Intake manifold gasket
Old 06-13-2008, 07:31 PM
Turbo 4th Gen
93altima's Avatar
Well ive had my Dek in for about 1 1/2 months now and i decided to remove the swirl valves. i removed the intake manifolds and took the lower manifold to the nearest machine shop and he cleaned and welded the swirl valve holes for $132.50 after taxes. (ill try to post some pics later) now i have it back and i was debating weather to use the old gaskets or get new ones??? i tried to price new ones, i called the nearst parts supplier and advanced auto parts they both dont sell intake gaskets for a 00-01 Maxima??
93altima is offline
Old 06-13-2008, 07:36 PM
hot_wax_tree's Avatar
well how bad are the old one's?
just get a vin off a 00-01 and tell that to nissan it prob isnt that much for the gasket.
if you have no cracks, tares or swelling you are fine.
hot_wax_tree is offline
Old 06-13-2008, 07:55 PM
oem ftw!
CRiME's Avatar
when I did the VI swap I used new lower intake manifold gaskets and I also used a new upper IM gasket. Also, though it's not mandatory, I applied a small bead of copper RTV in addition to the LIM gaskets. Didn't use any RTV on the UIM gasket. Everything worked out fine with no leaks. New gaskets are worth the money in the end, to rule out the possibility of a massive vac leak after you put everything back together!
that's odd that they didn't have them in stock, the local dealerships around here had them in stock and didn't need to order them. If you're unable to track the gaskets down, you can clean up the old ones, reuse them and apply some RTV as cheap insurance.
CRiME is offline
Old 06-13-2008, 08:05 PM
dot dot dot ...
NmexMAX's Avatar
Are you certain you asked for the correct product?
NmexMAX is offline
Old 06-14-2008, 01:19 AM
Turbo 4th Gen
93altima's Avatar
yes when i asked they said its a dealer part
93altima is offline
Old 06-14-2008, 02:15 AM
dot dot dot ...
NmexMAX's Avatar
Aren't they the 'dealer'?
NmexMAX is offline
Old 06-14-2008, 07:15 AM
maximabebe's Avatar
Well check out the nearest Nissan dealership's parts dept. If you're willing to drop 132.50 on cleaning swirl valves then you should be ready for Nissan's price on a DEK UIM gasket. I'm assuming its in the area of ~$40.
maximabebe is offline
Old 06-14-2008, 08:33 AM
Product_Of_Korea's Avatar
rockauto.com 6.16+shipping for the upper . but in all honesty you could probley reuse the gasket for the upper. but i would deffently get new ones for the lower when i did mine it cost about 30 bucks a peice from the stealership. i know i over paid but i paid for the convience of having it that day
Product_Of_Korea is offline
Old 06-14-2008, 08:53 AM
Turbo 3.5
t6378tp's Avatar
he did not go to the dealership, so with that said go to the dealer
t6378tp is offline
Old 06-14-2008, 04:31 PM
Turbo 4th Gen
93altima's Avatar
Heres a pics with the Cleaned LIM
http://s267.photobucket.com/albums/i...0614081600.jpg
http://s267.photobucket.com/albums/i...0614081601.jpg
93altima is offline
aw11power
10-10-2021 04:57 AM
knight_yyz
11-01-2015 01:34 PM
JonBlz
10-05-2015 06:02 PM
MichMaxFan
09-30-2015 09:18 AM
dshinn
09-26-2015 08:07 PM
Quick Reply: Intake manifold gasket
