secruity problem
Old 03-28-2012, 08:42 PM
adell's Avatar
secruity problem
well i have a 1999 Maxima Nissan, the security feature starts blinking once i open the door and insert the key, but once i crank the car it starts but then the security thingy turns all red and my car doesn't turn on, sometimes it turns on but turns off by itself
any help would be appreciated
adell is offline
Old 03-28-2012, 08:45 PM
TLMNICK's Avatar
99 maximas were the first to get the NATS (Nissan anti-theft system). It consists of a transponder chip inside the head of the key, and a receiver at the key cylinder. If your car is not starting, it's because the car isn't seeing the correct key.
For this car you CANNOT simply cut a key and use it....it must be a transponder key that has been programmed to the car at the dealer.
Some of the 99 maximas have been known to "forget" the keys, and they need to be reprogrammed by the dealer.
TLMNICK is offline
Old 03-28-2012, 08:47 PM
Amerikaner83's Avatar
^^ yeppers^^
I have heard that certain locksmiths can reprogram your key as well, if you want to avoid the dealer.
Amerikaner83 is offline
Old 03-30-2012, 06:19 PM
MrWilson44's Avatar
If you have AAA try calling them and have them send a locksmith, but get in contact with the locksmiths before he comes so he knows whats the problem. Some can help some can't.
MrWilson44 is offline
Old 03-31-2012, 08:23 AM
deloa84's Avatar
That right. Two locksmiths told me they could take care of the problem but when they got to my house and looked at it they were like "WOOPS I dont have the tools to reset it."
I ended up taking it to the dealer unfortunately. To reprogram the module and the key was about 85$ so it was not too bad. keep in mind this was 2 years ago.
This happened again to me but this time the NATS module gave out and they are not cheap!! So far I havent had any issues but if it pursues again... ECU SWAP!!
Good luck
deloa84 is offline
litch
123
01-04-2024 07:01 PM
jmlee44
10-02-2022 02:13 PM
hcarter1112
42
07-18-2022 03:35 PM
gavin68
09-18-2021 12:36 PM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: secruity problem
