wierd noise when ac on... help pls
So this is the deal... when i turn on the car in the morning (mainly happens at that time) i hear this sort of like humming noise when i turn on the ac... if i turn it off it goes away... it does not do it all the time but the pattern has been it mainly happening in the morning... after an while driving the noise goes away, any ideas or things i should check out that are causing this noise...
thanks b4 hand...
thanks b4 hand...
This happened to me too but it did it all day, it was a fairly loud humming. I'm not sure what it was or what caused it but it went away by its self somehow. My guess is something just rattled loose.
Chances are, this is your problem (see link). Worth investigating before you take it to a mechanic/stealership
http://forums.maxima.org/4th-generat...any-ideas.html
so i tried that out... didnt see anything in there was clean and what not... someone told me that it could be the same motor of that fan that was causing the noise (to be honest when i heard the noise. i didnt really hear it coming from there...
my wife states that she has heard that noise when the ac is off, and its more towards the driver side...
any ideas??? or something worth checking?
thanks again for any help given.
