08-24-2008, 02:49 AM
Mystery Part - "white box" under dash
About 2 years ago I busted a little white box under the dash (rolled over on it while working under the dash) and I was consumed with what I was doing and it didnt seem to bother anything so I chunked it into the moutain of other screwed up parts. I've since been unable to find it and I badly want to replace it now. It was located behind the bottom panel under the steering wheel, I think
Only things I have noticed that arent working due to that box is the light ring around the key, auto on dome light, and possibly the door chime. I might have removed the chime myself becuase chimes sound gay.. but I dont remember it was so long ago and chimes are the first thing I remove from my rides.
I've searched and searched for that stupid little box because I want my light ring back and my auto on dome but I dont know exactly what to call the sucker.
Anyone with a proper name for that "white box" or a part number will be my new hero
08-24-2008, 03:31 AM
that little white box is for the door chime and thats all not sure what the name or the part # is... hope this helps.
08-24-2008, 10:22 AM
The Dirty Pearl
As mista0406 said, that box does nothing but sound the chime for headlights on, key in ignition, etc.
I'll see if I can't dig up the part number.
08-24-2008, 11:22 AM
Par-mi-gian-o
Yeah, pretty common part for people to unplug because they hate the chiming. Personally I feel like it's there for a reason. It's saved me many times from leaving my keys in the ignition.
08-24-2008, 11:36 AM
You can have mine if you want it...
08-24-2008, 11:42 AM
Don't be worried it's not really necessary as the other members said and explained.
08-24-2008, 02:52 PM
Quote:
Thanks for your help but I am now left with the question as to why my light ring around the key and the auto feature on the dome light dont work. Of course I checked the bulbs.. not the issue. I figured those might be tied in with that box in some way.
08-24-2008, 02:54 PM
Quote:
Seriously?? You accept paypal
08-24-2008, 03:08 PM
The Dirty Pearl
Quote:
I believe both of those functions are controlled by the BCM.
Put any LEDs in your window switches lately?
08-24-2008, 04:59 PM
 nor do mine....
08-24-2008, 05:26 PM
it's probably a fuse but I'm not sure cause I disconnected my chime box and my lights all work.
08-24-2008, 05:41 PM
No window switches yet.. waiting on SMT's and resistors. I do however have a LED in my dimmer control switch, security light, cluster and the gear selector. I while back I tried to hook up an LED into the Cruise switch and now my switch isnt working.. got to order another one. You think the LED's or the broken cruise switch could be to blame? Those lights went out the same time I broke the chime box and started modding with LED's.
08-24-2008, 05:46 PM
 nor do mine....
Yours not working either ehh  Have you tried connecting the chime to see if they start working.. some say the box isnt the issue but the box on my 99 didnt just have a chime it, also had a small board of electrical goodies in there and the board snapped in half.. part of the reason I chunked it.
09-07-2008, 01:38 PM
Jedi Knight Academy
cruise control led
Does anyone know the polarity + and - terminals looking at the switch when its apart? There are 2 bulbs in there and looking at the switch the terminal are left to right. How about dimmer switch ? Dimmer switch has the terminals up and down like the harzard switch. looking on putting leds in there.
09-07-2008, 02:26 PM
hey, if you still need it, pm me and ill mail it out to you. i hate that stupid little box haha
09-07-2008, 06:07 PM
The Dirty Pearl
Quote:
I assume when you checked it with a multimeter, it proved inconclusive?
09-07-2008, 06:25 PM
Jedi Knight Academy
I saw your original post.. and instead of trying to be a sm@rt @ss you should think of something positive to say. If you look into this thread someone mentioned earlier they put leds in their cruise control switch , which is the reason I posted my question.
09-07-2008, 06:29 PM
The Dirty Pearl
I have something very useful to say.
When you checked the switches with a multimeter, could you not figure out which lead was positive and which was negative?
Of course, you did try that, right?
Besides, this thread is not about putting LEDs in switches, it's about diagnosing a different problem. You've got more than enough posts to start a new thread with your question.
09-07-2008, 06:36 PM
Jedi Knight Academy
So why pick on me? SOMEONE else changed the subject earlier and he wasn't bashed  anyhow how can you determine which is negative on the copper terminals with no power applied to it? I don't think you can unless you know something I don't. I have the switches in my house and was hoping someone that has done it would know off hand. Besides I don't feel the need to start a new thread when I can search and ask questions. I know many have done this before.
09-08-2008, 04:12 AM
Old Maxima Legend
Quote:
hey nice A32 you got there !
__________________
N/A - 97 SE - VQ30DE - 93 octane
13.8 @ 98x - 2.06 60' - USIM
13.5 @ 101 - 2.10 60' - OOVI/EU
N/A - 97 SE - VQ30DE-K Swap
TBA
09-08-2008, 04:21 AM
The Dirty Pearl
I assume you've tried checking continuity between the solder pad and the ground pin on the connector (or the ground layer on the PCB)?
Likewise, checking continuity to the connector pin where the switch receives power?
09-08-2008, 04:30 AM
Jedi Knight Academy
This is exactly what I'll do. I'll just check the connector pin for neg and pos. I was just trying to see if I can get an answer without having to go to the car. Thanks for the help though.
09-08-2008, 04:34 AM
The Dirty Pearl
No need to go to the car, just take a look through EL and it'll show you what pins are power and ground.
