Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 08-26-2008, 08:10 PM   #1
Send a message via AIM to 97ka-t
Starter Problem? I thought so! Replaced twice so far... Help!!
1996 5spd Maxima - Long story short- the car was running just fine, starting no problem. The next day, the starter would not engage with the flywheel. The car will start as long as it is pushed a bit (as is typical with a bad starter). The flywheel is in grade A condition. The starter was replaced with an Advance Autoparts one and the same problem occured. It was then replaced with an Autozone starter, and the same problem is still present. Is it a bad ground? All wires are connected... I don't know what else to do here. Any help would be greatly appreciated!
97ka-t is offline   Reply With Quote
Old 08-26-2008, 09:16 PM   #2
Well from reading around the org, hitting it normally helps, but your being so new, that shouldnt be the case. I say grounding issues. Lets hear what others say.
__________________
*Cheap T-mobile Phone
http://forums.maxima.org/other-sale-...-t-mobile.html
Nov-2008
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Nov-2008
Snypa is offline   Reply With Quote
Old 08-26-2008, 09:49 PM   #3
Check and make sure that you are getting power to the starter. It could be that you have a short in the power line.
thedwyer00 is offline   Reply With Quote
Old 08-26-2008, 09:54 PM   #4
NOT Banned
JSMax's Avatar
Send a message via MSN to JSMax
or that autozone starter was re-built by someone getting paid like $1/day to rebuild those. Chances are those are going to be crappy and they will keep failing on you. Suck it up and purchase a factory nissan rebuilt one.
I personally have gone through 3 autozone starters for my nissan in the past 2 years and finally swithced to a nissan dealership one. It's all good now.
good luck.
__________________
JSMax is offline   Reply With Quote
Old 08-26-2008, 09:57 PM   #5
could be your alternator also... get that checked.
__________________
Mods installed: 00vi, Megan Headers/Y-Pipe/Street Pipe, Pacesetter B-Pipe/Cat/Muffler, JWT ECU Upgrade, OBX Underdrive Pulley, FSTB/RSTB, Rear Sway Bar + Much More... And More To Come
mista0406 is offline   Reply With Quote
Old 08-26-2008, 10:18 PM   #6
CLICK CLACK 1
I would check for proper ground first and also batt. terminals.
__________________
CLICK CLACK
rm4628 is offline   Reply With Quote
Old 08-27-2008, 05:32 AM   #7
Quote:
so does the starter "spin" but dont turn the flywheel?
or does the starter do nothing?
by your post it sounds like the starter is engaging but not turning the flywheel,if this is the case you could have a bad spot on the flywheel. a lot of people will take the starter off and see the teeth and think the rest of the flywheel is ok...this is not always the case. with the starter off you will want to mark the flywheel and then manually turn it all the way around to confirm all the teeth are good.
usaully you will get some warning of this happening in the form of "grinding" when you start the car sometimes.
if the sarter does nothing ,the 1st thing would be to check if the switch wires(at the starter) is getting power when you turn the key to "start" position and go from there.
hope this helps
alset2 is offline   Reply With Quote
Old 08-28-2008, 10:29 AM   #8
The ground is good. It's getting enough voltage. It's set properly with the flywheel. I just don't know what's going on with it!
Any more ideas?
Old 08-28-2008, 01:04 PM   #9
What do you mean when saying "the starter would not engage with the flywheel"? Is it spinning freely without rotating the flywheel?
What actually hapends when you turn the key?
shilov is offline   Reply With Quote
Old 08-28-2008, 07:16 PM   #10
Yes that's what happening - when you crank it, the starter is turning but not engaging. Something with the connector at the ignition? It was running just fine before. Started without problems. Idled fine.
Old 08-28-2008, 07:23 PM   #11
Newbie-Just Blazed
Send a message via AIM to QNO_A32
it might be spinning but not pushing the gear out. it is a cheap starter try another one.
__________________
SHIFT_ A REBUILT TRANNY
QNO_A32 is offline   Reply With Quote
Old 08-28-2008, 07:34 PM   #12
The same thing happened with my original OEM starter. I just don't understand how that can happen with three starters, one of them being OEM. The teeth on the original OEM starter are in fine condition. No shorts in the wires, etc.
Old 09-07-2008, 01:21 PM   #13
Send a message via AIM to Abelman
I think I'm having the same problem - I just replaced my starter for the second time. The first time I replaced it, it gradually got worse and worse and then didn't start at all after 3-4 months. The new one is starting but doesn't sound right and seems like it's headed in the same direction as the previous one.
My mechanic tells me that he's seen this problem before with other maximas and that the transmission may need to be taken out and cleaned.
Any thoughts on this?
thanks
Abelman is offline   Reply With Quote
Old 09-07-2008, 03:27 PM   #14
You need to use an OEM starter. I can not tell you how many after market starters Ive seen fail.
SE-R_Tech is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
