KYB GR-2's. Feel good about that one. There are some parts I'm not sure of though. Reading though the stickies I see there are some sleves that go on the top and bottom of the springs. Are thoes necessary? I want to use reuse as many parts as possible.
__________________
Old 10-16-2008, 06:04 PM   #9
sleeves are usually thrown away
__________________
THE MAX
Old 10-16-2008, 06:07 PM   #10
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
For 1k turbo lol. Im playin. DO all maintenance you can.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 10-16-2008, 07:34 PM   #11
Maxima.org, my g/f's nightmare
JtzMax's Avatar
Send a message via Yahoo to JtzMax
A grand will not go far for a turbo. lol
Did you get a codes pulled ??? If I had a grand to soak into the car, I'd probably do the following:
KS, Fuel filter, Brakes (rotors and calipers), Struts, Raxle's axles (well, the ds anyway cause the ps is already done. lol).
__________________
CAI, Test Pipe Cat, JDM N1 Cat back, FSTB, Aluminium dash kit, STS, Razo shift knob, Clear markers, CC mod, .ORG Stickers (bright blue), Blue LED switches / map lights, A6 Bi-Xenon retrofit, rebuilt 5spd - My write up --> http://forums.maxima.org/showthread....121&highlight=
Need a wiring harness for your Xenon / Bi-xenon retro? PM ME
JtzMax is offline   Reply With Quote
Old 10-16-2008, 09:03 PM   #12
Open a checking account.
__________________
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Jan-2009
Snypa is offline   Reply With Quote
Old 10-17-2008, 05:29 AM   #13
Quote:
what the hell do you mean... she's giving you a grand?... i don't like where this is going.
don't you mean you've told her you're taking a grand to work on the car?
being married myself i fully understand sexual politics and the subserviant role we need to play intermittently in order to survive... but good God man, when it comes to your car... man up or at least don't advertize your emasculation.
...crap, i somehow feel compelled to invite you over for a twleve pack, a footbal game and maybe even some NASCAR... and i friggin hate NASCAR.
__________________
Turbobink is offline   Reply With Quote
Old 10-17-2008, 08:16 AM   #14
I'm horrible with money. I gave her the responsibility of the money and even gave her my bank and credit cards. Lets just say we have a lot more money now that I've done that and that we actually have a grand to play with! I hate NASCAR too so lets just work on the cars...
__________________
Old 10-17-2008, 08:31 AM   #15
Send a message via AIM to mastere954
i wish my lady would give me a thousand dollars!!! sheesh
__________________
Mods- injen CAI/ Stillen Y/ Stillen B/ Megan Racing Hi-flow Cat/ Greddy SP muffler/ MEVI/ Fidanza Flywheel/ Unorthodox Racing UDP/ JWT ECU/ NWP Thermal Intake Spacer Kit
mastere954 is offline   Reply With Quote
Old 10-17-2008, 08:52 PM   #16
Newbie-Just Blazed
Send a message via AIM to QNO_A32
yeah if you want it to ride better get the Eibachs and use your struts. and do the mounts and all. you can get the KYB strut boot kit too. do that and get a rear sway bar and you will love the way the car rides. you will still have money to play with too for the KS and full tune up youknow
__________________
SHIFT_ A REBUILT TRANNY
QNO_A32 is offline   Reply With Quote
Old 10-17-2008, 09:45 PM   #17
FYI, the knock sensor will throw a ghost code if it's bad. By that I mean the ecu will spit out a code for the knock sensor even though the check engine light is off. So get your codes checked regardless if the light's on or not. You can do it yourself quite easily actually. Check the stickies
psu2fan is offline   Reply With Quote
Old 10-18-2008, 11:46 AM   #18
if all sensors are ok, dont mess with it. It'll just be a headache. Dont fix whats no broken and invest on things you need right now. Run a diagnostic on your car and make sure there are no codes. Once that's done, see what else you need, like you said, get a better suspension. good luck
__________________
VQ35 Loaded....
Maxima FS with goodies
http://forums.maxima.org/maximas-sal...ly-loaded.html
Maximus_95 is offline   Reply With Quote
Old 10-18-2008, 03:44 PM   #19
NOT Banned
JSMax's Avatar
Send a message via MSN to JSMax
and if you want better handling... I would definately add the es poly bushings for the lower front sway bar and end links.
__________________
JSMax is offline   Reply With Quote
Old 10-23-2008, 09:21 AM   #20
Well yesterday I found the reason my car was making noises and riding rough. I forgot to torque my sway bar end links. Once I did that the front end sounded great and had a smooth ride. I feel better accept I found that one of my struts were leaking. Does that mean that it's bad? The struts have only been on for about 12,000K. I'm thinking of replacing them all anyways.
I'm going to check for codes this afternoon to see if anything pops up. Heres my list of parts I want to get.
Keys 99 Maxima Transoponder Keys
Seat Rubber Rear Seat Rubber - 54034
Seat Rubber Front Seat Rubber - 55034-A32B001
Antenna 4" Aluminum
Remote 99 Maxima Remotes
Strut Mounts Front KYB Strut Mount - SM5122
Strut Bellow Front KYB Strut Bellow - SB104
Strut Bellow Rear KYB Strut Bellow - SB108
Knock Sensor Nissan Knock Sensor - 2206030P00
Chain Tentioner Beck/Arnley Chain Tensioner - 0241181
Wheel Barings Timken Wheel Bearing - 510009
Strut Mounts Rear KYB Strut Mount - SM5123
Struts Front Right KYB GR-2 - KYB-334150
Struts Front Left KYB GR-2 - KYB-334151
Struts Rear KYB GR-2 - KYB-341202
Springs Eibach Pro Kit - EIB-6334-140
Total with shipping right now is just under $1100.00. Thoes didn't post right. I coppied them from an excel doc but you get the point.
__________________
Old 10-23-2008, 09:55 AM   #21
Newbie-Just Blazed
plus labor ?
__________________
Old 10-23-2008, 11:43 AM   #22
I do it all myself man. Got all the tools or have access to them.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
