Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 09-03-2008, 05:21 PM   #1
R34 Retro w/ s2000 projectors and infinity j30
after over a month of working on this project I am almost finish.
Here is a thread I started over on hidplanet http://www.hidplanet.com/forums/viewtopic.php?t=42823
major props to hidplanet and the first thing i suggest for anyone to do a retro is to read, read, read and if you think you know read some more. I spent over a month learning and researching before I even thought about what I wanted to do.
once I finally figured everything out I wanted the best projectors we could fit into out car which are the projectors coming out of the Honda S2000. They are the brightest and widest projectors behind the ls430 (but the ls430 are wayyyy to big to fit into our headlights)
However, the s2ks are only low beam so you either have to give up high beam or buy some headlights that have separate high/low. Therefore I bought some R34s over from ebay for under 200. Or you could use a bi-xenon projector which has both the low and high built in. The bext is the one from the Acura TL but are kind of big and requie a LOT of cutting. the fx35 with tsx lens are the second best and fit into the stock or cefiro headlights.
So with my r34 housing and s2ks, I also bought the halogen projectors that come from the infinity j30 to use the high beam from it.
I used JNC's method (over at hidplanet) of attaching the projectors to the assembly
The process of putting them in there took a month and two dremels. The s2ks and j30s barely fit in there. You really have to trim the projectors down to fit in.
Here are outpictures.
notice how there is no light emitting above the cutoff. Hence why you NEED to use projectors when you use HIDs
jessea510 is offline   Reply With Quote
Old 09-03-2008, 05:24 PM   #2
This is the low
and here is the high beam
Old 09-03-2008, 05:24 PM   #3
Send a message via AIM to phatryan69
dont look to bad i like it though nice job
phatryan69 is offline   Reply With Quote
Old 09-03-2008, 05:33 PM   #4
$180 for r34 from ebay
$150-350 for s2ks. 150 for both if you get lucky at a local junk yard or 350 on ebay or hidplanet
$130 for OEM phillips bulbs
$150 for ballast and harness
$25 for infinity j30 headlights but you only need the high beam
to give you a sense of light output: our stock maxima headlights use 9004 bulbs which put out 700 lumens low and 1200 lumens high(i believe)
an OEM phillips d2s bulbs puts out 3200 lumens (thats almost 5x the brightness and a lot wider) and 1700 lumens for the 9005 halogen bulbs the j30 high beam projector use
However, I am using RARE OEM phillips DL-50 bulb which put out 5300 lumens !!! and HIR bulbs for high which put out 2300 lumens + a catz zeta system which impoves the voltage going to the high beams from about 13v to 15.4V. therefore the high beam puts out about 3200 lumens!!!
In total its 5800lumens low(bc i forgot to mention I am slightly overpowering the dl50 bulbs with 55w ballast =) ) and 3200 lumens high per side. if everything was tunred on it would be 18,000 lumens. and the fogs which i NEVER use
I drove on the 5 freeway here in cali and my lights would have spread three lanes to each side if there were 7 lanes. and goes a good 75-100ft ahead of me.
ps I recommend using halogen bulbs for high bc when you flast someone it they automatically turn on. If you would use HIDs this is a no no.
also, you have to use a diode when you have separate high/low beams to keep the low on when the highs are on
Old 09-03-2008, 05:35 PM   #5
Send a message via AIM to A32MadMax
those are huge!!!
A32MadMax is offline   Reply With Quote
Old 09-03-2008, 05:44 PM   #6
the high beams are pretty big at 3" and s2ks are 2.5". The length of the j30s are pretty long too, I think over 5"s I believe. I haven't put a shroud to cover them up either. I also have to play with the lens a bit bc the cutoff is not that sharp
Old 09-03-2008, 06:13 PM   #7
That's pretty ridonkulous--my kind of setup.
__________________
All stock.
MorpheusZero is offline   Reply With Quote
Old 09-03-2008, 06:16 PM   #8
Quote:
yea man nice job its good to know people r stillin most of their own work out there
__________________
Drive Fast Live Fast
SHIFT_kinoki(don't ask inside joke)
96 Nissan Maxima SE 5SPD 128K
Full Warpspeed exhaust
Nitrous on its way
00vi if funds are right
96nismoSE is offline   Reply With Quote
Old 09-03-2008, 07:06 PM   #9
The JDM Rat.
timmay5835's Avatar
holy !!! that output is crazy! nice work but cops dont give you any trouble?
__________________
Granny's GLE, its stock i sware.
4th gen OWNZ ALL!
timmay5835 is offline   Reply With Quote
Old 09-03-2008, 08:16 PM   #10
saw this on HIDplanet the other day - looks nice!
How do you think the bulbs will hold up to being overdriven?
