09-05-2008, 06:44 PM
How to lower car like 3-4 inches budget way???
I want to know what you guys know about springs that give you that(3-4 inches) i know about coilovers but i think its too expensive  where i can get lowering without paying too much.
Right now im running stock springs with kyb shocks.
__________________
09-05-2008, 06:47 PM
there is a member on here known as euromax, he is selling his airbags for $600
09-05-2008, 06:51 PM
Just cut the springs in half and you'll be good to go
__________________
My Quest To Build The Perfect Sport Luxury Sedan
Progress RSB, Otto FSTB, Toyo Proxes 4, Eibach Springs, Illumina Shocks, 6th Gen Brakes Rotors/Calipers, Custom SFCs, Chassis Foam soon, ES Poly Bushings Waiting to go in
My Car Domain Page
http://www.cardomain.com/ride/2340299
09-05-2008, 06:52 PM
cut tein springs maybe
__________________
09-05-2008, 06:59 PM
A32shop.com
there is no way to do it properly and cheaply. the closest way would be to buy sprints or s techs and cut coils but this is not recommended for a number of reasons. it messes up suspension geometry (unavoidable with any type of low drop) as well as limiting strut travel and giving you unpredictable spring rates. you will also most likely run through axles quicker because of the harsh angles, which will cost you money and time in the long run.
09-05-2008, 07:07 PM
DONT CUT YOUR SPRINGS!!!!!
Thats an extreme no-no, but the only way ur going to get a really low drop is to go with coilovers. look in the FS section there were some ground controls that just got sold for $200
09-05-2008, 07:13 PM
yea dont cut them... heat them up it works better
__________________
09-05-2008, 07:15 PM
cheapest way i've seen to completely slam your ride is to take the wheels off.
09-05-2008, 07:22 PM
What blackonblackaction said. Even if you did somehow lower it 3-4 inches your axles will be blowing left and right, which will get expensive and/or annoying to keep changing them.
And honestly I think we only have about 2.5-3" (if that) of compression travel from the factory AFTER trimming the bump stops (1.5-2" before, tops), so in order to even get the car lower than that you will need to shorten the struts which the only way I know of doing involves buying Konis.
If you can handle the geometry issues and replacing the axles (cheapo lifetime warranty axles from Autozone maybe?) every month, then your best bet would be coilovers.
__________________
All stock.
09-05-2008, 07:23 PM
I'm nutty for Nissans
tein s techs are rated 2.2" drop and rest on the bump stops. anything short of coilovers or shorter konis will keep you from going that low.
__________________
-Jon
Daily driver: 98 Maxima SE ... Best E/T: 14.9, Best trap: 95
06 Drag car: 91 Sentra SE-R ... Best E/T: 13.1, Best trap: 110, 2.2 60' R.I.P.
08? Drag car: 94 Sentra E ... In the making
09-05-2008, 07:27 PM
A32shop.com
bump stops are for pansies.
everyone's probably right though... short of full tap coilovers you might not be able to go that low period.
09-05-2008, 07:50 PM
Buy a differnent car, Porsche perhaps or a Ferrarri. That will get you the drop you want.
09-05-2008, 08:07 PM
as crusher said and many others did as well...i would say get coilovers and a body kit that will give you the drop you want... oh and theres no cheap right way of lowering your car to that per say level. save and do it right.
09-05-2008, 08:14 PM
Use the Search Function!!
You gotta pay to play. Try www.ingdirect.com
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
09-05-2008, 08:20 PM
Thinks he owns a sports car
Consider smaller tires combined with lowering springs. These worn 215/45 tires got me an extra 1" drop. Other sizes can get you as much as 1.3".
09-05-2008, 08:43 PM
^^^ i think this is a good way. But dont go cutting s-techs. Or just save up and do the coilovers, i heard its worth the pennyzzzzzz.
09-05-2008, 08:44 PM
no cheap solution without sacrificing quality and safety..
there are ghetton ways:
heating your springs
cutting springs
old school spring clamps ( clamping 2 "coils" together on the spring)..
but all the above, I would NEVER recommend..
like they say, you want to play? the pay
09-05-2008, 08:59 PM
lol i got some K sport springs u can have LOL.. and some struts.. some blown.. all for 100 LOL
__________________
A Car is just like Underwear... it just not Right to share it....
09-05-2008, 09:01 PM
SLOW
4" lol.
3" on coilovers leaves virtually no suspension travel. 4" is borderline impossible and would be completely undriveable unless even with coilovers.
This is 2.75" on GCs with AGXs and bumpstops cut to 1/4 of their original size - and it was pretty uncomfortable. These tires were undersized @ 235-40-17 instead of 235-45-17 in the first picture.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto Drag Radials
3.5L - I/Y/E - USIM
13.26 @ 101 - 1.80 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - stock 3.0L - I/Y/E/MEVI/JWT ECU - Totalled
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Totally Stock - winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
09-06-2008, 09:06 AM
Thanks for the input guys wery helpfull
__________________
09-06-2008, 09:35 AM
A32shop.com
Quote:
4" lol.
lets keep the information correct. 3-4" may be impossible and/or undriveable on single tap or sleeve coilovers, but can be done on full tap coilovers without compromising suspension travel. that is not to say other aspects won't be extremely affected, but it is not impossible.
09-06-2008, 10:07 AM
Maintenance Monster
Possible or not, it's patently stupid.
09-06-2008, 12:15 PM
why go through all that trouble of springs etc? Wouldnt getn an air ride/ air bag system give him the drop he wants? I dont think 4" would be very good drivability but 3" maybe if done right.
__________________
 Scoobz
95 Maxima SE *sold 9-16-08*
06 Sentra SE *til i buy my next MAX*
09-06-2008, 12:30 PM
A32shop.com
Quote:
lets not mix fact with opinion, especially arrogant blanket ones. the only thing stupid is to go into it without understanding of the consequences. once the pros vs. cons have been evaluated it is up to the owner of the car to make an informed decision for or against.
09-06-2008, 01:23 PM
lol......lol
09-06-2008, 01:42 PM
