Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 05-01-2008, 04:20 PM   #1
Send a message via AIM to USC Justice
Leaking Manual transmission question
OK. I have done the 5spd conversion on my 96 Maxima SE. Got it put back together and it leaked from both axle seals. replaced the seals, and it still leaked from both sides. Read some more and discovered the thread on the Differential Bearings. Out of the car goes the transmission for a tear down. The bearings and their races were shot to say the least. There was no other damage inside the transmission.
New races, shims, bearings, and reassemby. Now the transmission is back in the car. It leaks a little from the passenger side axle seal at the bottom (not from the axle itself). I have now changed out with a spare passenger side axle that I had from the automatic. No change in the leak. I have also changed out the seal on the passenger side as well. Now that this has been completed, it still leaks a bit, but much less than before.
Could it be that I have overfilled the transmission (read conflicting reports on how much transmission fluid goes in) and it's simply pushing out the overfilled amount through the seal?
Any other thoughts on the possible cause for the leak? The axle seal is from Nissan, and I also checked where the seal fits for any burrs or other abberations that could prevent the seal from seating.
Thanks in advance.
Donald
__________________
"The only thing necessary for the triumph of evil is for good men to do nothing" - Sir Edmund Burke
USC Justice is offline   Reply With Quote
Old 05-01-2008, 05:22 PM   #2
The Dirty Pearl
pmohr's Avatar
Points: 22,440, Level: 93
Points: 22,440, Level: 93 Points: 22,440, Level: 93 Points: 22,440, Level: 93
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Did you fill the trans on (relatively) level ground? If so, you didn't overfill it (not without some sort of pump and quick hands, anyway).
There's a breather for excess fluid, it wouldn't leak out of a seal.
You put an auto axle in your trans?
__________________
A32 CEL Decoder | FSMs | Howto Videos
pmohr is offline   Reply With Quote
Old 05-01-2008, 05:39 PM   #3
The car is a 96, the transmission is from a 97, and the manual axles are from a 99. As I understand it, the passenger side axle is the same regardless of auto or manual. Currently the manual axles are in both sides.
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
