Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-23-2008, 12:44 AM   #1
Send a message via AIM to MaximaPimpin
KS, MAF, or something else? I'm stumped.
Lately I have been noticing that when sitting on red lights that my RPMs drop 100-200 rpms and then go back up to the regular idling RPM. It also makes little popping sounds out of the muffler and shakes the car every now and then very softly. This problem stops when car is in motion but in 2nd gears if the pedal is pressed more then half way it begins to jump a few times through 3-4k rpm and other then that runs fine. The other unusual problem is that it doesn't do it constantly but at random times, some days doing it all the time and others running completely normal. Does anyone have any idea on what this may be? I appreciate in advance for all the help.
__________________
MaximaPimpin is offline   Reply With Quote
Old 08-23-2008, 12:54 AM   #2
UnPr3d!cT@bL3 M@X !!!
JonBlz's Avatar
Send a message via AIM to JonBlz
a bad coil, check sparks, maf, bad injector check all that
__________________
Y0u kNoW Wh@T !t !$ !!!!! Money/Cash
^^R.I.P to my 99 maxima in Jan09
came back with an 02 maxima SE 6 spd nov 09
JonBlz is offline   Reply With Quote
Old 08-23-2008, 07:05 AM   #3
Send a message via AIM to |3ourne Send a message via Yahoo to |3ourne
while your at it , also check the camshaft position sensor , its on your left hand side of the engine if you are looking at it. Mine was bad and my car would drop down to like 400 rpms and then just shut down at the traffic light. Took me like a week to figure it out. Unless you have a SES for your MAF or KS , chances are , they are fine.
|3ourne is offline   Reply With Quote
Old 08-23-2008, 07:29 AM   #4
before you check into all these suggestions, which i might add are not bad ideas. i would start off simple first. is your cel light even on? have you scanned for codes? have you cleaned your iavc lately? is all your vaccums hooked up right?
__________________
97 Maxima GXE Totalled
96 Maxima Se Blown 3.5 New one coming
90 B12 Sentra My new winter beater
Product_Of_Korea is offline   Reply With Quote
Old 08-23-2008, 10:02 AM   #5
^^^^^^what lock nuts said check all your hoses make sure they are free from kinks or leaks.
__________________
Mods installed: 00vi, Megan Headers/Y-Pipe/Street Pipe, Pacesetter B-Pipe/Cat/Muffler, E-Manage Blue, OBX Underdrive Pulley, FSTB/RSTB, Rear Sway Bar + Much More... And More To Come
mista0406 is offline   Reply With Quote
Old 08-23-2008, 12:36 PM   #6
probably a bad coil thats starting to misfire.
__________________
vilmaxima is offline   Reply With Quote
Old 08-23-2008, 02:04 PM   #7
sounds like a COIL or the cam shaft sensor..check it first
fulloboost is offline   Reply With Quote
Old 08-23-2008, 03:51 PM   #8
As far as codes there are no codes which just makes the troubleshooting more of a pain in the ***. I have a feeling its a coil too since it only misfires in 2nd but i will definently check all the hoses and the cam shaft sensor and everything else listed. I know its not the sparks because they are about 10 month old NGK iridium plugs.
__________________
Old 08-23-2008, 05:07 PM   #9
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
I think it's the coil since its misfiring. Sucks that theres no codes, good luck though.
__________________
http://www.cardomain.com/ride/3135334______http://www.cardomain.com/ride/3171620
4th gen. items FS:
-2 sets of 9004 bulbs ($10/set).
-1157 red LED bulbs ($5).
-OEM bumper lights ($20).
-License plate light assembly ($10).
-PM me if interested.
-Shipping/PayPal fee not included..
ChrisMan287 is offline   Reply With Quote
Old 08-23-2008, 11:05 PM   #10
I'd put my money on coil packs since I had similar problems when I first got my car.
__________________
My 1999 Maxima Bought 8/18/2007. Sold on 9/11/2008@160,XXX miles.
2004 Hyundai Elantra: 73,XXX miles. Bought on 9/11/2008.
R.I.P. 2001 Chevy Prizm-totaled August 13th, 2007 by a 1999 Dodge Ram.(At 76,237 miles.)
Divewjason is offline   Reply With Quote
Old 08-23-2008, 11:22 PM   #11
does it drop rpm just once, or over and over? if gotten hichups from cais before but it only did it once, coils and plugs for repeated dips
BaysideMax is offline   Reply With Quote
Old 08-23-2008, 11:25 PM   #12
Its repeated. Yeah that's what im going with too.
__________________
Old 08-23-2008, 11:35 PM   #13
Send a message via AIM to DaZ910
i hate sounding like a donkey but most of the advice given so far would be incorrect. diagnosing a vehicle without proper information ie. OEM service manuals is pointless. you can drive yourself crazy trying to figure out drivability problems on your own. my opinion on your complaint is maybe you should go to a nissan dealer spend the hundred bucks or so and have them tell you the real source of your drivability problem and then if you can, fix it or replace the compenent yourself.
