Bolts Breaking
Old 06-23-2008, 12:08 PM
Jesse729's Avatar
Bolts Breaking
Every time I do work on my 99 I have bolt heads snap off. Does anyone else experience this?
I did my front brakes this weekend and 4 of the 8 bolts snapped off 2 on the passenger side caliper bracket and 2 on the drivers side. I used PB blaster every time and let it sit and the bolts always snap. I have snapped bolts on my exhaust my exhaust my suspension even the small 10mm bolts/ screws that hold the fog lights snap on me.
I have worked on old cars before and it's never been this bad is there any trick to getting them off.
Jesse729 is offline
Old 06-23-2008, 12:22 PM
Intel's Avatar
Heat is your friend. I go in and hit them with pb blaster for 2-3 days before about every day. Then I hit it and if it doesn't budge I heat it and go at it again.
Intel is offline
Old 06-23-2008, 08:06 PM
redwagon29's Avatar
Yeah I can relate to that. I can't tell you how many little bolts and screws we have replaced in my car over the last few years. I swear they come pre rusted with the car. My dad works on cars and he has even seen newer 2002, 2003 Nissan's come in with really crappy bolts that just get stripped, break off and need to be replaced
redwagon29 is offline
Old 06-23-2008, 08:11 PM
anik151's Avatar
i was chnging my brakes i snaped 2 off after i jus grabed a torch and i heated the rest up and they jus came right off
anik151 is offline
Old 06-24-2008, 08:44 AM
I love lamp.
maximase86's Avatar
Be sure that you have the socket and breaker bar on as straight as possible too. Also you weren't using a rigged cheater bar where you? You have to be careful which those because you might apply to much force on the head. Heat FTW.
maximase86 is offline
Old 06-24-2008, 08:54 AM
'Trynna' is not a word
mtrai760's Avatar
Do you use a torque wrench when re-installing everything? Anti-sieze when required?
mtrai760 is offline
Old 06-24-2008, 01:18 PM
The Russian's Avatar
your just hella strong man......
The Russian is offline
Old 06-25-2008, 01:39 AM
CMax03's Avatar
you need a woman dude!
CMax03 is offline
litch
123
01-04-2024 07:01 PM
D Mason
06-21-2016 04:43 AM
RealityCheck
10-02-2015 06:34 PM
Need help
23
10-02-2015 08:56 AM
Quick Reply: Bolts Breaking
