Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 06-12-2008, 11:54 PM   #1
How-To: Install AE Pedals + 350Z Dead Pedal On Your 4th Gen
Alright, since there is no write-up for this on the .org, I figured I would take everyone though a step-by-step process of how to do it. It is really an easy job and anyone can do it.
Parts Needed:
(1) Nissan 350Z Footrest Assembly: Part # - 67840-CD00C ($23.68)
(2) Nissan AE Maxima Clutch/Brake Pedal Cover: Part # - 46531-AB000 ($19.14 ea.)
(1) Nissan AE Maxima Gas Lever Assembly: Part # - 18005-4Y900 ($27.76)
(1) 8x1-3/4 Flat Philip Head Zinc Finish Screws ($1.03)
I got the OEM parts from Dave Burnette at Southpoint Nissan at cost, and after shipping my grand total of parts came to $99.50 with the screws added in.
__________________
1999 Super Black SE 5MT '00VI|VAFC-II|Fed Spec Conversion|Cattman Y|Budget B|HKS Rear Section|Stillen Hi-Flow Intake
OBX STS|18" Mille Miglia Evo 5s|Stillen FSTB|Progress RSB|Intrax Springs|KYB AGX Struts|AE Pedals+350Z Dead Pedal
Escort Passport 8500 Hardwired|Red/Clear Tails|Clear Bumper Lights|35%/25% Tint|Nismo Shift Knob|I30 Leather E-Brake+Autodim Mirror
Exedy Stage II Clutch|I30 VLSD Transmission
99BlackMaxMS is offline   Reply With Quote
Old 06-12-2008, 11:55 PM   #2
Tools Needed:
Bench Vise
Metal Hack Saw
Bench Grinder
Power Drill
1/8" Drill Bit
10mm Socket
Ratchet
Small Philips Head Screwdriver
Long Flathead Screwdriver
Stubby Flathead Screwdriver
__________________
Old 06-12-2008, 11:55 PM   #3
Step One: Preparing The Dead Pedal
The 350Z does not come from the factory with an elevated spot for a dead pedal, therefore there is a lot of unnecessary plastic that needs to be cut away.
First, remove the five (5) screws (four silver metal ones at each corner, and one black one in the center). Put the aluminum cover in a safe spot as it is very bendable.
Once separated, clamp the black plastic base to the bench vise and start sawing away. Leave about 1/2-3/4" of clearance between the top and the side of the pedal. Next, use the bench grinder or a sander/sandpaper to finish the edge of the pedal and to even out the base. It should look like this when finished:
__________________
Old 06-12-2008, 11:56 PM   #4
Step Two: Positioning/Mounting The Dead Pedal
Now that your dead pedal is correctly cut and finished to your liking, use the small Philips head screwdriver and screw in the small black screw to secure the aluminum plate to the base.
Go outside into your car and place the pedal where you would permanently like to place it. Rest it in place and begin drilling. You can drill directly through the carpeting. After drilling the four holes, take one 8x1-3/4 screw and fill in the four holes you just drilled. Voila, your dead pedal is installed and secured safely.
Before:
After:
__________________
Old 06-12-2008, 11:56 PM   #5
Step Three: Clutch/Brake Pedals
First off, if you have an automatic, you complete this task with only one pedal (clearly) but can use the same method as I did.
Begin by peeling back the old clutch and brake pedals. They should come off with little effort. I found it best to reinstall the new pedal cover in a specific order, making each corner/side easier to slip on. Using the stubby flathead screwdriver, slide the top right corner and right side on. Next, use the flathead to flip the backing away while you set the top left part of the cover in place. Continue this process until you get the entire cover on.
I found it best to install the cover in the following order:
Continue on and do the same for the brake pedal.
Step Four: Accelerator Pedal
Begin by removing the throttle cable from the very top of the pedal assembly. It is kind of tricky, but if you wedge your long flathead screwdriver between the plastic clip and the metal on the pedal arm, it will pop free. The cable is located where these two red arrows are pointing to:
Next, unbolt the two 10mm nuts holding the pedal bracket in place (located on the firewall). Once these are taken off, the whole gas pedal assembly (pedal and arm) will fall out.
Continue the re-installation of the new pedal in reverse order of taking out the old one (first bolt in the two 10mm nuts that hold the pedal to the mounting bracket, then clip in the throttle cable).
__________________
Old 06-12-2008, 11:57 PM   #6
You are finished. Put back your floormat and enjoy.
Before:
After:
__________________
Old 06-13-2008, 12:18 AM   #7
Well done !!!...looks good mate.
__________________
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Jan-2009
Snypa is offline   Reply With Quote
Old 06-13-2008, 01:32 AM   #8
looks great!!
maxx0831 is offline   Reply With Quote
Old 06-13-2008, 07:47 AM   #9
Your friend list is empty
Kevlo911's Avatar
Nice write up. I believe the old one say you can swap out just the gas pedal by drilling out the back of the pedal bigger.
__________________
97 Pearl White Max GLE
191WHP and 201WTQ
Bi-Xenon retro for sale!!!
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 06-13-2008, 08:04 AM   #10
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Nice job and thanks for detailed pics.
__________________
Fr33way™ is offline   Reply With Quote
Old 06-13-2008, 08:30 AM   #11
00vi'dvq30devq354.5genftw
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Cool looks like my Z. lol
ajcool2 is online now   Reply With Quote
Old 06-13-2008, 08:40 AM   #12
Newbie-Just Blazed
Send a message via AIM to QNO_A32
good job.... this is a nice cheap little interior project.+1
__________________
SHIFT_ A REBUILT TRANNY
QNO_A32 is online now   Reply With Quote
Old 06-13-2008, 09:17 AM   #13
Send a message via AIM to G4nismo
very nice write up man! i need to do this sometime down the road...
