RPM SIGNAL for msd switch. HELP NEEDED!
after sending my #8969 msd switch in for a repair, i just got it back, installed it and got the same results again even though it checked out fine for them. rpm display would show for about 5 minutes, then read to zero and stay that way.
i first had it connected to the ECU rpm signal. Then behind the cluster, tapped into the TAM screw. now msd suggests tapping it into the IGNITION COIL TRIGGER wire.
Where can i find this?
and has anyone else been experiencing this kinda of issue? where do you have yours hooked up?
oh so your using a summit, not msd?
well i dunno why i'm having this issue. i don't even know how msd found mine to be alright. and i thought tapping two diff applications on 1 signal wire was not recommended due to possible interference but hey if it works for you then i guess its alright.
i really don't think wiring it another way is gonna help but worth a try.
so i guess you don't know where the ignition coil trigger wire is?
ah ok. well i spoke w/ the 3rd msd tech today and looks like i'm just going to be sending this in again, HOPEFULLY not for a repair but for a replacement. this thing has given me so much headache...
TonyJr
08-20-2015 12:14 AM
MaximaDrvr
08-19-2015 08:20 PM
