CAI, Y pipe, B pipe disadvantages????
Old 04-29-2008, 08:05 PM
aramax's Avatar
as the title is pretty much self explainetpry, are there and disadvantages from installing, CAI, Y-pipe, or a B pipe?
aramax is offline
Old 04-29-2008, 08:12 PM
The Russian's Avatar
maybe noise? and cops might have more reasons to pull you over? only other thing is power.....if you cant control yourself from getting on it, then your car will be eating alot of gas
The Russian is offline
Old 04-29-2008, 08:22 PM
Wild for Width
Fr33way™'s Avatar
Nothing. ^^ Like Russian said it depends on you.
Also, get a suspension first...
Fr33way™ is offline
Old 04-29-2008, 08:59 PM
Snypa's Avatar
i been hearing mostly good stuff.Did them and happy.
Snypa is offline
Old 04-29-2008, 09:17 PM
maxboy325's Avatar
+1 on suspension first if you haven't already
maxboy325 is offline
Old 04-29-2008, 09:20 PM
!PrjctMax!'s Avatar
stock mufflers=quiet ride...so no real "noise" disadvantage
Do a few suspension mods, then go for performance
!PrjctMax! is offline
Old 04-29-2008, 09:58 PM
Shift_3.0
devilz05's Avatar
Grab a Rear Sway Bar, you won't regret it.
devilz05 is offline
Old 04-29-2008, 10:16 PM
hot_wax_tree's Avatar
does it really do that much?
hot_wax_tree is offline
Old 04-30-2008, 06:27 AM
Crusher103's Avatar
Konis on H&Rs were my first mod, love them now im moving on to pwr mods
Crusher103 is offline
Old 04-30-2008, 06:49 AM
Coolsaber57's Avatar
Yes, it makes a big difference. I was a skeptic at first, as the FSTB didn't do much, but I was very pleasantly surprised.
Coolsaber57 is offline
Old 04-30-2008, 08:05 AM
Shift_3.0
devilz05's Avatar
The difference is night and day, my friend. The car handles like a boat in rough water without one.
If you don't have that much money to blow on mods just invest in a Rear Sway Bar and Y-Pipe and be done with it. Those are the best bang for the buck mods as far as handling and power is concerned.
devilz05 is offline
Old 04-30-2008, 08:08 AM
dot dot dot ...
NmexMAX's Avatar
I think I've been here too long
NmexMAX is offline
Old 04-30-2008, 08:50 AM
RacerX1320's Avatar
Intake=Blah
Y Pipe =
Rear sway=
Light wheels and es mounts=
RacerX1320 is offline
Old 04-30-2008, 09:45 AM
!PrjctMax!'s Avatar
Originally Posted by RacerX1320
Intake=Blah
Y Pipe =
Rear sway=
Someone should get his light-weight lug-nuts too...
Old 04-30-2008, 11:52 AM
mastere954's Avatar
back to the original question
= runnin rich
mastere954 is offline
Old 04-30-2008, 05:59 PM
dot dot dot ...
NmexMAX's Avatar
Running rich?
NmexMAX is offline
Old 05-01-2008, 05:55 AM
maxboy325's Avatar
Originally Posted by NmexMAX
Running rich?
Old 05-01-2008, 04:15 PM
aramax's Avatar
i got kyb AGX and k-sports ready to be putted on and i got about 600 hundred more to fix the look and the power! after y-pipe and RSb( which I'm def. going to get it what else?!
aramax is offline
Old 05-01-2008, 06:47 PM
Shift_3.0
devilz05's Avatar
Try to find the Y-Pipe and RSB used on the forum, you will end up saving quite a bit of cash. Also, make sure you know whether your car is Cali or Fed spec before investing in the Y. Don't forget, the Y-pipe needs to be installed as well. It's a pain in the a$$ if you intend on doing it yourself. You might even need to invest in an 02 sensor or two if the tread strips off them. Do a search if you don't know if your car is Fed Spec...
As a side note, I did notice that my cat-back has a mean bend right before the muffler where it has to clear some metal. The diameter of the pipe gets cut in half at that point. IDK if all Maximas have that or that was just my mechanics attempt at putting on a new muffler for me.
/Rant
devilz05 is offline
Old 05-01-2008, 09:33 PM
TheWhiteWhale's Avatar
I dont know about Cali spec pipes, but when I put my Budget Y in it was actually pretty easy. Most of the bolts can be broke lose with some decent penetrant, but I will admit I had to take a torch to the cat bolts, and the o2 sensors are definitely at risk if you have a pretty decent amount of miles (my rear one failed immediately after I installed the pipe). I guess the main thing is preparation-I just couldn't justify paying someone else even $50 for the install.
TheWhiteWhale is offline
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
06-06-2017 02:01 PM
Quickywd01
09-21-2016 09:36 PM
09-27-2015 08:37 AM
Quick Reply: CAI, Y pipe, B pipe disadvantages????
