Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-03-2008, 12:00 AM   #161
ok so the idea is that the parking and the brake lights will go through the pwm and the 12v reg. The vreg will output the higher voltage. I have a diagram around here I'll post up. Just gotta find it.
__________________
SHIFT_gone away
Offering services for LED tail lights. All generations. PM me- see link http://forums.maxima.org/general-max...-services.html
Cdg2125 is offline   Reply With Quote
Old 12-03-2008, 12:10 AM   #162
Ok so here is the diagram:
you can see how the parking and brakes get wired and basically the brakes will override the pwm when applied. This is the setup I'm using for my new tail project.
__________________
SHIFT_gone away
Old 12-03-2008, 11:02 AM   #163
This diagram is slightly different from what I was planning do.
darklegend06 is offline   Reply With Quote
Old 12-03-2008, 11:20 AM   #164
thats fine. Just that diagram is a good way to wire it. There are other ways. You just need to make sure that the setup is ok for the type of array you have. What was your plan?
__________________
SHIFT_gone away
Old 12-03-2008, 10:39 PM   #165
The diagram used a sharp regulator, I was going to use a 12v regulator from radio shack.
Image taken from HID planet
Old 12-04-2008, 10:01 AM   #166
yeah that route would work too. Just that the sharp vregs are better than the lm317s you'd get at radioshack. Your diagram will work fine tho because it's the same concept. The parking lights run through the pwm and the lm317 and the brakes run to the lm317 on the pwm and change the output when the brakes are pressed. Just with mine it basically bypasses the lm317 on the pwm and uses the sharp to regulate the differences.
forget to ask, is that pwm sketch modified? Is that using the npn setup or switched to pnp setup?
__________________
SHIFT_gone away
Old 12-04-2008, 10:39 AM   #167
Quote:
If I read everything correctly, I'm using the one that came with the PWM kit, which is the NPN.
Old 12-04-2008, 10:51 AM   #168
Quote:
ok. If you're on hidplanet take a look in the advanced sticky thread. There is something in there about changing it to a pnp. It's better for cars because the npn uses ground connection instead of power connection. With cars you're using 12v signal to power the leds, having the npn transistor is not the best idea. Here's the link to the thread: http://www.hidplanet.com/forums/viewtopic.php?t=27245
__________________
SHIFT_gone away
Old 12-04-2008, 11:34 AM   #169
Yeah I read about that. Then I thought it was too much work to do.
So I was planning on doing the diagram I posted couple posts above.
Are you changing yours to PNP?
but if I was going to do the PNP transistor route, how would the schematics change?
Old 12-04-2008, 11:43 AM   #170
no i'm not changing it because the way I'm doing it takes the output from the 555 timer to the sharp. Don't even need the lm317 on the pwm for my application. If you're going to use the pwm from quikar I recommend modifying it to the pnp transistor. Its a safer bet for your car.
__________________
SHIFT_gone away
Old 12-04-2008, 11:59 AM   #171
I'll consider what you said, so I'm going to think of how to wire these things up now. Also write a list of what I need.
__________________
5SPEED swap finally done (3/30/07)
|Popcharger|5spd swap|AE headlights including corners|Kevlo911 STS|RAZO340|Cleared out tails|Ebay Fogs|Clear corners|H-tech on GR2s|Progress RSB|Warpspeed Y-pipe|FSTB|Custom Audi style LED headlights|Custom Catback exhaust|More to come|
Shift_Having fun
My cardomain site
Old 12-04-2008, 02:09 PM   #172
what do you mean how to wire them up? The led arrays?
__________________
SHIFT_gone away
Old 12-04-2008, 09:32 PM   #173
No the schematic of the board to the LED arrays.
Old 12-08-2008, 01:40 PM   #174
im looking 4 some angel eyes 4 a 95 maxima.
reese4 is offline   Reply With Quote
Old 12-08-2008, 01:43 PM   #175
Old 12-08-2008, 02:38 PM   #176
Coolsaber57's Avatar
Noober alert.
__________________
1996 Maxima GXE "My boy blue"
TS ECU|RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
Coolsaber57 is offline   Reply With Quote
Old 12-08-2008, 06:55 PM   #177
The Original CF Maxima
Flava_24/7's Avatar
You will have to make them, no one sells them for the max..
http://www.geocities.com/jvxdriver/eagle_eyes.htm
But even if you do make them, how are you going to attach them? There also going to look extremly retarded in halogen housing with a halogen bulb shooting through them.
__________________
Chumps try to imitate but can never duplicate
377hp 338tq
Flava_24/7 is offline   Reply With Quote
Old 02-19-2009, 11:14 AM   #178
Little Asian
kkozy1982's Avatar
Send a message via MSN to kkozy1982
what happened to all the pictures?
kkozy1982 is offline   Reply With Quote
Old 02-19-2009, 12:18 PM   #179
Quote:
I don't know what you are talking about, but they should all be visible. I haven't taken them off of my photobucket account. If not it's on my hard drive at home (I think).
__________________
Shift_Having fun
My cardomain site
Old 02-19-2009, 03:11 PM   #180
Pointy Elbows
00MaxSE's Avatar
Send a message via AIM to 00MaxSE
I can see them
00MaxSE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