__________________
DaZ910 is offline   Reply With Quote
Old 08-24-2008, 02:42 AM   #14
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
With the car running unplug a coil pack one at a time and reconnect, if there is no change in the rpm, when you unplug one, that's your culprit. You also have to consider the last time you changed your plugs.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 08-24-2008, 01:18 PM   #15
Send a message via AIM to Ricanprez1 Send a message via Yahoo to Ricanprez1
Quote:
That is the reason why he's on here asking questions. Why spend money for something you could fix yourself or diagnose yourself.
__________________
Ricanprez1 is offline   Reply With Quote
Old 08-24-2008, 09:23 PM   #16
Quote:
Sounds like a good idea, will try that out. My plugs where changed less then a year ago. Sadly I didn't get around to troubleshooting this problem yet as my clutch pedal went soft yesterday and this morning all it was doing was hitting the ground and i couldn't even switch gears. Bleeding clutch fluid in Fayes rain was fun but at least we finally got some pressure back in the pedal to where its driveable until I can get it to my mechanic who will check for leaks. Maybe time to get some SS lines.
Yeah, spending a hundred dollars for a person to tell you whats wrong is kinda out of my budget at this point. Ima broke *** college student so the less money I spend on repair means more i can spend on new stuff for the car. I would rather play around with it and find out whats wrong.
__________________
Old 08-24-2008, 10:01 PM   #17
I seem to have the same problem. RPM drops close to 300 and when i try to acccelerate it wont let me sometimes it just dies. It shakes some and then it dies sometimes the car tries to move forward but then dies. I do know that my drive axles are pretty bad. I was wondering if they get that bad would this be a problem or am i way off. I dont know much about coils or cars for that matter. but i did change the spark plugs about 3 months ago NGk's Iridiums gapped at .44 or something like that.
btw this my first post!
Rob20 is offline   Reply With Quote
Old 08-25-2008, 06:17 PM   #18
Quote:
why spend the money? i would say that with the issue hes having fiddling with his cop system could lead to damage to either the cop or his ignition module.
if you really want to find the problem yourself n on a budget find your self a digital multimeter and a back probe(2 bux at autozone) and private message me and ill try and teach how to self diagnose.
__________________
Old 08-25-2008, 06:45 PM   #19
here's a link to my thread - I'm having the identical problem and a lot of advice has been offered there:
Power Surging During Acceleration (~3000-4500rpm)
rx7racr is offline   Reply With Quote
Old 08-26-2008, 09:31 AM   #20
Send a message via AIM to Slickismax Send a message via Yahoo to Slickismax
First of all, he doesn't have a CEL. The dealership is going to just charge him $100.00 then tell him that they didn't find anything wrong. I've been down that street. I've also fixed several cars over the years without taking them to the dealership, or using a FSM, as have a lot of people on this board. Just because you can't diagnose and fix a car doesn't mean only the dealership can.
Are you serious? The VQ doesn't have a "Ingition Module". It's a disrtibutorless ignition and it's controlled solely by the ECM, and you're not going to damage that by unplugging sensors/coils. Do you even own a 4th gen?
__________________
MCOA #69
Buy from someone who knows what a VQ feels like!!!
www.leatherseats.com
1-866-NEWSEAT
BillC@leatherseats.com
Slickismax is offline   Reply With Quote
Old 08-26-2008, 07:52 PM   #21
I have same problems. Thought they were related, but after I replaced the cat and y-pipe, the acceleration problem went away. The stop light stuttering remains, but I did notice that the grounding strap from O2 sensor was gone. Gonna replace that and see if it helps.
With regards to dealerships, 4 hours of diagnostics, they just shrugged.
Cheeshead is offline   Reply With Quote
Old 08-27-2008, 09:34 AM   #22
i read somewhere on the net someone had same problem and they cleaned the throttle body and the rpm was kept up..im gonna be cleaning mine in a couple of days. maybe it could help solve your problem before you go off and buy more expensive parts to replace
Old 08-28-2008, 03:12 PM   #23
TB was cleaned a few months ago so I doubt thats the problem, its leaning more to be the coils.
__________________
Old 08-28-2008, 07:15 PM   #24
maxgtr2000's Avatar
Had to get an emission's diagnostic, the tech adjusted the iac valve screw, starts up on the first turn every time and overall runs smoother.
Old 08-29-2008, 04:14 AM   #25
May be a possibility. - Iridium plugs have less resistance through them than the original Platinum plugs. Therefore they tend to draw more current through the coil. This may cause the coil to overheat and malfunction after a period of time.
cedric is offline   Reply With Quote
Old 08-29-2008, 05:45 PM   #26
Yup, sadly its not my biggest problem as of right now. I just put in a new Master clutch cylinder and slave cylinder a few days ago and my clutch pedal managed to get stuck all the way down on the redlight and i barely got it to the side of the road. Checked everything out and it seemed fine and it started back up but did it again 20 or so minutes later so i've been trying not to press the pedal all the way down on stops and hold it there which seems to be working but I have a feeling my clutch has gone to hell which sucks since it was replaced around 5-6 months ago with an Exedy. Everything seems to go to **** at once and when you're low on funds. heh.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