__________________
Warpspeed y-pipe, magnaflow cat, cattman b-pipe, apexi WS2, 00VI, shortram, Suprastick V4, DR mod, hayden 404,
ksports coilovers, FTSB, RTP rotors, 2K3 rims, LED interior
G4nismo is online now   Reply With Quote
Old 06-13-2008, 10:01 AM   #14
Send a message via AIM to MOHFpro90
Holy crap that was a nice write up. Yeah looks hella better man, very nice job.
__________________
FOR SALE: Ksport coilovers! $225 + s/h!
00VI | 5.5Gen BBK | Axxis Ceramic | Raxles | Ksports | 00 5 spokes | AE'd | Cleared Tails | Shortram | 9007 conversion | LED interior | SNOMAX's LCAs
MOHFpro90 is offline   Reply With Quote
Old 06-13-2008, 10:44 AM   #15
Send a message via AIM to SoMarvelus
yeah, thats nice, now whats needed is the black carpet
__________________
From the Blackness
I had to get it, it was Crimson Blaze
SoMarvelus is offline   Reply With Quote
Old 06-13-2008, 12:56 PM   #16
Looks awesome, love the pedals!
__________________
Please read the forum rules on sig pic size before posting another picture.
Bandfan1024 is offline   Reply With Quote
Old 06-13-2008, 04:04 PM   #17
ZHP
4DRSpeed's Avatar
Send a message via AIM to 4DRSpeed
good job on the write up. With the gas pedal all you need to do is take the stock pedal off. The Z's pedal hole is a little bigger, so I just took some electrical tape and wrapped it around the pedal assembly and then just slid the Z pedal on. It was nice and snug then.
__________________
'96 Nissan Maxima SE 5-SPD - Ruby Pearl/BLK Leather
4DRSpeed is offline   Reply With Quote
Old 06-13-2008, 04:27 PM   #18
under construction
95 maxima se's Avatar
Send a message via MSN to 95 maxima se
wow im gonna have to do this to my max
__________________
'99 NISSAN MAXIMA SE-L CRIMSON BLAZE (5-Spd) DD RED/CLEAR w/ BATMOBILE OVERLAYS l CAI l WARPSPEED Y-PIPE w/ HI FLOW CAT l MEGAN EXHAUST l DROPZONE SPRINGS l 8K HID l R34 HD l EXEDY STAGE 1 CLUTCH l 17'' G35 COUPE RIMS l 17X7.5 30mm (F) 17X8 33mm(R) l MEGAN FSTB l BLK BUMPER LIGHTS l UR UPD l PBR/AXXIS PADS l ZINC PLATED RTP X-DRILLED ROTORS l
FOR SALE:
ID HALF SIZE ROOF WING
1.07.09
91 240sx FASTBACK 5-SPD
95 maxima se is offline   Reply With Quote
Old 06-13-2008, 07:43 PM   #19
khantalha+'s Avatar
Send a message via MSN to khantalha+ Send a message via Yahoo to khantalha+
nice work man.... good job .. and thanks for the part numbers tooo
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Day/Grocery Getter) = sold
myspace.com/shady_aftermath_
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
khantalha+ is offline   Reply With Quote
Old 06-13-2008, 08:38 PM   #20
PearlMaX
93altima's Avatar
This Should be Stickied ill try this in about a month or two
__________________
95 Pearl White Maxima with 00 DEK, Summit RPM Switch, Shrot throw shifter, Test Pipe Cat, N1 Cat back, Warpspeed Y-Pipe, dropped, 300zx rims, re-wired fogs, De-Badged Trunk, NGK Iridium IX Plugs, Custom Cold air intake, Black Housing lights, and L.E.D license plate lights
Shift_Break 1 Tranny at a time
Personal Best: 11/28/08 14.807 @ 93.82mph
93altima is offline   Reply With Quote
Old 06-13-2008, 11:11 PM   #21
Thanks for all the compliments guys. Kevlo already stickied it in the interior sticky under the 4th gen forum.
For the reference these are stock 20th anniversary edition pedals (clutch, brake, and gas) with only the 350z dead pedal.
__________________
Old 06-13-2008, 11:43 PM   #22
4th Gen Parts King
Maxima_Joe's Avatar
Do you happen to know if they make the brake cover for automatic cars?
__________________
If you need a 4th gen part contact me:
I do not ship large parts such as
engines, transmissions, seats, hoods, fenders, bumpers, doors or trunk lids due to the hassle.
Maxima_Joe is offline   Reply With Quote
Old 06-14-2008, 09:39 AM   #23
Build.
Send a message via AIM to nismology
Quote:
Yes.
46531-AB010
__________________
"Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing ever happened."
nismology is offline   Reply With Quote
Old 06-14-2008, 10:34 AM   #24
Wow! I can't wait to try this one out. Looks Good.
maxina97 is offline   Reply With Quote
Old 06-21-2008, 02:16 PM   #25
speedymax99's Avatar
Send a message via AIM to speedymax99 Send a message via Yahoo to speedymax99
I just did the install and was very easy to put in
__________________
Shift BOOSTED REDLINE
speedymax99 is offline   Reply With Quote
Old 06-22-2008, 08:54 AM   #26
damn looks good, might just have to do that
__________________
Gb2St is offline   Reply With Quote
