Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Sponsored by: FCP Import
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-27-2010, 11:20 PM   #41
The Dirty Pearl
pmohr's Avatar
Points: 21,018, Level: 91
Points: 21,018, Level: 91 Points: 21,018, Level: 91 Points: 21,018, Level: 91
Activity: 9.7%
Activity: 9.7% Activity: 9.7% Activity: 9.7%
Quote:
Originally Posted by blakshukvw View Post
I have a question related to water pump removal. I replaced one of these in a 96 max about 8 years ago but hardly remember it. I didn't use the 2 bolt removal method of the pump and still to this day don't understand how it works. If your threading bolts into the theads in the pump and into the threads in the block that the pump mounting bolts thread into, then how does this cause the pump to walk out? I think I tried it but found it was removing the threads in the block so I stopped and just used a prybar to get the pump out.
You're threading bolts into the threads on the pump, not into the timing cover.
The bolts that fasten the water pump to the timing cover are M6 (10mm head). The bolts you use to jack it out are M8 (12mm head). The M8 threaded holes will allow the M6 bolts to pass through and hold it down, but when you thread in M8 bolts, they push against the timing cover and force the pump out.
__________________
A32 CEL Decoder | FSMs | Howto Videos
pmohr is offline   Reply With Quote
Old 08-28-2010, 12:13 PM   #42
Okay. I didn't know that. That makes complete sense. Thanks.
blakshukvw is offline   Reply With Quote
Old 06-02-2012, 09:37 PM   #43
Points: 248, Level: 4
Points: 248, Level: 4 Points: 248, Level: 4 Points: 248, Level: 4
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
http://www.youtube.com/watch?v=ibfs1Zu9h4o
This is the How To video for all 4th gen maxima's on how to replace the water pump. Few bad angles but overall very helpful!
ADHDadditiv is offline   Reply With Quote
Old 06-03-2012, 06:58 PM   #44
Points: 3,375, Level: 36
Points: 3,375, Level: 36 Points: 3,375, Level: 36 Points: 3,375, Level: 36
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
I used this the whole time!!
Goodspeed91 is offline   Reply With Quote
Old 07-23-2012, 04:36 AM   #45
Points: 13,081, Level: 74
Points: 13,081, Level: 74 Points: 13,081, Level: 74 Points: 13,081, Level: 74
Activity: 17.6%
Activity: 17.6% Activity: 17.6% Activity: 17.6%
His videos were very helpful and I used them this weekend on my 96.
Let me add one thing about removing the water pump from the car after you've pulled it out of the engine. He doesn't tell you how to do it. I figured it out after much swearing.
Notice that there are three bolts holes on three corners of the water pump and then there is a curved corner.
That curved corner corresponds to a curved portion of the frame rail. To get it out, you have to align the curves. That will leave you with two of the three bolts holes on the engine side and the other bolt hole on the frame rail side.
You then need to tilt it to get it out. That will take some playing with it to get it right.
Oh, and also expect to hear a rattle when you start the car that will make you think you screwed up the job! Just turn off and back on. All will be fine.
I did not remove the motor mount. Frankly, it really wasn't in the way. Not nearly as much as the PS reservoir.
Overall, this isn't as difficult of a job - especially with the video - as I thought. One thing though, you must have some wrenches. Ratcheting wrenches make it a lot easier. I have those. At points wished I had some longer ratcheting or offset wrenches too.
__________________
2000 SE 5spd Black/Black
Timing Advanced to 17 BTDC ; Place Racing CAI ; Unorthodox Racing UDP ; JWT Stage 1 Clutch ; Cattman Headers; Cattman Mid Pipe ; Tokiko Illuminas/Eibach Springs ; Pacesetter STS ; Courtesy FTSB ; Pilot Sport A/S 225/50/17
Best 1/4 mile: 14.39 @ 98.03 2.195 60'
1996 SE Auto Pearl/Black
Stock - 280,000+ Miles
Max_Gator is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
