Removing AC Compressor
Old 06-10-2008, 07:40 AM
tc97max's Avatar
Is there a way to remove the compressor for good. I have no condenser because I never replaced it after a reck and dont plan on replasing it so I don't care about not having ac. The reason I would like to take the compressor off is because it is making an annoying noise and I dont want it to lock up and mess things up. So I would like to just take it off and not have to worry about that happening my question is do I have to get a free spinning pully or smaller belt since the crank, alternator and compressor use the same one? I have heard of people taking them off for racing how do they do that?
tc97max is offline
Old 06-10-2008, 07:49 AM
dashan's Avatar
You don't need to remove the compressor. Get a shorter belt and bypass the compressor. You might get some extra horse power at the wheel when bypassing it.
dashan is offline
Old 06-10-2008, 07:58 AM
tc97max's Avatar
So leave the compressor there and get a shorter belt to go in front of it? What size? and I would like to take the compressor off anyway to take it appart and see whats wrong with it.
tc97max is offline
Old 06-10-2008, 08:00 AM
4th Gen Parts King
Maxima_Joe's Avatar
It's in the stickies and theres many threads about it. If you search you will find them. From memory it's a 36" belt.
Maxima_Joe is offline
Old 06-10-2008, 08:02 AM
tc97max's Avatar
How would using a smaller belt work anyway? would the belt touch it self at the tensioner? Any one done this before? have pics?
tc97max is offline
Old 06-10-2008, 08:06 AM
4th Gen Parts King
Maxima_Joe's Avatar
If you need help routing a belt you probably shouldn't attempt this. It goes on the same way the stock belt does it just doesn't go around the ac compressor pulley anymore.
Old 06-10-2008, 08:08 AM
4th Gen Parts King
Maxima_Joe's Avatar
I'll be nice. I just did a search which took less then a minute and it even has a picture.
http://forums.maxima.org/showthread....736&highlight=
Old 06-10-2008, 08:13 AM
tc97max's Avatar
Ok i searched and found some info. I don't need help routing a belt it just looked like it would not work with out a compressor because the alternater is above the tensioner but I guess it will work just didnt look right.
tc97max is offline
Old 06-10-2008, 08:17 AM
Turbobink's Avatar
I did it.
It's cake and the compressor stays put. I'm running with the compressor by-passed right now.
If you do the search you'll find a couple of belt lengths that will work.
Just be sure to be in that range of lengths.
Turbobink is offline
Old 06-10-2008, 09:20 AM
tc97max's Avatar
thanks guy's compressor is off and 36in belt is on!
tc97max is offline
Old 06-10-2008, 11:55 AM
ajcool2's Avatar
I still need to replace my bearing. I just dont know how hard it is. Glad you got it on with no problem.
ajcool2 is offline
Old 06-10-2008, 12:42 PM
Turbobink's Avatar
that's easy too. no need to remove the compressor.
you will need a compressor clutch holding tool. http://www.autozone.com/R,NONAPP101/...ductDetail.htm
once the clutch disc is removed you'll need to take it to a machine shop to have the old bearing pressed out and the new one pressed in.
a new bearing is $35.00 to about $55.00 depending on the which compressor you've got. http://www.partsamerica.com/ProductD...pe=450&PTSet=A
Old 04-27-2010, 11:08 AM
FatalException's Avatar
Hey, quick question.
I also need to bypass my A/C but I dont plan on removing it. Though I cant seem to find a 36" belt for my 98. On gates website it just shows me the regular 43" one that goes around everything. Would anyone happen to have a link?
FatalException is offline
Old 04-27-2010, 12:21 PM
SrgScott's Avatar
Just go to an auto store(o reilly, auto zone, pep boys) and ask them for a 36" belt. Then just put it on your max.
If you search for a belt for a specific vehicle(like our max) youre going to find the belt size that goes around everything to run all acceseries. So just go pick up a 36" belt.
And seriously? This thread is over 2 years old.
SrgScott is offline
Old 04-27-2010, 12:30 PM
Ah, ok, got it.
At least I used the search feature instead of starting a new thread = ]
my03maxima
04-29-2020 12:48 AM
doctorpullit
03-29-2016 11:08 AM
RealityCheck
10-02-2015 06:34 PM
jaydot901
09-29-2015 01:18 PM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: Removing AC Compressor
