Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 09-06-2008, 01:34 PM   #1
Send a message via AIM to GStrength
Quality bump stoppers
I'll keep it simple. I recently dropped my car 2.2 inches in the front and 2.0 in the back. I changed my ball joints with cheap ebay ball joints a month ago. I noticed an annoying squeaky noise from the front under the car. It's coming from both driver and passenger side. When I inspected the vehicle, I noticed that both bump stoppers some how came loose and became stuck at the bottom of the strut. So I cut the bump stoppers off and now I dont have any on my front suspension? I assume that perhaps my struts are traveling to far and possibily causing a squeak noise, I have noticed struts making a squeak noise on other cars when travel is excessive. What is your take on my situation?
__________________
SHIFT_iMEVI
GStrength is offline   Reply With Quote
Old 09-06-2008, 02:22 PM   #2
Peak a boo.
bigpulve's Avatar
Send a message via AIM to bigpulve
You most likely have bad sway bar endlinks.....that is a common squeaker. But its not advisable to drive with no bump stops......just get some OEM ones and cut them to fit right.
__________________
Bros Before Hoes!!!!!!!!!!!!
bigpulve is offline   Reply With Quote
Old 09-06-2008, 02:34 PM   #3
What kind of ball joints did you get? Some of them you are supposed to pack with grease before you install them.
__________________
All stock.
MorpheusZero is offline   Reply With Quote
Old 09-06-2008, 09:48 PM   #4
Are sway bar end links supposed to have allot of play or no? When my tire is off I can move them rather easily. Is that normal for the end link to move front right to left with no force?
__________________
SHIFT_iMEVI
Old 09-06-2008, 10:42 PM   #5
I havent had bump stops for several years now. My Konis are still doing fine.
Nismo is offline   Reply With Quote
Old 09-07-2008, 12:09 AM   #6
Send a message via MSN to khantalha Send a message via Yahoo to khantalha
Quote:
+1
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Day/Grocery Getter) = sold
myspace.com/shady_aftermath_
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
khantalha is offline   Reply With Quote
Old 09-07-2008, 10:09 PM   #7
ok so i replaced my sway bar end links with moog, but the squeak continued. I'm going to change out the lower ball joints and replace the cheap ebay ones with a pair of moog ball joints. second i'm going to change all the bushings too. do you have to put any grease on the bushings when installing new bushings?
__________________
SHIFT_iMEVI
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
