Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 06-13-2008, 12:05 PM   #1
Send a message via AIM to G4nismo
HOW-TO: Install white LEDS for your AUTO Gear selector
Haven't seen anyone do this yet, so i figured i give this a shot.
TOOLS NEEDED:
Soldering iron
Rosen core
6 White 3mm LEDS (preferred) or 5mm LEDS
6 470 Ohms resistors
Breadboard
Dremel
sand paper
Flat head screwdriver
Hot glue gun
Heat shrink
Snap or slide connectors
First, remove the gear selector trim from the car. Remove the shifter trim, then remove the 4 screws holding the gear selector trim. Then remove the bulb socket. the gear trim is held by 4 plastic tabs, just lightly pry each one around. Disassemble like shown:
second, cut out a piece of the breadboard to fit it in the gear selector like so.
Goal is to try to get it sitting as low as possible so more light output can dissipate to reduce hotspots.
Third, Wire your LEDs:
Add a dot of hot glue on close connections from shorting out.
solder on + and - connections, wrap w/ elect tape, then heat shrink. afterwards, lightly sand off the tip of the LEDs to reduce hot spots if you want.
fourth, refer back to second step. place board as low as possible, then hot glue both ends.
__________________
Warpspeed y-pipe, magnaflow cat, cattman b-pipe, apexi WS2, 00VI, shortram, Suprastick V4, DR mod, hayden 404,
ksports coilovers, FTSB, RTP rotors, 2K3 rims, LED interior
G4nismo is online now   Reply With Quote
Old 06-13-2008, 12:07 PM   #2
Results:
it appears a rather bluish b/c of the blue overlay underneath the display. theres nothing you can do about that.
now go cut off the stock bulb harnesh off and then connect it to your LED wires:
reassemble and your done
one other side note. for the last 2 LEDS displaying gear 2 and gear 1, you will be able to see some of the white and the led itself off to the side in the passenger seat, as you can sorda see in the above pic already. Not necessary but i went ahead and took care of it. just get like 1/2 inch high, 1.25 inch long piece of plastic and just stick it beside it. you can use black electrical tape as well.
__________________
Old 06-13-2008, 12:39 PM   #3
maaaaan i been wanting to do this for a while it looks nice man how hard was it to remove everything?
good job
__________________
oc_wicked is offline   Reply With Quote
Old 06-13-2008, 12:43 PM   #4
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
did you try wetsanding the color overlay to get rid of the blue?
__________________
Your source for premium Maxima/I30 parts!
My CarDomain
Houston Maximas
BLACKonBLACK98 is online now   Reply With Quote
Old 06-13-2008, 12:47 PM   #5
Send a message via AIM to Thakidmeen
Daaag thats hot, thx my man, Do u have pics of it inside your car?
__________________
97 Nissan Maxima GXE, all glory to GOD!
Clear bumpersl 02 Maxima rimsl2 kicker 12" subs, also 4 kicker inside speakersl Dynamat trunk kitl Eclipse head unitl Blue fogslShaved Maxima Emblem(Trunk) l 95-96 trunk conversion...lMore mods comming soon...Might drop this sucka..lol
Thakidmeen is offline   Reply With Quote
Old 06-13-2008, 12:49 PM   #6
Your friend list is empty
Kevlo911's Avatar
You can use 800/1000/1500 grit sand paper to sand away at the blue, it SHOULD come off but no guarantee as I found out for the gauges..
__________________
97 Pearl White Max GLE
191WHP and 201WTQ
Bi-Xenon retro for sale!!!
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 06-13-2008, 01:30 PM   #7
Quote:
if you do that, wouldn't it scrape off the black overlay as well?
thats kinda what i was afraid of so i left it alone.
__________________
Old 06-13-2008, 01:45 PM   #8
Send a message via AIM to MOHFpro90
The black is on the outside of the acrylic, the blue film is on the inside. I think.
I think we need a sticky update with the how tos that have been created in the last few days. Haha. Nice job man.
__________________
FOR SALE: Ksport coilovers! $225 + s/h!
00VI | 5.5Gen BBK | Axxis Ceramic | Raxles | Ksports | 00 5 spokes | AE'd | Cleared Tails | Shortram | 9007 conversion | LED interior | SNOMAX's LCAs
MOHFpro90 is online now   Reply With Quote
Old 06-13-2008, 02:03 PM   #9
negative, i looked underneath it, the blue film is on the outside.
i agree on the sticky update.
thanks mang
__________________
Old 06-13-2008, 02:05 PM   #10
Hmm. Is the black on the outside like I thought?
__________________
Old 06-13-2008, 02:15 PM   #11
man i really should of just taken a pic of it but now its already put back and i don't feel like removing it again lol.
the black is on the outside but its like painted on, or i guess overlayed.
i know for a fact that, that can be scratched off if not careful cause i noticed some of it coming off in the corners to where i could see through. so i just covered the PRND21 display and painted the whole black area black again.
and i'm guessing for the blue overlay, its on top of the black overlay. thats why i didn't wanna mess w/ that.