__________________
'97 Neptune Blue SE 5spd
nalc is online now   Reply With Quote
Old 09-03-2008, 08:20 PM   #11
Jedi Knight Academy
Send a message via AIM to maxprivate
Quote:
Originally Posted by jessea510 View Post
This is the low
Sweet job man. I was on the same boat.. did plenty of research on hidplanet.com and even made my own harness. I love that place, I went with the TL bixenon and zkw lense swap and I custom made a high beam projector out of the zkw housing. So it looks like I have 2 projectors. it took lots of time to do I agree. I notice that the spacing of your projectors beams look to close together on the wall. what's the distance between the two steps on the wall? should be somewhere between 3' to 10'
maxprivate is offline   Reply With Quote
Old 09-03-2008, 08:22 PM   #12
Jedi Knight Academy
Quote:
Its all Oem stuff so I shouldn't give any problems at all.
Old 09-03-2008, 09:06 PM   #13
i agree, you shouldnt have probs at all.But who knows, some cop might just be bored. Nice setup btw.
__________________
*Cheap T-mobile Phone
http://forums.maxima.org/other-sale-...-t-mobile.html
Nov-2008
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Nov-2008
Snypa is online now   Reply With Quote
Old 09-03-2008, 09:34 PM   #14
Carbon Fiber addict
Quote:
I've always wondered if there was a standard, or a best distance for the 'steps'. Just curious, but where did the 3' to 10' measurement come from??
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
The Wizard is offline   Reply With Quote
Old 09-03-2008, 10:48 PM   #15
Distance between flares on the wall will vary with distance from the wall, and it will ideally be the same distance that your projectors are apart (they will both be pointing straight ahead), so around 5'.
Jesse's setup is a bit cross-eyed so the flares will actually converge depending on how far away the surface they're shown on is.
__________________
All stock.
Old 09-03-2008, 11:21 PM   #16
The Man is watching.
Send a message via MSN to maximase86
Do you have pics of how the car looks with the new projectors? How about the finished housing? Either way those look awesome. Good work!
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails - Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is online now   Reply With Quote
Old 09-04-2008, 05:08 AM   #17
Jedi Knight Academy
Quote:
just a general guideline I got from hidplanet.com at 25' you should have a distance of 3 to 10' and that's providing your projectors are mounted straight.
Old 09-04-2008, 09:49 AM   #18
192.168.1.1
gtr_rider's Avatar
Looks great, seems you went the same route as I did.. Did you follow JnC's mounting procedure?
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline   Reply With Quote
Old 09-04-2008, 09:53 AM   #19
I've actually re-aligned the projectors since then so they both go straight for about 100ft or so.
The bulbs are not actually from any car but they are TRUE 50w bulbs in the sense that they are not some cheap chinese bulbs but rather Philips bulbs. They are supposed to be used on home projectors but it happens to be an almost direct size and base as D2s bulbs. As for the high beams a few cars do come with HIR bulbs HOWEVER, I'm am boosting them by supplying them with 15.4v with the catz zeta system.
People have measured the heat coming from the dl-50 bulbs and there is only like 10deg. f. difference over regular 35w bulbs. I've driven them for over 30hrs so far and everything is good(I had them on for as long as three hours straight and all is good). If you use cheap 50w chinese bulbs than those can really do damage to the bulb.
Again, I'm not finish with it but I will try to take pictures with them on my car.
As far as cops go, along as they are aligned properly they shouldn't be a problem because as you can see no light is emitted above the cutoff so you don't blind people unless you go over a speed bump or hill. I've haven't been flashed and I've passed a lot of cops and highway patrol with them here around LA and in Sacramento and no issues whatsover.
Old 09-04-2008, 11:21 AM   #20
they look very nice, light output wise
how do they look on the car?
__________________
Car Ramrod
Don't tase me bro!
SHIFT_3.ooohhh
fat_kid is offline   Reply With Quote
Old 09-04-2008, 05:08 PM   #21
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Thats nice. I love thes2K but cant foot the price.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE 343whp/356wtq Turbonetics 60-1 @18psi,SAFCII,r33 full kit,Acura TL retroed headlights.Innovate LC1 wideband O2
Spec Stage 3 clutch, 550cc DW injectors,MEVI.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 09-04-2008, 07:26 PM   #22
Jedi Knight Academy
Quote:
Come on bro with all those led tails you make you cant afford it?
Old 09-04-2008, 08:04 PM   #23
Its not that i cant afford them i just refuse to pay for them. My E55's are serving me just fine.
__________________
Led retro's Pm me
Old 09-04-2008, 08:20 PM   #24
Jedi Knight Academy
lol I hear ya man just messin with you.
Old 09-04-2008, 08:39 PM   #25
Send a message via AIM to Camfantasy
how about a write-up?
__________________
99 SE-L FULLY loaded-17 G35 sedan wheels-R34 headlights-6000k hids-red/clears-PR style cold air intake-Warpspeed y pipe-Test pipe-Greaddy sp2 catback-Raxles-H&R/Illuminas-FSTB-VAFCII(not tuned yet)-Blemco groundkit-Panasonic indash-idmax 12" sub
Camfantasy is online now   Reply With Quote
