Lights not working???
Niether side clearance lights getting current, nor drivers side running light. Pass. side works. Fuse ok...had 10 amp in there from earlier clearance mod (tin foil) went to nip post on clearance bulbs to fix as foil wouldnt stay in place....can't get anything to work...or figure out whats wrong. Any suggestions?
I dont have a multimeter..just a simple test light. Dint think I have current. I got the marker light working. Got 2 new bulbs for clearance...nipped the nibs...still nothing on either side. 10 amp fuse ok. I was going to just tap into marker lights as theyre on the same switch and fuse...no clue why current not getting there.
Connections seem ok...I looked at relays but not that closely. I did tap into marker light for fog rewire. That was YEARS ago and theyre still fine. Maybe i'll take a closer look. And if not...just try the tap to marker lights.
jerrod99_se-l
08-27-2015 08:27 PM
kjm900r
08-05-2015 07:14 AM