Old 06-13-2008, 02:28 PM   #12
Nice job as usual G4
__________________
OEM RIMS FTW!
WhiteA32 is offline   Reply With Quote
Old 06-13-2008, 04:41 PM   #13
looks good reminds me of my setup have to re do mine it was a pain getting the perfboard to stick didnt think of the hot glue idea
LiGhtSoUt is offline   Reply With Quote
Old 06-14-2008, 05:40 AM   #14
I have an auto..I am thinking about doing this..but also as a side note..I really like your shift knob...where did you get it?
__________________
Jonny Black is offline   Reply With Quote
Old 06-26-2008, 02:31 PM   #15
I have tried to remove the blue tint from the letters, and its not easy to do. There are 3 layers to this, black, white and blue. They are like this:
Blue(top)
White
Black(bottom)
When you go to sand off the blue(yes, it does come off), its hard to keep everything even. In other words, you sand off some blue, but start to sand off white, and eventually(if you're stupid) you will sand off black. Its a delicate process.
I ended up just sanding off all of the white in the lettering, so they are now see through, and then I took a black marker and filled in some spots where the black wore thin. It turned out ok, and now the blue is gone.
I will get some pics later.
__________________
Old 06-26-2008, 04:39 PM   #16
Blue(top)
White
Black(bottom)
wow, 3 layers, screw that. yeh posts some pics man. so did you actually do the LED mod or did you just sand those off for the fun of it lol?
__________________
Old 06-26-2008, 04:54 PM   #17
Decal Specialist
erty67's Avatar
Send a message via AIM to erty67
looks great
erty67 is offline   Reply With Quote
Old 06-26-2008, 05:31 PM   #18
G4,
I have had the LED mod done for quite a while. I will get some pics when I finish putting my car back together tonight or tomorrow.
__________________
Old 06-26-2008, 05:40 PM   #19
I like it. But I would like it better red led.
__________________
signature deleted. not appropriate.
Armelius is offline   Reply With Quote
Old 06-26-2008, 11:25 PM   #20
Carbon Fiber addict
Nice job G4nismo. With all these LED How-to's you're producing, we're gonna have to change your username to Mr. LED
Your How-to's give me the confidence to tackle these mini projects myself.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate.....381 HP/323 TQ
The Wizard is offline   Reply With Quote
Old 06-27-2008, 06:41 AM   #21
I'm going with a red and black leather interior,
red + blue = purple
__________________
'96 GLE: Y pipe, Test pipe, Cone filter on stock mid-pipe, Debadged, Re-Wired Amber Corners, Megan Catback, Clear bumper lights, tinted tails
Coming soon: oovi, and wait for my tranny to blow...(starting to lust after 5spd)
Future plans: 3.5, RMT, 6spd
Shoto925 is offline   Reply With Quote
Old 07-25-2008, 05:26 PM   #22
Send a message via AIM to dkillahster
I had done that.
but it was more simpler... not as bright, but ehh... it worked for me..
I changed the stock bulb to a blue bulb..
dkillahster is offline   Reply With Quote
Old 07-25-2008, 09:40 PM   #23
looks good nice job!
__________________
1999 SE
2003 SE
2006 SE
Automagic FWD FTW!
Nightkid08 is offline   Reply With Quote
Old 07-25-2008, 10:10 PM   #24
shift knob info ?
__________________
95 GLE
GreenMachine
BluFlame is offline   Reply With Quote
Old 07-26-2008, 07:18 PM   #25
Maxer
Send a message via MSN to t65k3
Nice job!
No offense here, g4nismo. Your method gives 100% even light.
Here I have a quicker way of doing this. I ordered one of those 5-led light bulb,
http://cgi.ebay.com/ebaymotors/194-1...spagenameZWDVW, (this is not a ad, this just shows where i got it from) You can get any other kind as long as they have leds facing sideways, not only to the front only.
I directly placed the original bulb with this LED bulb and cut two strips of aluminum tape as reflectors. The bottom is actually rounded and could give a pretty good reflection.
At night, it looks like
Again, no offense.
Love your radar detector work!
Peace~
__________________
When 2.0 Meets 1.0 ......
t65k3 is offline   Reply With Quote
Old 07-26-2008, 07:32 PM   #26
The JDM Rat.
timmay5835's Avatar
nice work, you want to LED my whole interior for me?ha, with all these write ups you are making me want to LED some of my interior.
__________________
Granny's GLE, its stock i sware.
4th gen OWNZ ALL!
timmay5835 is online now   Reply With Quote
Old 08-03-2008, 12:52 AM   #27
I did the s
